Home » Eclipse Projects » Eclipse Platform » Extension point no extensible is same plugin ?
Extension point no extensible is same plugin ? [message #137307] Mon, 29 September 2003 06:00 Go to next message
I've create an extension point in my plugin (under development).
It's seems that I can't extends this point in same plugin, plugin.xml
parser
barks "Unknown Extension Point:..."
It is a limitation of the plugin engin ?
Arnaud.
Re: Extension point no extensible is same plugin ? [message #137590 is a reply to message #137307] Mon, 29 September 2003 15:02 Go to previous messageGo to next message
No. Maybe you might have misspelt your extension point name.
For e.g.
<extension-point id="statuschangelisteners" name="XYZ Change Status
Listener"
schema="schema/statuslistener.exsd"/>
<extension
point="xyz.statuschangelisteners">
<statuschangelistener
class="xyz.views.MyStatusChangeListener">
</statuschangelistener>
</extension>
xyz is the name of the plugin
HTH, Balaji
"Arnaud" <ademuyser@fr.ibm.com> wrote in message
news:bl8vr3$cbn$1@eclipse.org...
> parser
> Arnaud.
Re: Extension point no extensible is same plugin ? [message #137746 is a reply to message #137590] Tue, 30 September 2003 04:22 Go to previous messageGo to next message
Thanks a lot Balaji !
I'd just to know the extension must start attribute point with the plugin
id 'xyz' before name.
In addition extension-point id seems to no support '.' character in their
names.
Thanks.
> For e.g.
> Listener"
> <extension
> </extension>
> HTH, Balaji
> > parser
> > Arnaud.
Re: Extension point no extensible is same plugin ? [message #137924 is a reply to message #137746] Tue, 30 September 2003 10:51 Go to previous messageGo to next message
Originally posted by: richkulp.NO--SPAM.us.ibm.com
It would be helpful to append the definition of the extension point and
the usage of the extension point and the header element from your
plugin.xml so that we can see if there is semantic error here.
Rich
Re: Extension point no extensible is same plugin ? [message #138051 is a reply to message #137746] Tue, 30 September 2003 12:41 Go to previous messageGo to next message
I am curious, why would you want the plugin that provides the extension
point to extend itself via an extension in the plugin.xml? Couldn't you just
code it to do this without declaring it as an extension?
news:blbegs$poa$1@eclipse.org...
> names.
> Thanks.
> > For e.g.
> > Listener"
> > <extension
> > </extension>
> > HTH, Balaji
> > > parser
> > > Arnaud.
Re: Extension point no extensible is same plugin ? [message #138402 is a reply to message #138051] Wed, 01 October 2003 09:01 Go to previous messageGo to next message
Originally posted by: Andre_Weinand.oti.com
On 30.9.2003 18:41 Uhr, in article blcbck$p56$1@eclipse.org, "Kevin"
That's one of Eclipse's fundamental design principles:
Whenever we open up an implementation (by creating a new extension point) so
that others can provide their own extensions, we play by the same rules and
use that extension point ourselves. There should be no first class
citizens...
--andre
Re: Extension point no extensible is same plugin ? [message #138704 is a reply to message #138402] Wed, 01 October 2003 23:39 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
"Andre Weinand" <Andre_Weinand@oti.com> wrote in message
news:BBA09CB5.1E9E5%Andre_Weinand@oti.com...
so
and
> citizens...
But adherence isn't 100%, is it? Does Eclipse (the team) have a count of the
instances where Eclipse (the software) violates the rule? No measure, no
management.
Bob Foster
Re: Extension point no extensible is same plugin ? [message #139180 is a reply to message #138704] Thu, 02 October 2003 16:51 Go to previous message
On 2.10.2003 5:39 Uhr, in article blg5mk$rc5$1@eclipse.org, "Bob Foster"
> so
> and
>> citizens...
> management.
Sure, for this rule: 0
--andre
Previous Topic:Help
Next Topic:How to browse JDK Java Documentation from Eclipse
Current Time: Mon Jun 09 01:57:31 EDT 2025
Powered by FUDForum. Page generated in 0.10965 seconds
