Home » Eclipse Projects » Eclipse 4 » Decorating in e4(Is there an equivalent to DecoratorManager in e4)
Decorating in e4 [message #987927] Wed, 28 November 2012 11:47 Go to next message
Is there anything similar to the 3.x workbench DecoratorManager in e4, or do I need to roll my own?
[Updated on: Wed, 28 November 2012 13:22] by Moderator
Re: Decorating in e4 [message #1373757 is a reply to message #987927] Thu, 22 May 2014 06:01 Go to previous messageGo to next message
I also have the problem that I cannot use the ILabelDecorator, which is provided by the DecoratorManager. As the DecoratorManager uses PlatformUI in its constructor, there is no way to use it.
Re: Decorating in e4 [message #1375760 is a reply to message #1373757] Fri, 23 May 2014 01:49 Go to previous messageGo to next message
It seems that this feature shouldn't be used any more, as there is the possibility to define the styling with a CSS-file. With CSS it should be possible the specially define stylings.
The disadvantage of this way is that decorations are not possible any more, especially for images. I had to copy and adapt some images to get the decoration effect back, but it is only a replacment of images, not a decoration.
Re: Decorating in e4 [message #1375843 is a reply to message #1375760] Fri, 23 May 2014 02:33 Go to previous message
I don't think you can replace that easily with CSS - I'd rather say that
someone should take a the code and make it available from a bundle that
does not require the compat layer.
Tom
Previous Topic:Constructor of Part is being called twice
Next Topic:p2 Update error when using the delta pack
Current Time: Sun Jul 20 22:01:38 EDT 2025
Powered by FUDForum. Page generated in 0.28247 seconds
