Home » Language IDEs » ServerTools (WTP) » Eclipse not accepting taglib tag in web.xml
Eclipse not accepting taglib tag in web.xml [message #137890] Fri, 09 September 2005 13:40 Go to next message
Originally posted by: neil.JAMMConsulting.com
Hello:
I am converting an existing struts based web app into an Eclipse WTP
project.
Eclipse does not like my web.xml, it gives me this error:
cvc-complex-type.2.4.a: Invalid content was found starting with element
'taglib'.
One of '{"http://java.sun.com/xml/ns/j2ee":description,
"http://java.sun.com/xml/ns/j2ee":display-name,
"http://java.sun.com/xml/ns/j2ee":icon,
"http://java.sun.com/xml/ns/j2ee":distributable,
"http://java.sun.com/xml/ns/j2ee":context-param,
"http://java.sun.com/xml/ns/j2ee":filter,
"http://java.sun.com/xml/ns/j2ee":filter-mapping,
"http://java.sun.com/xml/ns/j2ee":listener,
"http://java.sun.com/xml/ns/j2ee":servlet,
"http://java.sun.com/xml/ns/j2ee":servlet-mapping,
"http://java.sun.com/xml/ns/j2ee":session-config,
"http://java.sun.com/xml/ns/j2ee":mime-mapping,
"http://java.sun.com/xml/ns/j2ee":welcome-file-list,
"http://java.sun.com/xml/ns/j2ee":error-page,
"http://java.sun.com/xml/ns/j2ee":jsp-config,
"http://java.sun.com/xml/ns/j2ee":security-constraint,
"http://java.sun.com/xml/ns/j2ee":login-config,
"http://java.sun.com/xml/ns/j2ee":security-role,
"http://java.sun.com/xml/ns/j2ee":env-entry,
"http://java.sun.com/xml/ns/j2ee":ejb-ref,
"http://java.sun.com/xml/ns/j2ee":ejb-local-ref,
"http://java.sun.com/xml/ns/j2ee":service-ref,
"http://java.sun.com/xml/ns/j2ee":resource-ref,
"http://java.sun.com/xml/ns/j2ee":resource-env-ref,
"http://java.sun.com/xml/ns/j2ee":message-destination-ref,
"http://java.sun.com/xml/ns/j2ee":message-destination,
"http://java.sun.com/xml/ns/j2ee":locale-encoding-mapping-list}' is
expected.
Here is my web.xml:
<web-app xmlns="http://java.sun.com/xml/ns/j2ee"
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd"
version="2.4">
<!-- Standard Action Servlet Configuration (with debugging) -->
<servlet>
<servlet-name>action</servlet-name>
<servlet-class>org.apache.struts.action.ActionServlet</servlet-class >
<init-param>
<param-name>config</param-name>
<param-value>/WEB-INF/struts-config.xml</param-value>
</init-param>
<init-param>
<param-name>debug</param-name>
<param-value>0</param-value>
</init-param>
<init-param>
<param-name>detail</param-name>
</init-param>
<load-on-startup>2</load-on-startup>
</servlet>
<!-- Standard Action Servlet Mapping -->
<servlet-mapping>
<url-pattern>*.do</url-pattern>
</servlet-mapping>
<!-- The Welcome File List -->
<welcome-file-list>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
<!-- Application wide error pages -->
<error-page>
<exception-type>java.lang.Throwable</exception-type>
<location>/error.do</location>
</error-page>
<!-- Struts Tag Library Descriptors -->
<taglib>
<taglib-uri>/tags/struts-bean</taglib-uri>
<taglib-location>/WEB-INF/struts-bean.tld</taglib-location >
</taglib>
<taglib>
<taglib-uri>/tags/struts-html</taglib-uri>
<taglib-location>/WEB-INF/struts-html.tld</taglib-location >
</taglib>
<taglib>
<taglib-uri>/tags/struts-logic</taglib-uri>
<taglib-location>/WEB-INF/struts-logic.tld</taglib-location >
</taglib>
<taglib>
<taglib-uri>/tags/struts-nested</taglib-uri>
<taglib-location>/WEB-INF/struts-nested.tld</taglib-location >
</taglib>
<taglib>
<taglib-uri>/tags/struts-tiles</taglib-uri>
<taglib-location>/WEB-INF/struts-tiles.tld</taglib-location >
</taglib>
<!-- Do not allow users to load jsps directly -->
<security-constraint>
<web-resource-collection>
<web-resource-name>no_access</web-resource-name>
<url-pattern>*.jsp</url-pattern>
</web-resource-collection>
<auth-constraint/>
</security-constraint>
</web-app>
Any ideas why this error is occurring?
Neil
Neil Aggarwal, JAMM Consulting, (214)986-3533, www.JAMMConsulting.com
FREE! Valuable info on how your business can reduce operating costs by
17% or more in 6 months or less! http://newsletter.JAMMConsulting.com
Re: Eclipse not accepting taglib tag in web.xml [message #137902 is a reply to message #137890] Fri, 09 September 2005 14:00 Go to previous messageGo to next message
This web.xml would probably be valid for Servlet 2.3, but with Servlet
2.4, the schema requires that <taglib> elements be children of a
<jsp-config> element.
Larry
Neil Aggarwal wrote:
> Hello:
> project.
> 'taglib'.
> expected.
> Here is my web.xml:
> version="2.4">
> <servlet>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> <welcome-file-list>
> <error-page>
> </error-page>
> <taglib>
> </taglib>
> <taglib>
> </taglib>
> <taglib>
> </taglib>
> <taglib>
> </taglib>
> <taglib>
> </taglib>
> <auth-constraint/>
> </web-app>
> Neil
Re: Eclipse not accepting taglib tag in web.xml [message #137940 is a reply to message #137902] Fri, 09 September 2005 16:21 Go to previous messageGo to next message
Larry:
Is there a way to tell eclipse to use the servlet 2.3 spec?
My server is running Tomcat 5.0 and I dont want to go thru the
hassle of upgrading it.
Neil
Re: Eclipse not accepting taglib tag in web.xml [message #137963 is a reply to message #137940] Fri, 09 September 2005 16:29 Go to previous messageGo to next message
> Larry:
> Neil
Tomcat 5.0 supports the Servlet 2.4 spec. I think you'd be better off
just modifying your web.xml file to match the Servlet 2.4 spec.
However, if you really want to revert back to 2.3, you just need to fix
the web.xml to be declared as 2.3 instead of 2.4 (DOCTYPE with 2.3 dtd,
vs. 2.4 schema)
-Stephen
Re: Eclipse not accepting taglib tag in web.xml [message #137975 is a reply to message #137963] Fri, 09 September 2005 17:30 Go to previous messageGo to next message
Stephen:
So, what you are saying is that Tomcat is allowing me to specify the 2.4 DTD
and
be sloppy.
I get your point. I will change my web.xml.
Neil
"Stephen Duncan Jr" <jrduncans@stephenduncanjr.com> wrote in message
news:dfsra8$dba$1@news.eclipse.org...
> vs. 2.4 schema)
> -Stephen
Re: Eclipse not accepting taglib tag in web.xml [message #137997 is a reply to message #137975] Fri, 09 September 2005 18:26 Go to previous messageGo to next message
If you only change the web.xml, only the server will think the webapp is
2.3. WebTools will still think it's 2.4 since that is how it was
created. WebTools wouldn't let you test it with a Tomcat 4.1 server.
When you create a Dynamic Web Application, make sure the Advanced
section is displayed. It is there that you can select the module's J2EE
version. You may want to create a new 2.3 Dynamic Web Application and
copy your current content over.
You could compare ".*" files between the two and try to manually change
your current project to 2.3. However, I don't know if that might make
the project inconsistent with cached information that would lead to
erroneous behavior.
Larry
> Stephen:
> and
> be sloppy.
> Neil
Re: Eclipse not accepting taglib tag in web.xml [message #138296 is a reply to message #137997] Mon, 12 September 2005 10:47 Go to previous message
Larry is describing some additional metadata that tracks the "module"
version, and should be changed as well. The .wtpmodules file uses the
<module-type module-type-id="jst.web">
<version>2.3</version> attribute, make sure you change this as
well.
The servlet schema didn't change too much between these versions, so you
should be fine....
- Chuck
Larry Isaacs <Larry.Isaacs@sas.com> wrote in
news:dft26d$lus$1@news.eclipse.org:
> is 2.3. WebTools will still think it's 2.4 since that is how it was
> J2EE version. You may want to create a new 2.3 Dynamic Web
> Application and copy your current content over.
> change your current project to 2.3. However, I don't know if that
> might make the project inconsistent with cached information that would
> lead to erroneous behavior.
> Larry
Previous Topic:Excluding a file from a war
Next Topic:SSE Documentation?
Current Time: Thu Sep 18 14:17:36 EDT 2025
Powered by FUDForum. Page generated in 0.11112 seconds
