Home » Modeling » TMF (Xtext) » xtext grammar import ATL metamodel
xtext grammar import ATL metamodel [message #1053683] Tue, 07 May 2013 04:40 Go to next message
Dear All,
I try to define a dsl which use some elements defined in an atl transformation.
So, using TCS injection of ATL, the textual representation of ATL transformation is generated as an xmi model conforms to ATL metamodel.
for example,
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:atl="http://www.eclipse.org/gmt/2005/ATL" xmlns:ocl="http://www.eclipse.org/gmt/2005/OCL">
  <atl:Module location="1:1-391:2" name="S2F">
    <inModels location="5:2-5:27" name="SModel" metamodel="/48"/>
    <outModels location="3:2-3:31" name="FModel" metamodel="/47"/>
    <outModels name="SModel2FModel" metamodel="/1"/>
    <elements xsi:type="atl:MatchedRule" location="7:1-100:2" name="Process2Program">
Therefore, I try to refer in my dsl to some elements in the atl model.
I define an import:
import "platform:/resource/MetaModels/ATL.ecore" as atl
For example, a kind of xtext rule.
Affectation:
	reference  = ID '<-' rule=[atl::MatchedRule]
However, when I run the workflow, I have error (which is normal) because
"Could not find a GenModel for EPackage 'http://www.eclipse.org/gmt/2005/ATL'".
By contrast, ATL haven't a Genmodel (ATL.genmodel).
How can I resolve this problem, please.
Re: xtext grammar import ATL metamodel [message #1385450 is a reply to message #1053683] Fri, 06 June 2014 09:50 Go to previous messageGo to next message
Hi, i am interested about this issue, did you found an answer ? Best regards.
Re: xtext grammar import ATL metamodel [message #1385476 is a reply to message #1385450] Fri, 06 June 2014 14:14 Go to previous messageGo to next message
you have to register the genmodels in the workflow (as it is done with the xbase in the workflow created by the wizard)
Re: xtext grammar import ATL metamodel [message #1385639 is a reply to message #1385476] Tue, 10 June 2014 04:21 Go to previous message
You can :
- create the genmodel and use it in xtext
- I believe there was a "registerEcoreFile" option for the mwe workflow
Previous Topic:Access to Java Fields at DSL
Next Topic:project java --> +/- java
Current Time: Sun Jul 27 01:53:47 EDT 2025
Powered by FUDForum. Page generated in 0.03819 seconds
