Trying to get org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter to work [message #1359675] |
Fri, 16 May 2014 08:52  |
I notice very few posts to this forum get answered. I used CDO and Teneo were the developers are heros in their support. It is not like we have a choice using PDE if we want to build plugins...
I follow the PDE documentation, which is extensive, but still do not get the expected result, so short of asking here I will have to trace through the PDE code to find the problem.
We have a single build.xml that builds several products based on target selection. One of these uses AspectJ, so needs org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter. I reproduce the relevant parts of the build.xml
<pde run="-buildfile ${eclipse.pdebuild.scripts}/productBuild/productBuild.xml
-Dproduct=/com.yambina.edm.ui/EDMUI.product -DcompilerAdapter=org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter -DsourceFileExtensions=*.java, *.aj " name="EDMUI" />
The macro
<macrodef name="pde">
<attribute name="run" />
<attribute name="name" />
<sequential>
<java classname="org.eclipse.equinox.launcher.Main" fork="true" failonerror="true">
<classpath>
<fileset dir="${eclipse.home}/plugins/">
<include name="org.eclipse.equinox.launcher_*.jar" />
</fileset>
</classpath>
<arg line="-application org.eclipse.ant.core.antRunner" />
<arg line="@{run}" />
<arg line="-DarchivePrefix=@{name}" />
<arg line="-DarchiveNamePrefix=@{name}" />
<arg line="-Dconfigs=${configs}" />
<arg line="-Dbuilder=${builder}" />
<arg line="-DbuildDirectory=${buildDirectory}" />
<arg line="-DbaseLocation=${baseLocation}" />
<arg line="-DpluginPath=${pluginPath}" />
<arg line="-DskipBase=true" />
<arg line="-DskipMaps=true" />
<arg line="-DskipFetch=true" />
<arg line="-DbuildLabel=@{name}" />
<arg line="-DcollectingFolder=@{name}" />
<arg line="-DjavacSource=${javacSource}" />
<arg line="-DjavacTarget=${javacTarget}" />
<arg line="-DjavacFailOnError=true" />
<arg line="-DallowBinaryCycles=true" />
<arg line="-DrunPackager=true" />
</java>
</sequential>
</macrodef>
I read this http://contraptionsforprogramming.blogspot.co.uk/2010/03/ajdt-pde-builds-redux.html and this http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.pde.doc.user%2Ftasks%2Fpde_compiler_options.htm
The .aj files are in the same directory as the java files so assume I do not need to specify an aspectpath. The output I get from ant is
build.EDMUI:
[java] Starting Groovy-Eclipse compiler resolver. Specified compiler level: 2.0
[java] Unknown target: *.aj
[java] BUILD SUCCESSFUL
[java] Total time: 0 seconds
[java] No known target specified.
Note the "Unknown target: *.aj" which suggests the "-DcompilerAdapter=org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter -DsourceFileExtensions=*.java, *.aj" are not getting picked up?
Thank you.
David
[Updated on: Fri, 16 May 2014 09:11] by Moderator
Re: Trying to get org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter to work [message #1359975 is a reply to message #1359675] |
Fri, 16 May 2014 11:49   |
Thought I'd test with cmd line first, using this
java -cp /Users/david/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar org.eclipse.equinox.launcher.Main -Dbuildfile=/Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/productBuild/productBuild.xml -DarchivePrefix=EDMUI -DarchiveNamePrefix=EDMUI -Dproduct=/com.yambina.edm.ui/EDMUI.product -DcompilerAdapter=org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter -DsourceFileExtensions="*.java, *.aj" -Dconfigs=macosx,cocoa,x86_64 -Dbuilder=/Users/david/workspace/edmbuild/builds -DbuildDirectory=/Users/david/workspace/edmbuild/build -DbaseLocation=/Users/david/eclipse -DpluginPath=/Users/david/eclipse/deltapack/eclipse -DskipBase=true -DskipMaps=true -DskipFetch=true -DbuildLabel=EDMUI -DcollectingFolder=EDMUI -DjavacSource=1.7 -DjavacTarget=1.7 -DjavacFailOnError=true -DallowBinaryCycles=true -DrunPackager=true
I get this
!SESSION 2014-05-16 15:23:28.160 -----------------------------------------------
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.7.0_25
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -Dbuildfile=/Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/productBuild/productBuild.xml -DarchivePrefix=EDMUI -DarchiveNamePrefix=EDMUI -Dproduct=/com.yambina.edm.ui/EDMUI.product -DcompilerAdapter=org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter -DsourceFileExtensions=*.java, *.aj -Dconfigs=macosx,cocoa,x86_64 -Dbuilder=/Users/david/workspace/edmbuild/builds -DbuildDirectory=/Users/david/workspace/edmbuild/build -DbaseLocation=/Users/david/eclipse -DpluginPath=/Users/david/eclipse/deltapack/eclipse -DskipBase=true -DskipMaps=true -DskipFetch=true -DbuildLabel=EDMUI -DcollectingFolder=EDMUI -DjavacSource=1.7 -DjavacTarget=1.7 -DjavacFailOnError=true -DallowBinaryCycles=true -DrunPackager=true
Command-line arguments: -Dbuildfile=/Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/productBuild/productBuild.xml -DarchivePrefix=EDMUI -DarchiveNamePrefix=EDMUI -Dproduct=/com.yambina.edm.ui/EDMUI.product -DcompilerAdapter=org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter -DsourceFileExtensions=*.java, *.aj -Dconfigs=macosx,cocoa,x86_64 -Dbuilder=/Users/david/workspace/edmbuild/builds -DbuildDirectory=/Users/david/workspace/edmbuild/build -DbaseLocation=/Users/david/eclipse -DpluginPath=/Users/david/eclipse/deltapack/eclipse -DskipBase=true -DskipMaps=true -DskipFetch=true -DbuildLabel=EDMUI -DcollectingFolder=EDMUI -DjavacSource=1.7 -DjavacTarget=1.7 -DjavacFailOnError=true -DallowBinaryCycles=true -DrunPackager=true
!ENTRY org.eclipse.osgi 2 0 2014-05-16 15:23:34.201
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-16 15:23:34.201
!MESSAGE Bundle org.eclipse.equinox.weaving.hook_1.0.200.v20120524-1707 [653] was not resolved.
!MESSAGE Bundle org.eclipse.equinox.weaving.hook_1.0.200.I20130319-1000 [654] was not resolved.
!ENTRY org.eclipse.osgi 4 0 2014-05-16 15:23:34.202
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4397)
Plenty of info on this error, put the weaving hook fragments into the same directory as the osgi - the last point here - http://www.eclipse.org/forums/index.php/t/202705/
should do it, but not clear were my workspace is in the context of the above command line? Any pointers?
Thx.
David
[Updated on: Fri, 16 May 2014 11:49] by Moderator
Re: Trying to get org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter to work [message #1369502 is a reply to message #1369458] |
Tue, 20 May 2014 12:14   |
Tried that too. I realise these properties apply to all my target builds, but in fact did not make a difference to my Java only builds.
I get
[java] [javac] 1564. WARNING in /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/src/main/aspects/com/yambina/edm/edmui/drools/eclipse/aspects/ResourceTracker.java (at line 49)
[java] [javac] final IFile newFile = ResourcesPlugin.getWorkspace().getRoot().getFile(delta.getMovedToPath());
[java] [javac] ^^^^^^^
[java] [javac] The value of the local variable newFile is not used
[java] [javac] ----------
[java] [javac] 1565. ERROR in /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/src/main/aspects/com/yambina/edm/edmui/drools/eclipse/aspects/ResourceTracker.java (at line 54)
[java] [javac] ResourceTracker.this.editor.setInput(newFile);
[java] [javac] ^^^^^^^^
[java] [javac] The method setInput(IEditorInput) in the type BPMNModelEditor is not applicable for the arguments (IFile)
[java] [javac] 1566. WARNING in /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/src/main/aspects/com/yambina/edm/edmui/drools/eclipse/aspects/ResourceTracker.java (at line 60)
[java] [javac] final IFile newFile = ResourcesPlugin.getWorkspace().getRoot().getFile(delta.getFullPath());
[java] [javac] 1567. ERROR in /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/src/main/aspects/com/yambina/edm/edmui/drools/eclipse/aspects/ResourceTracker.java (at line 64)
[java] [javac] 1568. WARNING in /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/src/main/aspects/com/yambina/edm/edmui/drools/eclipse/aspects/WorkItemDefinitionLoader.java (at line 54)
[java] [javac] List<Map<String, Object>> workDefinitionsMap = (List<Map<String, Object>>) MVEL.eval(content, new HashMap());
[java] [javac] HashMap is a raw type. References to generic type HashMap<K,V> should be parameterized
[java] [javac] 1568 problems (2 errors, 1566 warnings)
[java] [javac] Compilation failed. Compiler errors are available in /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/@dot.log
[java] BUILD FAILED
[java] /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/productBuild/productBuild.xml:43: The following error occurred while executing this line:
[java] /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/build.xml:105: The following error occurred while executing this line:
[java] /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/templates/headless-build/customTargets.xml:12: The following error occurred while executing this line:
[java] /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/productBuild/allElements.xml:20: The following error occurred while executing this line:
[java] /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/genericTargets.xml:118: The following error occurred while executing this line:
[java] /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/genericTargets.xml:123: The following error occurred while executing this line:
[java] /Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature/build.xml:139: The following error occurred while executing this line:
[java] /Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature/build.xml:94: The following error occurred while executing this line:
[java] /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/build.xml:1148: The following error occurred while executing this line:
[java] /Users/david/workspace/edmbuild/plugins/org.drools.eclipse-5.2.0.Final/build.xml:1076: Compile failed; see the compiler error output for details.
[java] Total time: 33 seconds
[java] An error has occurred. See the log file
[java] /Users/david/Documents/workspace/.metadata/.log.
Now I see this error when I start Eclipse and try to build the same project using the IDE, it occurs in the plugin that uses AspectJ. I solve it in the IDE builds simply by doing a clean project for just that plugin that uses AspectJ each time, then it seems to "see" ajdt and builds fine.
[Updated on: Tue, 20 May 2014 12:14] by Moderator
Re: Trying to get org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter to work [message #1384686 is a reply to message #1384628] |
Fri, 30 May 2014 07:13   |
Andrew,
There is a directory called "/Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/@dot" but no file by the name of "/Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/@dot.log" created.
here is .log
!SESSION 2014-05-30 12:07:24.918 -----------------------------------------------
Framework arguments: -application org.eclipse.ant.core.antRunner -buildfile /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts///productBuild/productBuild.xml -Dproduct=/com.yambina.edm.ui/EDMUI.product -DarchivePrefix=EDMUI -DarchiveNamePrefix=EDMUI -Dconfigs=macosx,cocoa,x86_64 -Dbuilder=/Users/david/git/EDM/builds/../builds -DbuildDirectory=/Users/david/workspace/edmbuild/build -DbaseLocation=/Users/david/eclipse -DpluginPath=/Users/david/workspace/edmbuild:/Users/david/eclipse/deltapack/eclipse -DskipBase=true -DskipMaps=true -DskipFetch=true -DbuildLabel=EDMUI -DcollectingFolder=EDMUI -DjavacSource=1.7 -DjavacTarget=1.7 -DjavacFailOnError=true -DallowBinaryCycles=true -DrunPackager=true
Command-line arguments: -application org.eclipse.ant.core.antRunner -buildfile /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts///productBuild/productBuild.xml -Dproduct=/com.yambina.edm.ui/EDMUI.product -DarchivePrefix=EDMUI -DarchiveNamePrefix=EDMUI -Dconfigs=macosx,cocoa,x86_64 -Dbuilder=/Users/david/git/EDM/builds/../builds -DbuildDirectory=/Users/david/workspace/edmbuild/build -DbaseLocation=/Users/david/eclipse -DpluginPath=/Users/david/workspace/edmbuild:/Users/david/eclipse/deltapack/eclipse -DskipBase=true -DskipMaps=true -DskipFetch=true -DbuildLabel=EDMUI -DcollectingFolder=EDMUI -DjavacSource=1.7 -DjavacTarget=1.7 -DjavacFailOnError=true -DallowBinaryCycles=true -DrunPackager=true
!ENTRY org.eclipse.osgi 2 0 2014-05-30 12:07:46.833
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-30 12:07:46.833
!ENTRY org.eclipse.osgi 4 0 2014-05-30 12:07:46.834
!STACK 1
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:513)
at org.eclipse.ant.core.AntRunner.start(AntRunner.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/productBuild/productBuild.xml:43: The following error occurred while executing this line:
/Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature/build.xml:19: The following error occurred while executing this line:
/Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/build.xml:152: The following error occurred while executing this line:
/Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/build.xml:113: Compile failed; see the compiler error output for details.
at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:551)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:444)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:392)
at org.apache.tools.ant.Target.performTasks(Target.java:413)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:672)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:537)
... 19 more
Caused by: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/build.xml:105: The following error occurred while executing this line:
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
at org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor.executeTargets(EclipseSingleCheckExecutor.java:30)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:442)
... 35 more
Caused by: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/templates/headless-build/customTargets.xml:12: The following error occurred while executing this line:
... 48 more
Caused by: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/productBuild/allElements.xml:20: The following error occurred while executing this line:
... 62 more
Caused by: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/genericTargets.xml:118: The following error occurred while executing this line:
... 75 more
Caused by: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts/genericTargets.xml:123: The following error occurred while executing this line:
... 89 more
Caused by: /Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature/build.xml:139: The following error occurred while executing this line:
... 102 more
Caused by: /Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature/build.xml:19: The following error occurred while executing this line:
... 116 more
Caused by: /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/build.xml:152: The following error occurred while executing this line:
... 129 more
Caused by: /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/build.xml:113: Compile failed; see the compiler error output for details.
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:1174)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:930)
... 143 more
Root exception:
... 35 more
... 48 more
... 62 more
... 75 more
... 89 more
... 102 more
... 116 more
... 129 more
... 143 more
But cannot see the compiler error output anywhere?
The console output looks like this:
build.EDMUI:
[java] Buildfile: /Users/david/eclipse/plugins/org.eclipse.pde.build_3.8.100.v20130514-1028/scripts///productBuild/productBuild.xml
[java] main:
[java] preBuild:
[java] preSetup:
[java] checkLocalMaps:
[java] getMapFiles:
[java] postSetup:
[java] checkLocalBase:
[java] getBaseComponents:
[java] processRepos:
[java] generateFeature:
[java] fetch:
[java] [eclipse.generateFeature] Some inter-plug-in dependencies have not been satisfied.
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.macosx:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.core.filesystem.macosx_1.3.0.v20100505-2103
[java] [eclipse.generateFeature] Bundle org.eclipse.e4.ui.workbench.renderers.swt.cocoa:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.e4.ui.workbench.renderers.swt.cocoa_0.11.100.v20130516-1100
[java] [eclipse.generateFeature] Bundle org.eclipse.equinox.launcher.cocoa.macosx.x86_64:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.200.v20140116-2212
[java] [eclipse.generateFeature] Bundle org.eclipse.equinox.security.macosx:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.equinox.security.macosx_1.100.200.v20130327-1442
[java] [eclipse.generateFeature] Bundle org.eclipse.jdt.launching.macosx:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.jdt.launching.macosx_3.2.200.v20130514-1246
[java] [eclipse.generateFeature] Bundle org.eclipse.jdt.launching.ui.macosx:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.jdt.launching.ui.macosx_1.0.200.v20130402-1743
[java] [eclipse.generateFeature] Bundle org.eclipse.swt.cocoa.macosx.x86_64:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.swt.cocoa.macosx.x86_64_3.102.1.v20140206-1358
[java] [eclipse.generateFeature] Host plug-in null_0.0.0 has not been found.
[java] [eclipse.generateFeature] Bundle org.aspectj.ajde:
[java] [eclipse.generateFeature] Another singleton version selected: org.aspectj.ajde_1.7.3.20130613144500-a
[java] [eclipse.generateFeature] Bundle org.eclipse.ajdt.core:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.ajdt.core_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.ajdt.ui:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.ajdt.ui_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.aspectj:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.aspectj_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.contribution.visualiser:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.contribution.visualiser_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.contribution.weaving.jdt:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.contribution.weaving.jdt_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.contribution.xref.core:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.contribution.xref.core_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.contribution.xref.ui:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.contribution.xref.ui_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.generateFeature] Bundle org.eclipse.equinox.weaving.hook:
[java] [eclipse.generateFeature] Bundle org.eclipse.update.core:
[java] [eclipse.generateFeature] Another singleton version selected: org.eclipse.update.core_3.2.600.v20140203-1328
[java] generate:
[java] preGenerate:
[java] allElements:
[java] allElementsDelegator:
[java] init:
[java] generateScript:
[java] [eclipse.buildScript] Some inter-plug-in dependencies have not been satisfied.
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.macosx:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.core.filesystem.macosx_1.3.0.v20100505-2103
[java] [eclipse.buildScript] Bundle org.eclipse.e4.ui.workbench.renderers.swt.cocoa:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.e4.ui.workbench.renderers.swt.cocoa_0.11.100.v20130516-1100
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.launcher.cocoa.macosx.x86_64:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.200.v20140116-2212
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.security.macosx:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.equinox.security.macosx_1.100.200.v20130327-1442
[java] [eclipse.buildScript] Bundle org.eclipse.jdt.launching.macosx:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.jdt.launching.macosx_3.2.200.v20130514-1246
[java] [eclipse.buildScript] Bundle org.eclipse.jdt.launching.ui.macosx:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.jdt.launching.ui.macosx_1.0.200.v20130402-1743
[java] [eclipse.buildScript] Bundle org.eclipse.swt.cocoa.macosx.x86_64:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.swt.cocoa.macosx.x86_64_3.102.1.v20140206-1358
[java] [eclipse.buildScript] Host plug-in null_0.0.0 has not been found.
[java] [eclipse.buildScript] Bundle org.aspectj.ajde:
[java] [eclipse.buildScript] Another singleton version selected: org.aspectj.ajde_1.7.3.20130613144500-a
[java] [eclipse.buildScript] Bundle org.eclipse.ajdt.core:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.ajdt.core_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.ajdt.ui:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.ajdt.ui_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.aspectj:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.aspectj_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.contribution.visualiser:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.contribution.visualiser_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.contribution.weaving.jdt:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.contribution.weaving.jdt_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.contribution.xref.core:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.contribution.xref.core_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.contribution.xref.ui:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.contribution.xref.ui_2.2.3.e43x-RELEASE-20130627-0800
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.weaving.hook:
[java] [eclipse.buildScript] Bundle org.eclipse.update.core:
[java] [eclipse.buildScript] Another singleton version selected: org.eclipse.update.core_3.2.600.v20140203-1328
[java] postGenerate:
[java] clean:
[java] allElements:
[java] init:
[java] cleanElement:
[java] [echo] /Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature
[java] init:
[java] clean:
[java] init:
[java] all.features:
[java] init:
[java] clean:
[java] all.plugins:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] properties:
[java] init:
[java] clean:
[java] [delete] Deleting directory /Users/david/workspace/edmbuild/plugins/com.yambina.edm.ui/@dot
[java] properties:
[java] init:
[java] clean:
[java] update.feature:
[java] all.children:
[java] process:
[java] preProcess:
[java] allElements:
[java] init:
[java] processElement:
[java] processViaFeature:
[java] init:
[java] build.jars:
[java] init:
[java] init:
[java] build.jars:
[java] all.plugins:
[java] properties:
[java] init:
[java] build.jars:
[java] properties:
[java] init:
[java] build.jars:
[java] properties:
[java] init:
[java] @dot.nestedJars:
[java] @dot:
[java] [mkdir] Created dir: /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/@dot
[java] [javac] Compiling 1 source file to /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/@dot
[java] [javac] Unrecognized option : org.eclipse.ajdt.core.ant.AJDT_AjcCompilerAdapter
[java] [javac] Compilation failed. Compiler errors are available in /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/@dot.log
[java] BUILD FAILED
[java] /Users/david/workspace/edmbuild/build/features/org.eclipse.pde.build.container.feature/build.xml:19: The following error occurred while executing this line:
[java] /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/build.xml:152: The following error occurred while executing this line:
[java] /Users/david/workspace/edmbuild/plugins/com.yambina.log4j.cfg/build.xml:113: Compile failed; see the compiler error output for details.
[java] Total time: 14 seconds
BUILD FAILED
/Users/david/git/EDM/builds/build.xml:117: The following error occurred while executing this line:
/Users/david/git/EDM/builds/build.xml:626: Java returned: 13
Total time: 38 seconds
[Updated on: Fri, 30 May 2014 07:15] by Moderator
FUDForum. Page generated in 0.31566 seconds
