Home » Language IDEs » ServerTools (WTP) » WTP 0.7 - Export Preferences - Regression ??
WTP 0.7 - Export Preferences - Regression ?? [message #136285] Thu, 01 September 2005 20:06 Go to next message
Originally posted by: laurentd75___no.sp_am.yahoo.fr
In WTP 1.0 M3 through M5, you could export and import back many workspace
preferences through the "Import" and "Export" buttons in the Preferences
dialogue.
In WTP 0.7, this functionality was moved to the "File > Export" and "File >
Import" wizards, where you have to select the "Preferences" item (I suspect
this is really a change in the Eclipse platform final release itself, not in
WTP... Took me a while to figure this out anyway, though I supposee the
change was documented somewhere ).
In any case, there seems to be a regression here:
In the earlier milestones, the Preferences import/export seemed to work
quite well, and allowed for saving/loading most preferences, including
WTP-related ones, not just those of Eclipse.
By contrast, the capability is much more limited in Eclipse 3.1 + WTP0.7:
you get an additional dialogue where you can elect to save all preferences
or choose amongst a list, but the list only includes preferences related to
CVS repositories, installed JREs, and keyboard shortcuts. Whatever the
option you choose, you will lose many preferences when exporting, including
preferences related to WTP.
Is anybody aware of this ? Is there a particular reason for this limitation,
and any plans to overcome it in a future milestone ? Do I need to fill in a
bug report, and if so, against which component ?
Laurent
Re: WTP 0.7 - Export Preferences - Regression ?? [message #136354 is a reply to message #136285] Fri, 02 September 2005 09:27 Go to previous messageGo to next message
Hi Laurent,
Many of the WTP preference pages still include import/export buttons. For
example you can import/export CSS Templates, DTD Templates, HTML
Templates, JSP Templates, XML Catalog entries, and XML Templates. Perhaps
these need to be converted to use the global preference expoert. However,
using the global export preferences function (as you suggest) only allows
me to export the installed JREs preference, suggesting this is either new
or old functionality.
I'm not sure which approach should be followed at this point. Please go
ahead and open a bug report against the Web Standard Tools component and
someone will have a look. (BTW, if you're not sure which component to use
when opening a bug just guess. The bug will be reassigned as required.)
Lawrence
Re: WTP 0.7 - Export Preferences - Regression ?? [message #137184 is a reply to message #136354] Wed, 07 September 2005 21:01 Go to previous message
Lawrence Mandel wrote:
> Hi Laurent,
Hi Lawrence,
As usual, I found your feedback very valuable and I'd like to thank you for
that and for your quick response.
You are absolutely right in pinpointing the import/export buttons on some
WTP Preferences pages, but I personally think that this approach is not the
way to go, because it only leads to Preference file clutter. If one only
wants to save selected Preferences, then the "Export checked preferences
only" option in "File > Export > Preferences" seems a much neater approach
to me.
In any case, I have now filed this issue as bug report #109015 on BugZilla.
Thanks again for your feedback & advice,
Laurent
Previous Topic:Web Services Explorer Error - attribute 'ref' is not permitted
Next Topic:Manipulating the DOM model and keeping in sync with it
Current Time: Mon Jun 09 00:03:32 EDT 2025
Powered by FUDForum. Page generated in 0.03488 seconds
