Home » Eclipse Projects » GEF » Adding captions for a flow(continue)
Adding captions for a flow(continue) [message #13819] Wed, 17 July 2002 21:23 Go to next message
I am sorry by pressing the wrong to post it, and here I continues,
But the problems is that this method sometime works. While for sometime,
the child figure is not completely drawn. First I thought the reason might
be a child figure's bounds cannot exceeds its parent's bounds, but the
caption after cut is not in the parent(Flow figure)'s bounds area either.
And whenever I select the flow in the canvas, the caption get painted
completely without any problem.
So my question is ?
Is this a problem of Draw2d? And is there any other convienent way of
adding caption for a flow, and the caption should be able to exceed the
flow's bound area ?
Thank you.
Re: Adding captions for a flow(continue) [message #13835 is a reply to message #13819] Wed, 17 July 2002 22:05 Go to previous messageGo to next message
Originally posted by: none.ibm.com
"Joe" <zhujun@cn.ibm.com> wrote in message
news:ah55aq$2t4$1@rogue.oti.com...
> So my question is ?
> flow's bound area ?
What is a flow? Are you using an additional framework with GEF?
> 2) In the paintFigure method, set the position of the Label with the
> following code,
*nothing* should change during a paint operation. You should not be moving
figures or changing anything about the figure from within the various paint
methods.
Re: Adding captions for a flow(continue) [message #13959 is a reply to message #13835] Wed, 17 July 2002 23:27 Go to previous messageGo to next message
Here \"flow\" means a Connection (PolylineConnection) Figure, and I set a
Label as the child of this Connection by calling connection.add(label).
The function I want to have now is that the label should always be at the
center of the connecton\'s bound area, so I need to change the bounds of
the label whenever the
So I am just moving the child figure of a connection figure within the
paintFigure method of this connection figure, I don\'t know if it is
allowed. Because I noticed the paintChildren() is called after the
paintFigure method and I set the caption\'s bound at the very beginning of
the paintFigure method, so I don\'t know whehter it would work.
I tried to set the bounds in the ConnectionEditPart\'s refreshVisual
method, only to find the method never get called before the paint() method
of the figure is called, so maybe the painting of figures are controlled
by the ConnectionLayer.
Randy Hudson wrote:
> \"Joe\" <zhujun@cn.ibm.com> wrote in message
> > be a child figure\'s bounds cannot exceeds its parent\'s bounds, but the
> > caption after cut is not in the parent(Flow figure)\'s bounds area either.
> > So my question is ?
> > flow\'s bound area ?
> > following code,
> methods.
Re: Adding captions for a flow(continue) [message #13961 is a reply to message #13959] Thu, 18 July 2002 00:23 Go to previous messageGo to next message
Joe,
You should use a ConnectionLocator, specifically the MidpointLocator, when you
add the Label to the connection.
connection.add(label, new MidpointLocator(connection, 0));
This will keep the label in the center of the connection. The 0 in the
MidpointLocator constructor above is the index of the first of the two points
that the label will be centered between. In other words, if you have a
connection with no bendpoints, this will place the label in the center of the
connection. If the connection does have bendpoints, you can center the label on
any of the line segments.
Eric
"Joe" <zhujun@cn.ibm.com> wrote in message news:ah5cis$5m2$1@rogue.oti.com...
> > > So my question is ?
> > > following code,
> > methods.
Re: Adding captions for a flow(continue) [message #13974 is a reply to message #13959] Thu, 18 July 2002 09:26 Go to previous message
When a Figure is painted, the GC is clipped to the figures bounds by its
parent (the connection layer). So obviously it is too late to move the
figure during the paint call, and update your bounds. That is why we have
validate() which is called first on all figures to make sure they are happy
with their locations, and then everything gets painted.
I believe the Locator Eric mentions is demonstrated in one of the demos in
the Draw2d Reference plugin.
sometime,
might
the
either.
> > > So my question is ?
the
> > > following code,
moving
paint
> > methods.
Previous Topic:Adding captions for a flow
Next Topic:dynamic actions
Current Time: Tue Sep 16 21:10:43 EDT 2025
Powered by FUDForum. Page generated in 0.06698 seconds
