Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Progressbar is frozen with syncExec
Progressbar is frozen with syncExec [message #1377185] Fri, 23 May 2014 15:23 Go to next message
I want to display a progres bar in GUI while a time consuming task, this task collects data from gui form, so I must use
 Display.getDefault().syncExec
or
Display.getDefault().asyncExec
in order to access GUI.
The issue with my following code, that while task is running the main GUI thread is locked and the progress bar is not "running".
Please help.
showProgress.addSelectionListener(new SelectionAdapter() {
      public void widgetSelected(SelectionEvent event) {
        try {
            new ProgressMonitorDialog(shell).run(true, true, new IRunnableWithProgress() {
	       public void run(IProgressMonitor monitor) throws InvocationTargetException, InterruptedException {
		  monitor.beginTask("Running long running operation", IProgressMonitor.UNKNOWN);
		  Display.getDefault().syncExec(new Runnable() {
		  public void run() {
		     for (int i = 0; i < 0100; i += 1) {
			try {
			    Thread.sleep(1000);
			    readDataFromGUI();
			} catch (InterruptedException e) {
			     e.printStackTrace();
		monitor.done();
        } catch (InvocationTargetException e) {
          MessageDialog.openError(shell, "Error", e.getMessage());
          MessageDialog.openInformation(shell, "Cancelled", e.getMessage());
[Updated on: Fri, 23 May 2014 15:51] by Moderator
Re: Progressbar is frozen with syncExec [message #1377350 is a reply to message #1377185] Fri, 23 May 2014 17:02 Go to previous messageGo to next message
The syncExec method calls the run method in the GUI thread so the GUI thread isn't locked, it is running your code. The syncExec (and asyncExec) calls exist to allow long running threads to update the display. They aren't there to execute long running code. The way they are intended to be used is that your long running task invokes them when it needs to update the display. The Runnable passed to the method should do a quick update of a GUI component and return.
I haven't used ProgressMonitorDialog, but I believe that by passing the fork parameter of true on the run method, it handles the threading for you. Have you tried removing the syncExec call and having the loop with the sleep in it right after the monitor.beginTask call?
Re: Progressbar is frozen with syncExec [message #1378356 is a reply to message #1377350] Sat, 24 May 2014 03:24 Go to previous message
I am already passing fork parameter as true in the code above...
When I remove syncExec call it works, but I won't be able to access gui controls.
Previous Topic:[SOLVED]Accessing GUI from another thread with progressbar
Next Topic:UTF-8 Char are not displaying in TableViewer SWT
Current Time: Fri Jul 25 22:16:20 EDT 2025
Powered by FUDForum. Page generated in 0.03750 seconds
