Home » Eclipse Projects » Remote Application Platform (RAP) » Nebula CompositeTable support
Nebula CompositeTable support [message #1371568] Wed, 21 May 2014 08:35 Go to next message
Does RAP support CompositeTable from nebula?
If it does not, is there any other widget supported that would allow a similar behaviour like Jlist. In the sense that JList displays Composites and List widgets can only display text or images?
Thanks in advance,
Javi
Re: Nebula CompositeTable support [message #1371627 is a reply to message #1371568] Wed, 21 May 2014 09:12 Go to previous messageGo to next message
Nebila CompositeTable is not ported to RAP. We have a bug opened:
293983: Port Nebula's CompositeTable to RAP
https://bugs.eclipse.org/bugs/show_bug.cgi?id=293983
but it seems that the interest (votes) is small.
If you need flexible Table/Tree row layout only you could use row
templates [1].
[1]
http://eclipsesource.com/blogs/2013/11/14/rap-2-2m3-introducing-row-templates/
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Nebula CompositeTable support [message #1385277 is a reply to message #1371627] Thu, 05 June 2014 06:39 Go to previous message
Thanks Ivan, Tempalte Row look quite interesting but unfortunately not for what i need.
At the end i followed the following advise:
Write your own implementation of a custom List, which contains Composite Items.
For instance you could use a org.eclipse.swt.custom.ScrolledComposite and place your custom Composite Items on it.
More info in this post:
https://www.eclipse.org/forums/index.php/mv/msg/768906/1372023/#msg_1372023
Previous Topic:Deployment problems with RAP 2.3 M3
Next Topic:Toolbars in parts not shown (RAP 2.3, Eclipse Luna)
Current Time: Sat Aug 30 23:10:49 EDT 2025
Powered by FUDForum. Page generated in 0.03047 seconds
