Home » Language IDEs » Java Development Tools (JDT) » "enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8
"enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8 [message #1378592] Sat, 24 May 2014 05:50 Go to next message
With "enable syntactic null analysis for fields" enabled, the "a.toString();" compiles ok in java1.7 compliance, but give a warning/error with java1.8
import org.eclipse.jdt.annotation.NonNull;
import org.eclipse.jdt.annotation.Nullable;
public class Test3 {
@Nullable Integer a;
@NonNull
Integer get() {
return new Integer(1);
void test() {
a = get();
a.toString();
Re: "enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8 [message #1379024 is a reply to message #1378592] Sat, 24 May 2014 10:14 Go to previous messageGo to next message
Works for me - but sometimes the null analysis warnings/errors start to
show up arbitarily :-(
I also think that generally speaking this code is haveing the risk of
NPEs if it is used in a multi-threaded env.
Tom
> @NonNull
> Integer get() {
> void test() {
> a = get();
> a.toString();
Re: "enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8 [message #1379149 is a reply to message #1379024] Sat, 24 May 2014 11:29 Go to previous messageGo to next message
With eclipse 4.4rc2 the warning still exists, are you sure using "compiler compliance level" 1.8 ? When using java 1.8 but with compliance 1.8, all works fine.
The option "enable syntactic null analysis for fields" is explained at
http://wiki.eclipse.org/JDT_Core/Null_Analysis/Beta
and it's supposed to eliminate this warning
Thomas Schindl wrote on Sat, 24 May 2014 10:14
show up arbitarily Sad
Tom
> @NonNull
> Integer get() {
> void test() {
> a = get();
> a.toString();
Re: "enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8 [message #1382013 is a reply to message #1379149] Sun, 25 May 2014 16:54 Go to previous message
solved: using the old org.elicpse.jdt.annotation give the problem
Previous Topic:null type mismatch with eclipse 4.4rc1 and java 1.8
Next Topic:the annotaion @NonNull is disallowed for this location
Current Time: Mon Jul 21 00:22:02 EDT 2025
Powered by FUDForum. Page generated in 0.03848 seconds
