| paintedItemListener behavior in CTableTree [message #13683] |
Mon, 09 October 2006 13:08  |
Originally posted by: alnospammajor.noboxspamspoon.com
it appears that paintedItemListener can be called before the
corresponding item (cell) is intialized. is this expected behavior? or a
bug?
al
| Re: paintedItemListener behavior in CTableTree [message #13769 is a reply to message #13726] |
Tue, 10 October 2006 14:25  |
> I think the bigger problem here is that cells do not have a well defined
> series of life-cycle events (partly because once you and Cal started
> using them, it became apparent that the initial sequence was inadequate
agreed. i guess that's why the widget is alpha ;-).
> :) ). This problem is also at the heart of your other issue with
> getting events for your viewers' creation and disposal, and even the
> order in which they initialize.
ya. what i'll do is attempt to get everything working in some fashion,
possibly with changes to the widget/viewer sources. then i'll have a
better sense of all the problems and potential solutions.
> Please file a bug for this and add your thoughts on what will suit your
> use cases best.
hopefully i'll be able to do the above and file the bug within a week.
al
| Re: paintedItemListener behavior in CTableTree [message #566491 is a reply to message #13683] |
Tue, 10 October 2006 08:41  |
This is certainly possible behavior...
These events are fired when the container updates its internal
"paintedItems" list by determining which items will be painted to the
screen and which will not. Depending on the implementation, the cell
may wait to initialize until it is painted, in which case
paintedItemListener is called before it is ready to actually be painted.
use cases best.
> bug?
> al
| Re: paintedItemListener behavior in CTableTree [message #566564 is a reply to message #13726] |
> use cases best.
al
FUDForum. Page generated in 0.03327 seconds
