Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] Retaining ID's
[EMFStore] Retaining ID's [message #1385671] Tue, 10 June 2014 08:16 Go to next message
I have an EMF XMI resource that we have generated with manually set ID's. I wrapped all the EObjects in relevant EMFStore project and imported. This has well, but when I go to export the project, all the ID's I have set are replaced with UUID's.
Is there a way to retain all my ID's in ECP/EMFStore?
Mt Naj.
Re: [EMFStore] Retaining ID's [message #1385775 is a reply to message #1385671] Wed, 11 June 2014 03:39 Go to previous messageGo to next message
yes, you can use the internal API to set the IDs of you Resource as IDs
for EMFStore. You need to cast ESLocalProject to ESLocalProjectImpl and
then call
ESLocalProjectImpl.toInternalAPI().getProject().allocateModelElementIds(Map<EObject,
ModelElementId>).
Hope this helps!
Maximilian
Am 10.06.2014 14:16, schrieb Mt Naj:
> Mt Naj.
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Retaining ID's [message #1450831 is a reply to message #1385775] Wed, 22 October 2014 21:05 Go to previous messageGo to next message
I have the exact same problem, but I'm running in the context of an ECPProject.
I used the suggested approach with:
ModelElementId mei = ModelUtil.createModelElementId("999");
eObjectToIdMapping.put(defaultRelationship, mei);
then before calling save:
final ECPProject project = ECPUtil.getECPProjectManager().getProject(baProject);
InternalProvider ecpProvider = (InternalProvider)project.getProvider();
EMFStoreProvider emfProvider = (EMFStoreProvider)ecpProvider.getAdapter(EMFStoreProvider.class);
ESLocalProject projectSpace = emfProvider.getProjectSpace((InternalProject)project);
ESLocalProjectImpl projectSpaceImpl = (ESLocalProjectImpl)projectSpace;
projectSpaceImpl.toInternalAPI().getProject().allocateModelElementIds(eObjectToIdMapping);
Followed by:
project.saveContents();
There are no errors reported but the assigned ID of 999 is replaced by a generated ID at the end.
Are there special considerations that I need to take here?
Alain
Re: [EMFStore] Retaining ID's [message #1451213 is a reply to message #1450831] Thu, 23 October 2014 09:45 Go to previous messageGo to next message
BTW I got it to work, but I have to make sure the allocateModelElementIds is called before the object is attached to the model.
This greatly impacts the design of the code that I have. Is there a better solution like providing the map and making sure it is updated before attaching objects to the model ?
Alain
Re: [EMFStore] Retaining ID's [message #1451326 is a reply to message #1451213] Thu, 23 October 2014 13:14 Go to previous message
Hi Alain,
somehow you must pass in a mapping of EObject to ID to the framework if
you wish to use your own IDs. So I see no way to avoid this, but maybe I
do not understand your question.
Maximilian
Am 23.10.2014 15:45, schrieb Alain Picard:
> model.
> Thanks
> Alain
Maximilian Kögel
Previous Topic:[EMFFORMS] Tree and Tree Master Detail View
Next Topic:[EMFForms] ViewModelContextImpl notification exception
Current Time: Mon Jul 21 10:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.05882 seconds
