Home » Modeling » Graphiti » Selection Behavior problems
Selection Behavior problems [message #1385365] Thu, 05 June 2014 16:27 Go to next message
Hi all,
I've a shape like this:
- invisible rectangle
- ellipse
- text
I want only the ellipse and text to be clickable. Following your tutorial http://help.eclipse.org/juno/topic/org.eclipse.graphiti.doc/resources/docu/gfw/selection-behavior.htm?cp=30_1_4_6 I've override the method getClickArea as below (this is just a test):
	public GraphicsAlgorithm[] getClickArea(PictogramElement pe) {
		if (pe instanceof ContainerShape) {
			GraphicsAlgorithm[] graphicsAlgorithmsList = new GraphicsAlgorithm[100];
			int i =0;
			for (Shape shape : ((ContainerShape) pe).getChildren()) {
				if(shape.getGraphicsAlgorithm().getLineVisible()){
				graphicsAlgorithmsList[i++]=shape.getGraphicsAlgorithm();
		return graphicsAlgorithmsList;
		return super.getClickArea(pe);
but even if this return the ellipse and text, I can still click on the invisible rectangle.
What I am doing wrong here?
Thanks for your help
Simone
Re: Selection Behavior problems [message #1385826 is a reply to message #1385365] Wed, 11 June 2014 08:31 Go to previous messageGo to next message
Simone,
have you checked if your coding is called at all? E.g. the method will only
be called for active shapes.
Michael
Re: Selection Behavior problems [message #1386445 is a reply to message #1385826] Tue, 17 June 2014 11:24 Go to previous message
Yes, I've cheked it.
Previous Topic:Complicated Shapes & Member Access
Next Topic:System in Cloud Modeler 0.1.0
Current Time: Thu Jul 24 23:40:46 EDT 2025
Powered by FUDForum. Page generated in 0.07019 seconds
