Home » Eclipse Projects » Subversive » Mime-types not set
Mime-types not set [message #1385431] Fri, 06 June 2014 07:43 Go to next message
Hi I am using Eclipse SVN. When committing from Team->Commit, I get the following error message although I have set the mime type in the config file (see attached)
Is there anything else I need to do?
svn: Commit blocked by pre-commit hook (exit code 1) with output:
/opt/svn/repositories/administration/hooks/check-mime-type.pl:
Project1/cleanup.json : svn:mime-type is not set
  • Attachment: config.txt
    (Size: 2.89KB, Downloaded 511 times)
Re: Mime-types not set [message #1402996 is a reply to message #1385431] Sat, 19 July 2014 11:44 Go to previous message
Hi!
I've checked the file and the first thing to draw my attention was the name of the configuration file. In my case it is called simply 'config' and not 'config.txt'. So, it is possible that the file was completely ignored by the SVN client library.
So, in order to check if that is the case, you may try adding/committing resources using command line tool. If it works, then you may try JavaHL based connector and then SVN Kit connector in order to check if there is a difference or not.
Another way is to use plug-in's functionality:
Window->Preferences->Team->SVN->Properties Configuration->Automatic properties.
Previous Topic:wrong resource URL appears in label on imported projects
Next Topic:Checking out Large Reposotories
Current Time: Fri Jul 25 19:56:22 EDT 2025
Powered by FUDForum. Page generated in 0.04553 seconds
