Home » Modeling » Graphiti » [Spray] Problem with anchors
[Spray] Problem with anchors [message #1385168] Wed, 04 June 2014 13:35 Go to next message
Hi all,
I will use pseudo code to describe the problem.
I have two shape definitions as follows:
Shape A {
anchor {
position (xoffset=0.5, yoffset=0.0) // middle-top
position (xoffset=0.5, yoffset=1.0) // middle-bottom
Shape B {
anchor {
I have a connection that connects these two types. Somehow, every new connection that is created ALWAYS attachs the 'middle-top' anchor.
Note that both anchor points are visible and I can alter the connections (source/target points) after that to attach to the middle-bottom anchor.
The problem comes from this method
protected Anchor getDslShapeAnchor(PictogramElement pe) {
if (pe == null) {
return null;
Shape dslShape = SprayLayoutService.findDslShape(pe);
if (dslShape != null) {
EList<Anchor> anchors = dslShape.getAnchors();
if (!anchors.isEmpty()) {
return anchors.get(0); //<-------- ALWAYS THE FIRST
return null;
that returns always the first anchor.
How do you solve this problem in Graphiti? I mean, how do you get the anchor closer to the mouse pointer?
Thanks for your help
Simone
Re: [Spray] Problem with anchors [message #1385227 is a reply to message #1385168] Thu, 05 June 2014 01:24 Go to previous messageGo to next message
You are not asking for the mouse position to receive any anchor, you always return the same?
I wrote an editor for a grammar, where its necessary where the connection ends/starts, so I wrote an extra popup for it.
In your case you can ask for the relative coordinates of the anchor and compare it with the mouse position? Maybe that helps.
Re: [Spray] Problem with anchors [message #1385300 is a reply to message #1385227] Thu, 05 June 2014 09:30 Go to previous messageGo to next message
Soern,
I think you misunderstood the question. That method is created by Spray, and it does return always the first anchor (that is wrong).
Now, if you have a shape with two anchors, how do you get the anchor near the mouse position?
I was thinking about drag&drop, but Spray has bugs even there.
Re: [Spray] Problem with anchors [message #1385813 is a reply to message #1385168] Wed, 11 June 2014 07:33 Go to previous message
Hi Simone,
in plain Graphiti you would check the mouse location at the time the
connection is created and compare to the locations of the available anchors.
Then you would not use the anchor provided in the create connection context
(usually the chopbox anchor or the first anchor of the shape) but the one
you determined.
But I don't know if and how that procedure is applicable to Spray.
Michael
Previous Topic:Rotate GraphicsAlgorithm
Next Topic:Possible bug with BoxRelativeAnchor
Current Time: Thu Jul 24 23:42:31 EDT 2025
Powered by FUDForum. Page generated in 1.30353 seconds
