Mapping one object to multiple [message #1373915] |
Thu, 22 May 2014 07:31  |
Hi, I am new to ATL and MDD and I think I am missing something really important with this problem.
I have an object container which has a reference called group to one or more items.
I'm trying to write an in-place transformation that will insert a new item for every item already in a group so the group has twice as many elements than before the transformation is run.
Here is my current approach.
create OUT: source refining IN: source;
helper context source!item def: doSomething() : source!item =
self.refSetValue('interestingValue', 1)
helper context source!container def: generateSequence() : Sequence(source!item) =
self.group->iterate(e; res: Sequence(source!item) = Sequence{} |
res->append(e.doSomething())
rule putNewThingsThere {
from
s: source!container
to
t: source!container (
group <- s.generateSequence()
When I run this transformation, the items in group become the new ones, but I would like to retain the old ones as well. Can someone explain how in ATL we create fresh elements for the new model?
Re: Mapping one object to multiple [message #1377755 is a reply to message #1374222] |
Fri, 23 May 2014 21:10   |
Hi, I have come across another problem.
I now have the new objects being created within the same container, but I need to be able to control the order.
If I start with a model which has a container with {A, B C}
My transformation results in {A, B, C, A1, B1, C1}
I have been trying to get it to produce {A, A1, B, B1, C, C1} but I am unsuccessful.
Is there a way to specify that the new elements should be inserted straight after their counterpart?
Thank you.
Re: Mapping one object to multiple [message #1383878 is a reply to message #1383665] |
Mon, 26 May 2014 11:55  |
EMF is already providing some support to import XML documents as regular EMF models.
You should take a look to this (cf. the EMF documentation and forum).
If needed, you could of course use an additional ATL transformation to perform an eventually required mapping.
FUDForum. Page generated in 0.04292 seconds
