Home » Modeling » EMF » Errors in generated java code when extending Xcore
Errors in generated java code when extending Xcore [message #1376688] Fri, 23 May 2014 10:32 Go to next message
I am working on a DSL in which I want to use features from Xcore.
I added dependencies org.eclipse.emf.ecore.xcore;bundle-version="1.1.2"
to the main project and
org.eclipse.emf.ecore.xcore.ui;bundle-version="1.1.1" to the UI project,
then I created a language like this:
grammar org.xtext.example.extendedxcore.ExtendedXcore with
org.eclipse.emf.ecore.xcore.Xcore
generate extendedXcore
"http://www.xtext.org/example/extendedxcore/ExtendedXcore"
import "http://www.eclipse.org/emf/2011/Xcore" as xcore
EXcore:
package=XPackage
extension=Extension;
Extension:
'selection' name=ID '{'
selected+=Select*
Select:
'select' class=[xcore::XClass];
I then added the following lines to the Workflow file:
registerGeneratedEPackage = "org.eclipse.emf.ecore.xcore.XcorePackage"
registerGenModelFile =
"platform:/resource/org.eclipse.emf.ecore.xcore/model/Xcore.genmodel"
When I run the workflow now I get lots of errors in the generated java
files and I can't figure out how to fix that...
I pasted the list of errors here: http://pastebin.com/05sSHXhV
Most of them seem to speak of missing dependencies, but I don't know
what is missing. Any idea?
Thanks for any suggestions,
Florian
Re: Errors in generated java code when extending Xcore [message #1378113 is a reply to message #1376688] Sat, 24 May 2014 00:51 Go to previous messageGo to next message
Florian,
This look really more like a question best sent to the TMF forum. I
expect an answer requires a good understanding of what's in Xcore's
workflow and based on that what's supposed to be in your extended
grammar's workflow. From the look of it, you're generating some type of
serializer that wants to extend a serializer that's not of the expected
form in Xcore itself. I know the IncQuery project extends Xcore, so you
might want to have a look at their source and see how they've configured
their extension in their workflow.
On 23/05/2014 4:32 PM, Florian König wrote:
> org.eclipse.emf.ecore.xcore;bundle-version="1.1.2" to the main project
> and org.eclipse.emf.ecore.xcore.ui;bundle-version="1.1.1" to the UI
> project, then I created a language like this:
> EXcore:
> package=XPackage
> Extension:
> selected+=Select*
> Select:
> Florian
Re: Errors in generated java code when extending Xcore [message #1381467 is a reply to message #1378113] Sun, 25 May 2014 11:19 Go to previous message
Hi Ed,
Thanks for your suggestions! I will try my luck in the TMF forum and I
will take a deeper look into the IncQuery project (already found it
earlier).
Am 24.05.2014 06:51, schrieb Ed Merks:
> Florian,
>> Hi,
>> EXcore:
>> package=XPackage
>> Extension:
>> selected+=Select*
>> Select:
>> Florian
Previous Topic:Propagating EObject status to all referencing EObjects
Next Topic:New EClass instance validation
Current Time: Thu Jul 24 22:27:34 EDT 2025
Powered by FUDForum. Page generated in 0.10725 seconds
