Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EmfStore] Commit observe on server
| [EmfStore] Commit observe on server [message #988785] |
Mon, 03 December 2012 03:10  |
Maybe it's a simple question..
How observe commit on server side? I find solution only on client side by extension org.eclipse.emf.emfstore.client.commitObserver
Thanks.
Dmitriy.
| Re: [EmfStore] Commit observe on server [message #1385417 is a reply to message #1376406] |
Fri, 06 June 2014 05:59   |
sorry for the late answer. I already found the solution. At deletion of
a project the notification needs to be disabled first. I added a few
lines to the method deleteProject() in class
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl
which now looks like this:
public void deleteProject(SessionId sessionId, ProjectId projectId,
boolean deleteFiles) throws ESException {
for (final ProjectHistory history :
eMFStoreControllerInstance.getServerSpace().getProjects())
if (history.getProjectId().getId().equals(projectId.getId()))
// the notifier needs to be disabled for the deletion of the
// project to avoid NullPointerExceptions
history.eAdapters().get(0).getTarget().eSetDeliver(false);
getEmfStore().deleteProject(sessionId, projectId, deleteFiles);
Kristof
Am 23.05.2014 13:54, schrieb Maximilian Koegel:
> could you post the stacktrace, please.
> Cheers,
> Maximilian
> Am 21.05.2014 15:06, schrieb Zalecki, Kristof:
>> Hi,
>> I tried the solution for the commit notifications and I am getting
>> Nullpointer Exceptions when I try to delete projects on the server.
>> It seems to be connected to the Adapters which are created for the
>> notifications.
>> Is there a way to get this working properly? I already tried deleting
>> the Adapter before the project itself is being deleted in the
>> deleteProject method in class
>> but without any luck.
>> Regards,
>> Kristof
| Re: [EmfStore] Commit observe on server [message #1385866 is a reply to message #1385417] |
Wed, 11 June 2014 14:32   |
Hi Kristof,
I tested this myself and I didn't have any issues so far.
Do you have any customizations of your own registered at the server?
If so, would you mind sharing a stacktrace or a minimal test case with
us, such that we can reproduce the issue?
Also, can you tell us which adapter is returned for
history.eAdapters().get(0) and which target it is pointing to?
Edgar
Am 06.06.2014 11:59, schrieb Zalecki, Kristof:
> the
> Regards,
> Kristof
>> Hi,
>> Cheers,
>> Maximilian
>>> Hi,
>>> notifications.
>>> Regards,
>>> Kristof
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
| Re: [EmfStore] Commit observe on server [message #1386438 is a reply to message #1385866] |
Tue, 17 June 2014 10:28  |
Hi Edgar,
In the attachement there are two text files containing the stack traces
from my client and from my server. The only changes I have made on
server side are the mentioned Adapters, which i added to the server
start as your example showed and also to the createProject() and
createEmptyProject() in class
in order to create them at creation of projects.
The problem occurs after committing a project containing changes, which
then of course invokes the notification mechanism. After that I try to
delete the project on the server and I get the NullPointerException.
When trying to delete the project a second time it works.
I am also using Version 1.1 of EMFStore so maybe this problem fixed
itself on the way.
Kristof
Am 11.06.2014 20:32, schrieb Edgar Mueller:
> Hi Kristof,
> Cheers,
> Edgar
>> Hi,
>> the
>> Regards,
>> Kristof
>>> Hi,
>>> Cheers,
>>> Maximilian
>>>> Hi,
>>>> notifications.
>>>> Regards,
>>>> Kristof
!ENTRY org.eclipse.emf.emfstore.client 4 4 2014-06-17 16:11:50.268
!MESSAGE org.eclipse.emf.emfstore.server.exceptions.ESException: java.lang.NullPointerException
!STACK 0
java.util.concurrent.ExecutionException: org.eclipse.emf.emfstore.server.exceptions.ESException: java.lang.NullPointerException
at java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.java:232)
at java.util.concurrent.FutureTask.get(FutureTask.java:91)
at org.eclipse.emf.emfstore.internal.client.common.UnknownEMFStoreWorkloadCommand.execute(UnknownEMFStoreWorkloadCommand.java:83)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$14.run(ESRemoteProjectImpl.java:518)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$14.run(ESRemoteProjectImpl.java:1)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.run(ServerCall.java:249)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.executeCall(SessionManager.java:120)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.execute(SessionManager.java:61)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.execute(ServerCall.java:269)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:482)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:1)
at org.eclipse.emf.emfstore.client.util.RunESCommand$WithException$2.doRun(RunESCommand.java:102)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.commandBody(EMFStoreCommand.java:51)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack$1.doExecute(EMFStoreTransactionalCommandStack.java:61)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.basicExecute(AbstractTransactionalCommandStack.java:241)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.basicExecute(EMFStoreTransactionalCommandStack.java:163)
at org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:63)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.runEMFStoreCommand(EMFStoreTransactionalCommandStack.java:64)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.execute(EMFStoreTransactionalCommandStack.java:49)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
at org.eclipse.emf.emfstore.client.util.RunESCommand$WithException.run(RunESCommand.java:117)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.delete(ESRemoteProjectImpl.java:477)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIDeleteRemoteProjectController.deleteRemoteProject(UIDeleteRemoteProjectController.java:149)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIDeleteRemoteProjectController.doRun(UIDeleteRemoteProjectController.java:110)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIDeleteRemoteProjectController.doRun(UIDeleteRemoteProjectController.java:1)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1162)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction.execute(MonitoredEMFStoreAction.java:67)
at org.eclipse.emf.ecp.emfstore.internal.ui.handler.DeleteOnServerHandler.execute(DeleteOnServerHandler.java:50)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:814)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:707)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:691)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:630)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.emf.ecp.application3x.Application.start(Application.java:30)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.emf.emfstore.server.exceptions.ESException: java.lang.NullPointerException
at org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.execute(AbstractSubEmfstoreInterface.java:152)
at org.eclipse.emf.emfstore.internal.server.core.EMFStoreImpl.invoke(EMFStoreImpl.java:158)
at $Proxy4.deleteProject(Unknown Source)
at org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl.deleteProject(XmlRpcEmfStoreImpl.java:193)
at org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:115)
at org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.execute(ReflectiveXmlRpcHandler.java:106)
at org.apache.xmlrpc.server.XmlRpcServerWorker.execute(XmlRpcServerWorker.java:46)
at org.apache.xmlrpc.server.XmlRpcServer.execute(XmlRpcServer.java:86)
at org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:200)
at org.apache.xmlrpc.webserver.Connection.run(Connection.java:208)
at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
at org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl$1.notifyChanged(XmlRpcEmfStoreImpl.java:122)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.didRemove(BasicNotifierImpl.java:146)
at org.eclipse.emf.common.util.AbstractEList.didClear(AbstractEList.java:166)
at org.eclipse.emf.common.util.BasicEList.clear(BasicEList.java:640)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.clear(BasicNotifierImpl.java:235)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.unloaded(ResourceImpl.java:1576)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doUnload(ResourceImpl.java:1635)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doUnload(XMLResourceImpl.java:631)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.unload(ResourceImpl.java:1650)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.delete(ResourceImpl.java:1667)
at org.eclipse.emf.emfstore.internal.server.core.subinterfaces.ProjectSubInterfaceImpl.deleteProject(ProjectSubInterfaceImpl.java:302)
at org.eclipse.emf.emfstore.internal.server.core.subinterfaces.ProjectSubInterfaceImpl.deleteProject(ProjectSubInterfaceImpl.java:263)
at org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.execute(AbstractSubEmfstoreInterface.java:140)
... 14 more!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-17 16:11:50.249
!MESSAGE Exception on execution: java.lang.reflect.InvocationTargetException
... 19 more
... 19 more
17.06.2014 16:11:50 org.apache.xmlrpc.server.XmlRpcErrorLogger log
SCHWERWIEGEND: Failed to invoke method deleteProject in class org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl: java.lang.NullPointerException
org.apache.xmlrpc.common.XmlRpcInvocationException: Failed to invoke method deleteProject in class org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl: java.lang.NullPointerException
at org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:129)
... 6 more
... 14 more
Caused by:
... 14 more
Current Time: Wed Nov 05 09:24:30 EST 2025
Powered by FUDForum. Page generated in 0.24574 seconds
