Home » Eclipse Projects » Nebula » Highlighting over item bounds
Highlighting over item bounds [message #13789] Wed, 11 October 2006 14:24 Go to next message
This is a nebula/newbie question:
On selection, I'd like the titleArea and childArea to be highlighted as
one. I have the bounds highlighted but a little ~halo just around the
perimeter of the childArea control remains white. I added a border to the
child contents composite to check it out, area in question is within the
border. How do I get that painted? Thanks.
(single control in child composite, fillLayout)
Re: Highlighting over item bounds [message #13829 is a reply to message #13789] Fri, 13 October 2006 12:52 Go to previous messageGo to next message
It's subtle, so I want to make sure you're aware that the
createChildContents method passes in an SComposite for the parameter
"contents", and not a regular Composite.
There have also been changes to the SComposite class, and its creation
in the CContainerCell, so please update them from cvs (there is also the
addition of javadocs in SComposite :))
If the update does not fix this, I probably misunderstand the problem,
in which case please post a small screenshot to show the problem.
cheers
Cal wrote:
> Hi
> the child contents composite to check it out, area in question is within
> the border. How do I get that painted? Thanks.
Re: Highlighting over item bounds [message #14378 is a reply to message #13829] Fri, 13 October 2006 15:40 Go to previous message
I was thinking it was a regular composite. But the changes worked, thanks
Re: Highlighting over item bounds [message #566625 is a reply to message #13789] Fri, 13 October 2006 12:52 Go to previous message
cheers
Cal wrote:
> Hi
Re: Highlighting over item bounds [message #566641 is a reply to message #13829] Fri, 13 October 2006 15:40 Go to previous message
Previous Topic:Highlighting over item bounds
Next Topic:ContainerCheckedTreeViewer
Current Time: Tue Jul 22 02:48:01 EDT 2025
Powered by FUDForum. Page generated in 0.04731 seconds
