Seemingly random errors generating gmfgen [message #1384740] |
Fri, 30 May 2014 21:21  |
I am using Kepler SR2 (20140224-0627) and GMF Tooling
3.1.0.201403031044. Whenever I go to generate my gmfgen file I get an
error message in the form of:
Ambiguous definitions Runtime::fqn FOR ...
for example:
Ambiguous definitions Runtime::fqn FOR gmfgraph::XYLayout and
Runtime::fqn FOR gmfgraph::Ellipse:in Runtime
BTW none of my ellipse figures have an XYLayout! If I make a change to
my gmfgraph file e.g. change the layout my ellipse is using then the
error message changes to be a different message in the same format. e.g.
Ambiguous definitions Runtime::fqn FOR gmfgraph::CustomLayout and
Runtime::fqn FOR gmfgraph::FlowLayout:in Runtime
If I restore the change I just made, i.e. I put everything back to how
it was I get yet another error in this format but again a different message!
Ambiguous definitions Runtime::fqn FOR gmfgraph::RoundedRectangle and
Runtime::fqn FOR gmfgraph::Label:in Runtime
Any suggestions as to what the heck is wrong are welcome!
Nigel
BTW. The full stack trace and my environment is as follows:
org.eclipse.gmf.internal.xpand.model.EvaluationException: Ambiguous
definitions Runtime::fqn FOR gmfgraph::RoundedRectangle and Runtime::fqn
at
org.eclipse.gmf.graphdef.codegen.FigureGenerator.fqnSwitch(FigureGenerator.java:87)
at
org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.createViewmap(InnerClassViewmapProducer.java:140)
at
org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.create(InnerClassViewmapProducer.java:99)
at
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.createNodeLabel(DiagramGenModelTransformer.java:674)
at
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.processAbstractNode(DiagramGenModelTransformer.java:583)
at
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.createGenChildNode(DiagramGenModelTransformer.java:538)
at
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.process(DiagramGenModelTransformer.java:448)
at
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.processAbstractNode(DiagramGenModelTransformer.java:580)
at
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.process(DiagramGenModelTransformer.java:417)
at
org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer.transform(MappingTransformer.java:31)
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation$2.process(TransformToGenModelOperation.java:442)
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation.executeTransformation(TransformToGenModelOperation.java:272)
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenModelWizard$1.run(TransformToGenModelWizard.java:168)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenModelWizard.performFinish(TransformToGenModelWizard.java:171)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:628)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4166)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1489)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1474)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3651)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
at org.eclipse.jface.window.Window.open(Window.java:802)
at
org.eclipse.gmf.internal.bridge.transform.TransformToGenModelAction.run(TransformToGenModelAction.java:72)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.7.0_40
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product
-keyring /Users/Nigel/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product
org.eclipse.epp.package.modeling.product -keyring
Re: Seemingly random errors generating gmfgen [message #1385484 is a reply to message #1384861] |
Fri, 06 June 2014 15:46  |
this was finally tracked down to an empty reference in the gmfgraph
for a child reference for a label, fixing that prevented all of the
random errors. Is there likely to be any improvement to the error
messages, their appearance denoted something was wrong but none of the
random ones I got helped to identity the cause :(
regards,
Nigel
On 02/06/2014 08:19, Nigel Daniels wrote:
> Further, this symptom seems to have nothing to do with my gmfgraph or
> gmfmap files. Whenever I click finish on the gmfgen wizard I get a
> different error message in this format.
> On 30/05/2014 18:21, Nigel Daniels wrote:
>> Hi,
>> for example:
>> message!
>> and Runtime::fqn FOR gmfgraph::Label:in Runtime
>> Nigel
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> java.vendor=Oracle Corporation
FUDForum. Page generated in 0.07640 seconds
