Home » Modeling » TMF (Xtext) » Adding Property to EMF Objects Dynamically(Adding Property to EMF Objects Dynamically)
Adding Property to EMF Objects Dynamically [message #1385051] Tue, 03 June 2014 22:13 Go to next message
I want to add a property to EMF Object Dynamically for eg, if we have a grammar below :
Model:
greetings+=Greeting*;
Greeting:
'Hello' name=ID '!';
After EMF classes is generated, I want to add another property lets say greetingID to
Greeting Class at runtime. Is there any way to do achieve this ?
Cheers
Kunal
Re: Adding Property to EMF Objects Dynamically [message #1385053 is a reply to message #1385051] Wed, 04 June 2014 00:26 Go to previous messageGo to next message
http://christiandietrich.wordpress.com/2011/07/22/customizing-xtext-met
amodel-inference-using-xtend2/
Re: Adding Property to EMF Objects Dynamically [message #1385054 is a reply to message #1385051] Wed, 04 June 2014 00:35 Go to previous messageGo to next message
P.s. and for actually setting it you could use iderivedstatecomputer
BTW what is your actual/real usecase
Re: Adding Property to EMF Objects Dynamically [message #1385055 is a reply to message #1385054] Wed, 04 June 2014 01:02 Go to previous messageGo to next message
Hi Christian,
Thanks for the reply. My Actual/Real Use Case is I want to assign a property Id to each of my EMF Classes and that property should not be part of grammar ie it should not be displayed in Xtext editor . In other sense, I want a variable in Xtext Grammar and it should not be accessible in Xtext Editor but it can be accessed via generated EMF Classes.
Cheers
Kunal
Re: Adding Property to EMF Objects Dynamically [message #1385064 is a reply to message #1385055] Wed, 04 June 2014 03:12 Go to previous messageGo to next message
On 04/06/2014 07:02, Kunal Khaware wrote:
> Hi Christian,
> Classes.
you need to swtich to a custom Ecore first (see, e.g.,
http://www.lorenzobettini.it/2014/02/switching-from-an-inferred-ecore-model-to-an-imported-one-in-your-xtext-grammar/
) and then you can add the additional field as "transient" so that it
won't be serialized when you save the file (it won't be shown in the
editor either).
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Adding Property to EMF Objects Dynamically [message #1385088 is a reply to message #1385064] Wed, 04 June 2014 05:34 Go to previous message
the postprocessor can do the very same
Previous Topic:General scoping question regarding cross references
Next Topic:JvmModelInferrer and debug: skip steps?
Current Time: Sat Jul 26 23:29:01 EDT 2025
Powered by FUDForum. Page generated in 0.03508 seconds
