Home » Modeling » Graphiti » Possible bug with BoxRelativeAnchor
Possible bug with BoxRelativeAnchor [message #1385329] Thu, 05 June 2014 12:22 Go to next message
Hi all,
I think there is a bug within the class CreateConnectionCommand, package org.eclipse.graphiti.ui.internal.command
In particular, having a shape with a BoxRelativeAnchor, every time I click on it in order to drag and drop a connection without using the palette, the connectionContext contains the following info:
CreateConnectionContext sourceAnchor: org.eclipse.graphiti.mm.pictograms.impl.BoxRelativeAnchorImpl@85091a (visible: true, active: true) (useAnchorLocationAsConnectionEndpoint: false) (relativeWidth: 0.5, relativeHeight: 1.0) targetAnchor: null sourcePictogramElement: org.eclipse.graphiti.mm.pictograms.impl.BoxRelativeAnchorImpl@85091a (visible: true, active: true) (useAnchorLocationAsConnectionEndpoint: false) (relativeWidth: 0.5, relativeHeight: 1.0)
in paricular what is wrong is the sourcePictogramElement section. Indeed, it should be the AnchorContainer, and not the anchor itself.
Finally, the method
public boolean canStartConnection() {
		// allow connections only from anchor to anchor
		CreateConnectionContext connectionContext = createContext();
		sourceLocation = connectionContext.getSourceLocation(); // store
																// location for
																// later usage
		for (IFeature feature : features) {
			if (feature instanceof ICreateConnectionFeature) {
				ICreateConnectionFeature ccf = (ICreateConnectionFeature) feature;
				if (ccf.canStartConnection(connectionContext)) {
					return true;
			} else
				return true;
		return false;
when it tries to call anStartConnection(connectionContext) always retrun false (correct).
Am I missing something, or is this a bug?
Simone
Re: Possible bug with BoxRelativeAnchor [message #1385330 is a reply to message #1385329] Thu, 05 June 2014 12:29 Go to previous messageGo to next message
In particular, I think the problem can be easily solved modifing the constructor:
	 * Instantiate a command that can create a connection between two anchors.
	 * @param source
	 *            the source endpoint (a non-null Shape instance)
	 * @param lineStyle
	 *            the desired line style. See Connection#setLineStyle(int) for
	 *            details
	 * @throws IllegalArgumentException
	 *             if source is null
	 * @see Connection#setLineStyle(int)
	public CreateConnectionCommand(IConfigurationProvider configurationProvider, PictogramElement pe,
			List<IFeature> features) {
		super(configurationProvider);
		setLabel(Messages.CreateConnectionCommand_0_xmsg);
		this.features = features;
		this.sourceObject = pe;  //<------- FIX HERE
Indeed, pe can be even a BoxRelativeAnchor, and since it is a PictogramElement there are no problems for Java (but a lot for me Smile )
Re: Possible bug with BoxRelativeAnchor [message #1385820 is a reply to message #1385329] Wed, 11 June 2014 08:02 Go to previous message
Simone,
not sure...
What does the metod createContext() do? It seems to fill the
connectionContext you are using afterwards. And what are the features list
you are looping over?
Usually I would have expected that the create connection context passed to
the canStartConnection method should contain the necessary information, e.g.
the shape you can start to search for the anchor to use.
Michael
Previous Topic:[Spray] Problem with anchors
Next Topic:Draw Matrix in Graphiti
Current Time: Sun Jul 27 14:41:54 EDT 2025
Powered by FUDForum. Page generated in 0.03839 seconds
