Home » Eclipse Projects » EclipseLink » SessionCustomizer not used
SessionCustomizer not used [message #1385376] |
Thu, 05 June 2014 21:28  |
Hi all
I'm attempting to get a SessionCustomizer working, but it seems to mostly not get called when I'm performing actual queries.
I'm running EclipseLink 2.5.1 in Glassfish 4, using a JNDI data source of type OracleConnectionPoolDataSource. My persistence.xml looks like this:
<persistence xmlns-stuff-omitted-due-to-forum-thinking-its-a-link version="2.1">
<persistence-unit name="foo">
<jta-data-source>jdbc/FooDS</jta-data-source>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.session.customizer" value="com.foo.MySessionCustomizer"/>
</properties>
</persistence-unit>
</persistence>
My SessionCustomizer does get called once or twice during startup, but not when I run a query. My customizer replaces the connector with one which returns a wrapped connection object, but that connector never gets used at query time - sticking a breakpoint on JNDIConnector shows that the default connector is getting called directly.
My session customizer does this:
public class MySessionCustomizer implements SessionCustomizer {
public void customize(Session session) throws Exception {
session.getLogin().setConnector(new FooConnector(session.getLogin().getConnector()));
public class FooConnector implements Connector {
Connector target;
public FooConnector(Connector target) { this.target = target; }
public Connection connect(Properties properties, Session session) {
return new ConnectionWrapper(target.connect(properties, session));
So in theory when trying to obtain a connection EclipseLink should be calling the connector that I have configured, but it doesn't. The stacktrace from hitting the breakpoint in JNDIConnector show this code path:
Daemon Thread [http-listener-1(2)] (Suspended (breakpoint at line 95 in JNDIConnector))
owns: DatabaseAccessor (id=9822)
JNDIConnector.connect(Properties, Session) line: 95
DatabaseLogin(DatasourceLogin).connectToDatasource(Accessor, Session) line: 162
DatabaseAccessor(DatasourceAccessor).connectInternal(Login, AbstractSession) line: 346
DatabaseAccessor.connectInternal(Login, AbstractSession) line: 307
DatabaseAccessor(DatasourceAccessor).reconnect(AbstractSession) line: 581
DatabaseAccessor.reconnect(AbstractSession) line: 1625
DatabaseAccessor(DatasourceAccessor).incrementCallCount(AbstractSession) line: 321
DatabaseAccessor.basicExecuteCall(Call, AbstractRecord, AbstractSession, boolean) line: 613
DatabaseAccessor.executeCall(Call, AbstractRecord, AbstractSession) line: 558
ServerSession(AbstractSession).basicExecuteCall(Call, AbstractRecord, DatabaseQuery) line: 1991
ServerSession.executeCall(Call, AbstractRecord, DatabaseQuery) line: 570
ExpressionQueryMechanism(DatasourceCallQueryMechanism).executeCall(DatasourceCall) line: 242
ExpressionQueryMechanism(DatasourceCallQueryMechanism).executeCall() line: 228
ExpressionQueryMechanism(DatasourceCallQueryMechanism).executeSelectCall() line: 299
ExpressionQueryMechanism(DatasourceCallQueryMechanism).selectAllRows() line: 694
ExpressionQueryMechanism.selectAllRowsFromTable() line: 2738
ExpressionQueryMechanism.selectAllRows() line: 2691
ReadAllQuery.executeObjectLevelReadQuery() line: 495
ReadAllQuery(ObjectLevelReadQuery).executeDatabaseQuery() line: 1168
ReadAllQuery(DatabaseQuery).execute(AbstractSession, AbstractRecord) line: 899
ReadAllQuery(ObjectLevelReadQuery).execute(AbstractSession, AbstractRecord) line: 1127
ReadAllQuery.execute(AbstractSession, AbstractRecord) line: 403
ReadAllQuery(ObjectLevelReadQuery).executeInUnitOfWork(UnitOfWorkImpl, AbstractRecord) line: 1215
RepeatableWriteUnitOfWork(UnitOfWorkImpl).internalExecuteQuery(DatabaseQuery, AbstractRecord) line: 2896
RepeatableWriteUnitOfWork(AbstractSession).executeQuery(DatabaseQuery, AbstractRecord, int) line: 1793
RepeatableWriteUnitOfWork(AbstractSession).executeQuery(DatabaseQuery, AbstractRecord) line: 1775
RepeatableWriteUnitOfWork(AbstractSession).executeQuery(DatabaseQuery, List) line: 1740
EJBQueryImpl<X>(QueryImpl).executeReadQuery() line: 258
EJBQueryImpl<X>(QueryImpl).getResultList() line: 469
AuthorisationServiceImpl.getAll() line: 51
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 57
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 43
Method.invoke(Object, Object...) line: 606
EJBSecurityManager.runMethod(Method, Object, Object[]) line: 1081
EJBSecurityManager.invoke(Method, boolean, Object, Object[]) line: 1153
StatelessSessionContainer(BaseContainer).invokeBeanMethod(EjbInvocation) line: 4695
EjbInvocation.invokeBeanMethod() line: 630
AroundInvokeChainImpl.invokeNext(int, InterceptorManager$AroundInvokeContext) line: 822
EjbInvocation.proceed() line: 582
SessionBeanInterceptor(AbstractEJBRequestScopeActivationInterceptor).aroundInvoke(InvocationContext) line: 46
AroundInvokeInterceptor.intercept(InterceptorManager$AroundInvokeContext) line: 883
_SystemInterceptorProxy_Serializable(SystemInterceptorProxy).doCall(InvocationContext, Method) line: 163
_SystemInterceptorProxy_Serializable(SystemInterceptorProxy).aroundInvoke(InvocationContext) line: 140
InterceptorManager.intercept(InterceptorManager$InterceptorChain, InterceptorManager$AroundInvokeContext) line: 369
StatelessSessionContainer(BaseContainer).__intercept(EjbInvocation) line: 4667
StatelessSessionContainer(BaseContainer).intercept(EjbInvocation) line: 4655
EJBLocalObjectInvocationHandler.invoke(Class, Method, Object[]) line: 212
EJBLocalObjectInvocationHandlerDelegate.invoke(Object, Method, Object[]) line: 88
$Proxy284.getAll() line: not available
Licences.findLicences(UriInfo) line: 39
ResourceMethodInvocationHandlerFactory$1.invoke(Object, Method, Object[]) line: 81
JavaResourceMethodDispatcherProvider$TypeOutInvoker(AbstractJavaResourceMethodDispatcher).invoke(Object, Object...) line: 125
JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(Object, Request) line: 195
JavaResourceMethodDispatcherProvider$TypeOutInvoker(AbstractJavaResourceMethodDispatcher).dispatch(Object, Request) line: 91
ResourceMethodInvoker.invoke(ContainerRequest, Object) line: 346
ResourceMethodInvoker.apply(ContainerRequest) line: 341
ResourceMethodInvoker.apply(Object) line: 101
ServerRuntime$1.run() line: 224
Errors$1.call() line: 271
Errors$1.call() line: 267
Errors.process(Callable<T>, boolean) line: 315
Errors.process(Producer<T>, boolean) line: 297
Errors.process(Runnable) line: 267
RequestScope.runInScope(Runnable) line: 317
ServerRuntime.process(ContainerRequest) line: 198
ApplicationHandler.handle(ContainerRequest) line: 946
WebComponent.service(URI, URI, HttpServletRequest, HttpServletResponse) line: 323
ServletContainer.service(URI, URI, HttpServletRequest, HttpServletResponse) line: 372
ServletContainer.service(HttpServletRequest, HttpServletResponse) line: 335
ServletContainer.service(ServletRequest, ServletResponse) line: 218
StandardWrapper.service(ServletRequest, ServletResponse, Servlet) line: 1682
ApplicationFilterChain.internalDoFilter(ServletRequest, ServletResponse) line: 344
ApplicationFilterChain.doFilter(ServletRequest, ServletResponse) line: 214
ProfilingFilter.doFilter(ServletRequest, ServletResponse, FilterChain) line: 85
ApplicationFilterChain.internalDoFilter(ServletRequest, ServletResponse) line: 256
StandardWrapperValve.invoke(Request, Response) line: 316
StandardContextValve.invoke(Request, Response) line: 160
WebPipeline(StandardPipeline).doInvoke(Request, Response, boolean) line: 734
WebPipeline(StandardPipeline).invoke(Request, Response) line: 673
WebPipeline.invoke(Request, Response) line: 99
StandardHostValve.invoke(Request, Response) line: 174
CoyoteAdapter.doService(Request, Request, Response, Response, boolean) line: 357
CoyoteAdapter.service(Request, Response) line: 260
ContainerMapper.service(Request, Response) line: 188
ContainerMapper(HttpHandler).runService(Request, Response) line: 191
ContainerMapper(HttpHandler).doHandle(Request, Response) line: 168
HttpServerFilter.handleRead(FilterChainContext) line: 189
ExecutorResolver$9.execute(Filter, FilterChainContext) line: 119
DefaultFilterChain.executeFilter(FilterExecutor, Filter, FilterChainContext) line: 288
DefaultFilterChain.executeChainPart(FilterChainContext, FilterExecutor, int, int, DefaultFilterChain$FiltersState) line: 206
DefaultFilterChain.execute(FilterChainContext) line: 136
DefaultFilterChain.process(Context) line: 114
ProcessorExecutor.execute(Context) line: 77
TCPNIOTransport.fireIOEvent(IOEvent, Connection, IOEventProcessingHandler) line: 838
AbstractIOStrategy.fireIOEvent(Connection, IOEvent, IOEventProcessingHandler, Logger) line: 113
WorkerThreadIOStrategy.run0(Connection, IOEvent, IOEventProcessingHandler) line: 115
WorkerThreadIOStrategy.access$100(Connection, IOEvent, IOEventProcessingHandler) line: 55
WorkerThreadIOStrategy$WorkerThreadRunnable.run() line: 135
FixedThreadPool$BasicWorker(AbstractThreadPool$Worker).doWork() line: 564
FixedThreadPool$BasicWorker(AbstractThreadPool$Worker).run() line: 544
DefaultWorkerThread(Thread).run() line: 744
I really just want the equivalent of the Hibernate ConnectionProvider interface (can't link to it as I have less than 5 posts, it's google-able). It seemed like replacing the connector in a session customizer was the way to do it, but the new connector just doesn't get used.
Any suggestions?
Tom
Current Time: Sat Jul 26 13:22:20 EDT 2025
Powered by FUDForum. Page generated in 0.12572 seconds
