Home » Eclipse Projects » Remote Application Platform (RAP) » Focus lost event with hyperlink in Browser
Focus lost event with hyperlink in Browser [message #1373941] Thu, 22 May 2014 07:50 Go to next message
I have a problem with a hyperlink in the Browser widget. A simplified example is below:
I have an editable table and a Browser widget which contains a hyperlink. When I click inside a table's cell, the celleditor opens and has the focus.
SWT:
When I click on the hyperlink the celleditor closes because the hyperlink gains focus (on mousepressed)
RAP:
The celleditor does not close because the link does not gain the focus (there is no focusOut event on the table/celleditor)
Subsequently this leads to a "Widget is disposed" exception in
org.eclipse.jface.viewers.ColumnViewerEditor.cancelEditing()
Control control = cellEditor.getControl();
if (control != null && !viewer.getControl().isDisposed()) {
if (mouseListener != null) {
control.removeMouseListener(mouseListener); //control is disposed here!
Because control is disposed here
Maybe it is related to http://www.eclipse.org/forums/index.php/m/917900/?srch=focus#msg_917900 ?
[Updated on: Thu, 22 May 2014 09:56] by Moderator
Re: Focus lost event with hyperlink in Browser [message #1375877 is a reply to message #1373941] Fri, 23 May 2014 02:50 Go to previous messageGo to next message
exactly...
This
is the reason.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Focus lost event with hyperlink in Browser [message #1376078 is a reply to message #1375877] Fri, 23 May 2014 04:47 Go to previous messageGo to next message
HI Ivan,
thanks for your reply.
Can you give me a hint how to solve the problem?
frank b wrote
found a way to solve the problem using Tim's advice : browser function facility in onclick body event
however I don't understand what he means
Re: Focus lost event with hyperlink in Browser [message #1384144 is a reply to message #1376078] Wed, 28 May 2014 04:32 Go to previous messageGo to next message
I just tried the following snippet:
<html>
<body>
<select id="selectfield">
  <option value="volvo">Volvo</option>
  <option value="saab">Saab</option>
  <option value="vw">VW</option>
  <option value="audi" selected>Audi</option>
</select>
<input type="text" id="textfield"></input>
<iframe src="iframe.htm" width="90%" height="400" name="name"></iframe> <!-- here a hyperlink is contained -->
<script type="text/javascript">
document.getElementById("selectfield").onblur = function () { alert("focus lost!"); }
document.getElementById("textfield").onblur = function () { alert("focus lost!"); }
</script>
</body>
</html>
When I click on the hyperlink in the IFrame the focusLost event is sent as expected. Is there no way that RAP can achieve the same behaviour?
[Updated on: Mon, 02 June 2014 04:40] by Moderator
Re: Focus lost event with hyperlink in Browser [message #1384811 is a reply to message #1384144] Mon, 02 June 2014 05:10 Go to previous messageGo to next message
Hi.
The snippet works (I assume) because it relies only on the
browser-native focus handling, while RAP does most of the focus handling
itself. It's actually rather complicated and I can't really say how this
could be fixed without some detailed research. In any case, couldn't you
embed the link using a Label widget with markup?
Greetings,
Tim
> <html>
> <body>
> </select>
> lost!"); }
> </script>
> </body>
> </html>
> as expected. Is there now way that RAP can achieve the same behaviour?
Tim Buschtöns
Re: Focus lost event with hyperlink in Browser [message #1384826 is a reply to message #1376078] Mon, 02 June 2014 07:22 Go to previous messageGo to next message
> frank b wrote found a way to solve the problem using Tim's advice :
> browser function facility in onclick body event however I don't
It's a hack using a BrowserFunction (the Java class) to manually
focusing the browser widget. After the BrowserFunction is created it has
to be bound to the browser widgets document body, e.g. by using
browser.evaluate or code like...
document.body.onclick = function(){ myBrowserFunction(); }
.... embedded in the browsers HTML.
I have not tested that, and I can't say for sure it will fix your
problem also.
Greetings,
Tim
Tim Buschtöns
Re: Focus lost event with hyperlink in Browser [message #1385287 is a reply to message #1384826] Thu, 05 June 2014 07:58 Go to previous messageGo to next message
created bug 436693
Re: Focus lost event with hyperlink in Browser [message #1386260 is a reply to message #1385287] Mon, 16 June 2014 04:43 Go to previous messageGo to next message
I tried to manually send a focusLost event. I created a new BrowserFunction which sends a FocusOut event. However it does not work... Did I do anything wrong here?
    return new BrowserFunction(m_browser, getHyperlinkFunctionName()) {
      public Object function(Object[] arguments) {
        Control focusControl = Display.getDefault().getFocusControl();
        if (focusControl != null) {
          System.err.println("sending focus lost event to " + focusControl);
          Event event = new Event();
          event.type = SWT.FocusOut;
          event.widget = focusControl;
          event.display = Display.getDefault();
          focusControl.notifyListeners(SWT.FocusOut, event);
          Event event2 = new Event();
          event2.type = SWT.FocusIn;
          event2.widget = m_browser;
          event2.display = Display.getDefault();
          m_browser.notifyListeners(SWT.FocusIn, event2);
[Updated on: Mon, 16 June 2014 04:48] by Moderator
Re: Focus lost event with hyperlink in Browser [message #1386265 is a reply to message #1386260] Mon, 16 June 2014 04:58 Go to previous messageGo to next message
instead of creating the events manually just try
browser.setFocus/forceFocus(); - this will automatically fire focusOut
of the old focus control and focusIn of the browser. Check the return
value of these methods. Is you browser function executed - sysout printed?
Best,
Ivan
Ivan Furnadjiev
Re: Focus lost event with hyperlink in Browser [message #1386293 is a reply to message #1386265] Mon, 16 June 2014 08:03 Go to previous messageGo to next message
Hi Ivan,
thanks for your reply. Yes the BrowserFunction is working.
Is "Control.forceFocus()" somehow different than really clicking into a field by mouse?
Note:
I have a control (A) which has the focus and attached a focusLostListener.
a) Now I click into another field (B) by mouse, the focusLostListener is called. When I look at the currently focused field: getDisplay().getFocusControl() B is focused, as expected.
b) When I do a "B.forceFocus()" in the BrowserFunction, the focusLost listener is called but getDisplay().getFocusControl() returns A
[Updated on: Mon, 16 June 2014 08:04] by Moderator
Re: Focus lost event with hyperlink in Browser [message #1386300 is a reply to message #1386293] Mon, 16 June 2014 08:18 Go to previous messageGo to next message
are you trying to access the focusControl (display().getFocusControl())
inside the focusOut listener? I think in this case the focusControl
should be the one which is about to lose the focus. It seems that this
is not the case when you change the focus on the client (by mouse for
example) - focusControl is changed and then focusOut event is fired.
Best,
Ivan
Ivan Furnadjiev
Re: Focus lost event with hyperlink in Browser [message #1386304 is a reply to message #1386300] Mon, 16 June 2014 08:47 Go to previous messageGo to next message
Yes, I am calling display().getFocusControl() inside the focusOut listener. Do you know if there is any way to achieve the same behavior as clicking by mouse?
Re: Focus lost event with hyperlink in Browser [message #1386309 is a reply to message #1386304] Mon, 16 June 2014 08:59 Go to previous messageGo to next message
just checked in SWT and it behaves like I thought. We should change
(somehow) the implementation when the focus is changed on the client to
behave like focus.setFocus() on the server. Please file a bugzilla about
this difference.
About your question - focucOut is fired before the actual switch of the
focus control. In focusOut listener display.getFocusControl should
return the same control like event.widget. Our current implementation is
not correct and you should not rely on it.
Best,
Ivan
Ivan Furnadjiev
Re: Focus lost event with hyperlink in Browser [message #1386314 is a reply to message #1386304] Mon, 16 June 2014 09:17 Go to previous messageGo to next message
.... bug opened:
437530: Display#getFocusControl returns wrong control in FocusOut
listener when focus is changed on the client
https://bugs.eclipse.org/bugs/show_bug.cgi?id=437530
Ivan Furnadjiev
Re: Focus lost event with hyperlink in Browser [message #1386524 is a reply to message #1386314] Wed, 18 June 2014 02:15 Go to previous messageGo to next message
Hi Ivan,
sorry for asking again. Is there a way to achieve the same behavior programatically as like clicking into a field via mouse - e.g. I need to first switch the focus control and afterwards get the focus out.
Re: Focus lost event with hyperlink in Browser [message #1386536 is a reply to message #1386524] Wed, 18 June 2014 03:51 Go to previous message
no... FocusOut *must* be fired before the focus control is switched (bug
will be fixed soon). This is the correct logic and this is how SWT works.
Best,
Ivan
Ivan Furnadjiev
Previous Topic:Nice way to get a lazy loaded, session scoped model (MVC)
Next Topic:[ANN] RAP 2.3RC1 available for download
Current Time: Sun Jul 27 22:25:54 EDT 2025
Powered by FUDForum. Page generated in 0.09379 seconds
