Home » Language IDEs » Java Development Tools (JDT) » null type mismatch with eclipse 4.4rc1 and java 1.8
null type mismatch with eclipse 4.4rc1 and java 1.8 [message #1378575] Sat, 24 May 2014 05:38 Go to next message
using eclipse 4.4RC1 with "compiler compliance level 1.7", the code below is fine, but with "compiler compliance level 1.8", it doesn't work.
if you use "(E)null" instead of "null" the code work with a warning
import org.eclipse.jdt.annotation.Nullable;
public class Test2<E> {
@Nullable
E test() {
return null;
void test2() {
E local = null;
Re: null type mismatch with eclipse 4.4rc1 and java 1.8 [message #1379023 is a reply to message #1378575] Sat, 24 May 2014 10:11 Go to previous messageGo to next message
That's to be expected! You need to annotate the generic type
> public class Test2<@Nullable E> {
> @Nullable
> E test() {
> return null;
> void test2() {
> E local = null;
I had the same missunderstanding see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=434374#c8 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=434374#c11
Tom
> @Nullable
> E test() {
> return null;
> void test2() {
> E local = null;
Re: null type mismatch with eclipse 4.4rc1 and java 1.8 [message #1379174 is a reply to message #1379023] Sat, 24 May 2014 11:43 Go to previous messageGo to next message
I have read the bugs, but I don't understand why it is related.
I declared the variable @Nullable, so it has to be nullable, indeed (E)null works ok.
the declaration
give me an error, maybe I miss something
However, E type can be null or not null at class level, but I think I always can do a local variable null:
@NonNull E test2() {
E local = null;
if( local != null )
return E;
Thomas Schindl wrote on Sat, 24 May 2014 10:11
> @Nullable
> E test() {
> return null;
> void test2() {
> E local = null;
Tom
> @Nullable
> E test() {
> return null;
> void test2() {
> E local = null;
Re: null type mismatch with eclipse 4.4rc1 and java 1.8 [message #1379412 is a reply to message #1379174] Sat, 24 May 2014 14:08 Go to previous messageGo to next message
The semantics of null type annotations in relation to type parameters and type variables still needs to be documented. I hope I'll find the time to include the basic explanations into the Luna migration guide.
Basically, all examples you give work as designed, but:
the declaration
this works for me. What error are you seeing?
best,
Stephan
Re: null type mismatch with eclipse 4.4rc1 and java 1.8 [message #1382012 is a reply to message #1379412] Sun, 25 May 2014 16:52 Go to previous message
i found the problem: i have update eclipse 4.3 to 4.4, my project point to old
Previous Topic:How to keep track of the selected Quick Fixes?
Next Topic:"enable syntactic null analysis for fields" broken with eclise 4.4rc1 jdk1.8
Current Time: Mon Jul 21 07:49:51 EDT 2025
Powered by FUDForum. Page generated in 0.03149 seconds
