Home » Eclipse Projects » Oomph » Creating a Kepler based setup (httpclient 4.1 vs 4.2)
Creating a Kepler based setup (httpclient 4.1 vs 4.2) [message #1385413] Fri, 06 June 2014 05:24 Go to next message
I tried to create a setup which uses Kepler as a base but it seems that there are some plugins that are part of Eclipse which needs to be a higher version for Oomph to work.
Specifically, I get the following exception when the new Eclipse starts:
An internal error occurred during: "Setup check...".
java.lang.NoClassDefFoundError: org/apache/http/impl/cookie/DateParseException
	at org.eclipse.oomph.internal.setup.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:191)
	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
[...standard EMF loading...]
	at org.eclipse.oomph.internal.setup.core.util.EMFUtil$1.getResource(EMFUtil.java:720)
[...standard EMF proxy resolution...]
	at org.eclipse.oomph.setup.impl.InstallationImpl.getProductVersion(InstallationImpl.java:79)
	at org.eclipse.oomph.internal.setup.core.SetupContext.getInstallation(SetupContext.java:308)
	at org.eclipse.oomph.internal.setup.core.SetupContext.createSelf(SetupContext.java:125)
	at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:168)
	at org.eclipse.oomph.setup.ui.SetupUIPlugin.access$3(SetupUIPlugin.java:147)
	at org.eclipse.oomph.setup.ui.SetupUIPlugin$1$1.run(SetupUIPlugin.java:116)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.ClassNotFoundException: org.apache.http.impl.cookie.DateParseException cannot be found by org.eclipse.oomph.setup.core_1.0.0.v20140605-1702
I checked and the manifest.mf of oomph.setup.core expects:
   org.apache.httpcomponents.httpclient;bundle-version="[4.2.0,5.0.0)";resolution:=optional,
   org.apache.httpcomponents.httpcore;bundle-version="[4.2.0,5.0.0)";resolution:=optional,
But in the new Eclipse, there is only:
   org.apache.httpcomponents.httpclient (4.1.3.v201209201135) "Apache HttpComponents HttpClient OSGi bundle" [Resolved]
Is there an exitsing way of dealing with this easily or is Kepler simply not compatible with the new Oomph (even though you can choose it as a product version)?
Thank you for any suggestions!
Re: Creating a Kepler based setup (httpclient 4.1 vs 4.2) [message #1385420 is a reply to message #1385413] Fri, 06 June 2014 06:27 Go to previous messageGo to next message
Hi Abel,
We contributed a few bug fixes to the most recent version of ECF, but I think we could work around those problems in
older versions. Please submit a bugzilla and I'll relax our constraints on the http components.
Please note that we've almost not tested Kepler compatibility, yet. If you encounter more trouble please let us know.
Cheers
/Eike
http://www.esc-net.de
Am 06.06.2014 11:24, schrieb Abel Hegedus:
> at
Re: Creating a Kepler based setup (httpclient 4.1 vs 4.2) [message #1385422 is a reply to message #1385420] Fri, 06 June 2014 06:37 Go to previous message
Thanks for the answer, bug submitted: https://bugs.eclipse.org/bugs/show_bug.cgi?id=436814
Previous Topic:[Announce] Breaking Changes to Catalog names
Next Topic:reusing setups/tasks
Current Time: Wed Jul 23 05:45:42 EDT 2025
Powered by FUDForum. Page generated in 0.08124 seconds
