Home » Modeling » GMF (Graphical Modeling Framework) » Adding dependencies permanent to plugin.xml
Adding dependencies permanent to plugin.xml [message #137579] Tue, 19 June 2007 08:25 Go to next message
Originally posted by: snej_NO-SPAM_.esuark.de
Hi!
Is it possible to add dependencies permanently to the plugin.xml of the
XXX.diagram Plugin with GMF 1.0.3?
I must always add them again after generating the code.
regards
Jens
Re: Adding dependencies permanent to plugin.xml [message #138079 is a reply to message #137579] Wed, 20 June 2007 13:28 Go to previous messageGo to next message
Originally posted by: vinsarwate.yahoo.com
Dependencies that you specify in "dependencies" tab for plugin.xml are
stored in manifest.mf file. I am not aware of any tag or mechanism for
preserving certain entries in manifest.mf while code generation.
Thanks.
Vinay
Re: Adding dependencies permanent to plugin.xml [message #138253 is a reply to message #137579] Thu, 21 June 2007 09:20 Go to previous message
Hi Jens,
The mechanism to reconcile manifest.mf only appeared in GMF 2.0 M7 (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=146774).
Boris
Jens Krause wrote:
> Hi!
> regards
> Jens
Previous Topic:Re: GMF Property View Refresh Problem
Next Topic:Remove parent EditPart from child editPart
Current Time: Tue Jul 22 16:05:53 EDT 2025
Powered by FUDForum. Page generated in 0.02214 seconds
