Home » Language IDEs » ServerTools (WTP) » Why my added libraries are automatically removed from "Java Build Path" in Eclipse? (Build Path Libraries Issue)
Why my added libraries are automatically removed from "Java Build Path" in Eclipse? [message #1384524] Thu, 29 May 2014 03:52 Go to next message
I am working on a Web Application;
I added libraries to my project via "Java Build Path" Application is running perfectly but when I made changes to my .jsp file and refreshed the the page on Browser;
the added libraries automatically removed.
Now how can fix it??? i am using apache-tomcat-7.0.37.
as every time I update my .jsp file or make any other changes I need to add the libraries again.
Any advice or suggestion would be highly appreciable. Thank you!
Re: Why my added libraries are automatically removed from "Java Build Path" in Eclipse? [message #1384603 is a reply to message #1384524] Thu, 29 May 2014 08:56 Go to previous messageGo to next message
Moving this to the Web Tools forum.
Re: Why my added libraries are automatically removed from "Java Build Path" in Eclipse? [message #1384620 is a reply to message #1384603] Thu, 29 May 2014 11:54 Go to previous messageGo to next message
Looks like it was also asked at http://stackoverflow.com/questions/23926925/why-my-added-libraries-are-automatically-removed-from-java-build-path-in-eclip?noredirect=1#comment36852228_23926925 .
Re: Why my added libraries are automatically removed from "Java Build Path" in Eclipse? [message #1384632 is a reply to message #1384620] Thu, 29 May 2014 15:07 Go to previous messageGo to next message
Yes, I posted it there too; and if I m nt wrong u r the same Nitind.
Re: Why my added libraries are automatically removed from "Java Build Path" in Eclipse? [message #1384751 is a reply to message #1384632] Sat, 31 May 2014 05:16 Go to previous messageGo to next message
Solution please???
Re: Why my added libraries are automatically removed from "Java Build Path" in Ecl [message #1384836 is a reply to message #1384751] Mon, 02 June 2014 08:55 Go to previous messageGo to next message
On 5/31/2014 5:16 AM, Sana Shaikh wrote:
> Solution please???
What is the contents of the .classpath file in your project. That might
provide some clues or provide help in determining the next questions to ask?
Larry
Re: Why my added libraries are automatically removed from "Java Build Path" in Ecl [message #1384909 is a reply to message #1384836] Tue, 03 June 2014 00:20 Go to previous messageGo to next message
Well, .classpath file doe not contain anything odd, contents:
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry kind="lib" path="lib/mysql-connector-java-3.1.14-bin.jar"/>
<classpathentry kind="lib" path="lib/antlr-2.7.6.jar"/>
<classpathentry kind="lib" path="lib/commons-collections-3.1.jar"/>
<classpathentry kind="lib" path="lib/commons-logging-api-1.1.jar"/>
<classpathentry kind="lib" path="lib/ejb3-persistence.jar"/>
<classpathentry kind="lib" path="lib/hibernate3.jar"/>
<classpathentry kind="lib" path="lib/hibernate-annotations.jar"/>
<classpathentry kind="lib" path="lib/hibernate-commons-annotations.jar"/>
<classpathentry kind="lib" path="lib/hibernate-search.jar"/>
<classpathentry kind="lib" path="lib/javassist-3.4.GA.jar"/>
<classpathentry kind="lib" path="lib/jta.jar"/>
<classpathentry kind="lib" path="lib/log4j-1.2.15.jar"/>
<classpathentry kind="lib" path="lib/slf4j-api-1.5.0.jar"/>
<classpathentry kind="lib" path="lib/slf4j-log4j12-1.5.0.jar"/>
<classpathentry kind="lib" path="lib/spring.jar"/>
<classpathentry kind="output" path="bin"/>
</classpath>
Re: Why my added libraries are automatically removed from &quot;Java Build Path&quot; in Ecl [message #1384910 is a reply to message #1384836] Tue, 03 June 2014 00:23 Go to previous messageGo to next message
Actually I tried many things,
recreated the server instance to check if there was problem wid a previous one...
tried modifying server specific settings too...
bt no effect.
I could nt figure out what's wrong..
There may be something wrong wid the IDE settings... bt What .. Who knowsss Sad
Re: Why my added libraries are automatically removed from &amp;quot;Java Build Path&amp;quot [message #1385010 is a reply to message #1384909] Tue, 03 June 2014 11:29 Go to previous messageGo to next message
> <classpath>
> </classpath>
This file shows no evidence of being a Dynamic Web Project. If
something is removing entries, it doesn't appear to be Web Tools doing it.
Larry
Re: Why my added libraries are automatically removed from &amp;quot;Java Build Path&amp;quot [message #1385102 is a reply to message #1385010] Wed, 04 June 2014 07:07 Go to previous messageGo to next message
yes;
May be its nt the Web Tools removing those libraries...
bt something is....
strange..
Re: Why my added libraries are automatically removed from &amp;amp;quot;Java Build Path&amp; [message #1385120 is a reply to message #1385102] Wed, 04 June 2014 08:57 Go to previous messageGo to next message
On 6/4/2014 7:07 AM, Sana Shaikh wrote:
> yes;
> bt something is....
> strange..
I don't know if I can help, but the next step would be to look in the
..project file to see if any of the natures or builders give a clue as to
what Eclipse plugins may be "messing" with the project.
Larry
Re: Why my added libraries are automatically removed from &amp;amp;quot;Java Build Path&amp; [message #1385215 is a reply to message #1385120] Wed, 04 June 2014 23:26 Go to previous message
Well, Yes I am trying to detect what the prob is...let's see
will get the solution InshaALLAH.
Thanku so much for all.JazakALLAH
Previous Topic:error in creating JSF projrct
Next Topic:Ganymede JEE - Tomcat 6.0 Server Plugin
Current Time: Wed Jul 23 18:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.05319 seconds
