Home » Eclipse Projects » OSEE » Installation w/ Qucik Start Tutorial
Installation w/ Qucik Start Tutorial [message #13772] Wed, 29 April 2009 17:24 Go to next message
I am trying to install OSEE on a Windows XP. I have PostgreSQL up and
running with an OSEE database (I wish there was a test so I could validate
this step).
I am using the method described in:
http://www.eclipse.org/osee/OSEE_eclipsecon2009_tutorial_sli des.pdf
I am at page 8 were it says to 'Launce OSEE Client', and then specifies:
eclipse -vmargs -Xmx512m
-Dosee.application.server=http://localhost:8089
-Dosee.authentication.protocol=demo
When I run this, I get an Eclipse error window which states:
JVM terminated. Exit code=-1
-Xmx512m-Dosee.application.server=http://localhost:8089-Dosee.authentication.protocol=demo
<16 more lines with no statements that seem to be errors>
-Djava.class.path=C:\osee\eclipse\plugins\org.exlipse.equino x.launcher_1.0.101.R34x_v20081125.jar
OK
When I select the 'OK' button, Eclipse closes.
If I then open Eclipse to follow the next directive in the tutorial:
Switch to the ATS Perspective
1. Window
2. Open Perspective
3. ATS
The Defin Nav pane has the text:
OSEE Service(s) Unavailable:
Application Server. Error: Application server address was null
Arbitration Server. Error: Error requesting application server for
version [0.8.0RC 2009-04-16 18:34]
Client Data Source. Error: Error obtaining database connection.
Session Manager. Error: Invalid resource server address
Since this looks like a app server problem, I entered the contents of ...:
java -Dosee.log.default=INFO -Dorg.osgi.service.http.port=8089
-Dosgi.compatibility.bootdelegation=true -Xmx512m
-Dosee.db.connection.id=postgresqlLocalhost -Dequinox.ds.debug=true -jar
org.eclipse.osgi_3.4.0.v20080326.jar -console
which showed no errors and ended with:
Wed Apr 29 15:56:25 CDT 2009
org.eclipse.osee.framework.search.engine.internal.SearchEngi neTagger
INFO org.eclipse.osee.framework.search.engine.internal.StartUpRun nable
run (45)
Tagging on Server Startup was not run.
So I excited Eclipse and started it up again then went to the same ATS
point. This time, the 'Filter' control was visible but there was still an
error message, this time it was in the quick search window. It stated:
Application Servr. Error: Application server address was null
As the tutorial directed, I input 'Populate' in the filter. Blam
Operations filtered down to 'XWidget Populate Example', there wasn't a
John Hopkins University Populate Demos Action item.
When I double clicked the Blam example, an OSEE Error window came up with:
Session is invalid - authentication is required
Reason:
The details were:
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.getOseeSessionGrant(InternalClientSessionMa nager.java:91)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.getDatabaseInfo(InternalClientSessionManage r.java:83)
org.eclipse.osee.framework.core.client.internal.ClientDataba seProvider.getDatabaseInfo(ClientDatabaseProvider.java:34)
org.eclipse.osee.framework.db.connection.OseeDbConnection.ge tDatabaseInfoProvider(OseeDbConnection.java:63)
org.eclipse.osee.framework.db.connection.OseeDbConnection.ge tConnection(OseeDbConnection.java:44)
org.eclipse.osee.framework.db.connection.ConnectionHandlerSt atement.allowReuse(ConnectionHandlerStatement.java:151)
org.eclipse.osee.framework.db.connection.ConnectionHandlerSt atement.runPreparedQuery(ConnectionHandlerStatement.java:69)
org.eclipse.osee.framework.skynet.core.artifact.BranchManage r.ensurePopulatedCache(BranchManager.java:195)
org.eclipse.osee.framework.skynet.core.artifact.BranchManage r.getKeyedBranch(BranchManager.java:677)
org.eclipse.osee.framework.skynet.core.artifact.BranchManage r.getCommonBranch(BranchManager.java:130)
org.eclipse.osee.framework.ui.skynet.blam.BlamWorkflow.getOr CreateBlamWorkflow(BlamWorkflow.java:71)
org.eclipse.osee.framework.ui.skynet.blam.BlamEditorInput.<init >(BlamEditorInput.java:32)
org.eclipse.osee.framework.ui.skynet.blam.BlamEditor.edit(Bl amEditor.java:85)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateItemBlam.run(XNavigateItemBlam.java:36)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite.handleDoubleClick(XNavigateComposite.java:214)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite.handleDoubleClick(XNavigateComposite.java:204)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite$3.handleEvent(XNavigateComposite.java:100)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
org.eclipse.equinox.launcher.Main.run(Main.java:1236)
In summary, I am having difficulty getting past ATS. Any suggestions on
how to go forward?
Ray
Re: Installation w/ Qucik Start Tutorial [message #13793 is a reply to message #13772] Wed, 29 April 2009 18:25 Go to previous messageGo to next message
Since this looked like a server setup problem, I looked at the methods I
tried. There is the .sh version and the .bat version. I tried both and
they both failed. So I tried a combination which went a lot farther than
the originals but still failed (as described below).
sh version:
-jar org.eclipse.osgi_3.4.0.v20080326.jar
-console
bat version:
CMD /K java -Declipse.ignoreApp=true -Xms40m -Xmx512m
-Dosgi.compatibility.bootdelegation=true -Dequinox.ds.debug=true
-Dorg.osgi.service.http.port=8089 -Dosee.log.default=INFO
-Dosgi.configuration.area=osee_app_server
-jar
osee_app_server/platform/org.eclipse.osgi_3.4.2.R34x_v200808 26-1230.jar
-console
combo version:
eclipsec -application org.eclipse.osee.framework.database.configClient
-vmargs
-Xmx512m
-Dosee.log.default=INFO -Dosee.application.server=http://localhost:5432
-Dosee.authentication.protocol=trustAll -Dosee.prompt.on.db.init=false
-Dosee.choice.on.db.init="OSEE Demo Database"
Results:
!SESSION 2009-04-29 09:22:48.347
eclipse.buildId=M20080911-1700
java.version=1.6.0_04
Framework arguments: -application
Command-line arguments: -os win32 -ws win32 -arch x86 -application
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2009-04-29
09:22:49.847
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.internal.provisional.p2.director; version="0.0.0"
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
<snipped to end> . . .
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at
org.apache.commons.httpclient.HttpParser.readRawLine(HttpPar ser.java:78)
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser .java:106)
at
org.apache.commons.httpclient.HttpConnection.readLine(HttpCo nnection.java:1116)
at
org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnect ionManager.java:1413)
at
org.apache.commons.httpclient.HttpMethodBase.readStatusLine( HttpMethodBase.java:1973)
at
org.apache.commons.httpclient.HttpMethodBase.readResponse(Ht tpMethodBase.java:1735)
at
org.apache.commons.httpclient.HttpMethodBase.execute(HttpMet hodBase.java:1098)
at
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:398)
at
org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
at
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
at
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:323)
at
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:106)
... 18 more
It looks like something is still missing. I will appreciate all help.
Ray
Re: Installation w/ Qucik Start Tutorial [message #13812 is a reply to message #13793] Thu, 30 April 2009 10:45 Go to previous message
I am sorry I missed the boat on this. The two methods are not related.
I'll have to try something else.
Re: Installation w/ Qucik Start Tutorial [message #573247 is a reply to message #13772] Wed, 29 April 2009 18:25 Go to previous message
sh version:
-console
bat version:
-jar
-console
combo version:
-vmargs
-Xmx512m
Results:
09:22:49.847
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 18 more
Ray
Re: Installation w/ Qucik Start Tutorial [message #573259 is a reply to message #13793] Thu, 30 April 2009 10:45 Go to previous message
Previous Topic:Installation w/ Qucik Start Tutorial
Next Topic:osee exe files
Current Time: Fri Jul 18 20:06:26 EDT 2025
Powered by FUDForum. Page generated in 0.04197 seconds
