Home » Eclipse Projects » Sirius » Diagram Description with more than one sematic model
icon3.gif  Diagram Description with more than one sematic model [message #1374291] Thu, 22 May 2014 11:10 Go to next message
I've three semantic models (ecore) in my project.
I build a diagram description.
I would use selection wizard descrption to load a property of selected element.
Problem :the elements displayed in selection wizard description doesn't stored in a same model that selected element.
How can i access at these elements in Candidates Expression field?
thank,
[Updated on: Fri, 23 May 2014 05:47] by Moderator
Re: Diagram Description with more than one sematic model [message #1376723 is a reply to message #1374291] Fri, 23 May 2014 10:52 Go to previous messageGo to next message
Can you unfold your ecore semantic models directly from the model
explorer view ? If it's possible that means your resources are loaded in
the Sirius Session resourceset and you should be able to access them. I
suggest you to use a java service (see
http://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#specialized
and
http://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#service_methods
to implement and use a java service). In this service you could get to
the resourceset starting from the selected element for instance.
Florian
On 05/22/2014 09:06 PM, nicolas nusswitz wrote:
> element.
> Problem : elements displayed in selection wizard descrption don't stored
> thank,
Re: Diagram Description with more than one sematic model [message #1376823 is a reply to message #1376723] Fri, 23 May 2014 11:46 Go to previous message
Hi Nicolas,
You can fill the 'Metamodels' section of the viewpoint Representation mapping.
As an addition, you can also use the 'Load resource' context menu on the viewpoint editor to load your m2.
With this, you should see your mappings.
Hope it helped.
Charlie
Previous Topic:An exception stack trace is not available.
Next Topic:Sirius Moving a NodeCreationDescription
Current Time: Fri Jul 18 17:23:07 EDT 2025
Powered by FUDForum. Page generated in 0.48366 seconds
