Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Eclipse memory consumption in general
Eclipse memory consumption in general [message #1377] Fri, 28 October 2005 08:22 Go to next message
Originally posted by: arto.laurila.nomail.nokia.com
Hi!
I was in some meeting where some participants raised an issue that the
Eclipse memory
consumption is raising too much.
As seen that the Eclipse based GUI extensions with some multimedia content
may easily
hold several megs of data (1-40), and with the base Eclipse frameworks
memory footprint the
total memory reqs can be quite high (->slow).
In generally the memory optimization is crucial for larger volumes (and e.g.
the RCP/eRCP
code should be memory optimized)
Does others share this kind of issue, have you had problems with the memory
consumption
in Eclipse environments?
Br. Art
Arto Laurila
Nokia
Re: Eclipse memory consumption in general [message #3475 is a reply to message #1377] Wed, 02 November 2005 06:52 Go to previous message
Hello Arto Laurila,
Yes its a concern although pesonally I have not expereinced any memory
consumption issues.
However, its not wise for use to assume that they will not be an issue
at some point.
Arto Laurila wrote:
> Hi!
> Eclipse memory
> may easily
> the RCP/eRCP
> consumption
> Br. Art
> Arto Laurila
> Nokia
Re: Eclipse memory consumption in general [message #561388 is a reply to message #1377] Wed, 02 November 2005 06:52 Go to previous message
Hello Arto Laurila,
consumption issues.
at some point.
Arto Laurila wrote:
> Hi!
> Eclipse memory
> may easily
> the RCP/eRCP
> consumption
> Br. Art
> Arto Laurila
> Nokia
Previous Topic:Use Case documents
Next Topic:Antenne Contributor Joining
Current Time: Sun Oct 19 13:35:48 EDT 2025
Powered by FUDForum. Page generated in 0.03779 seconds
