null pointer while using ASF... [message #137088] |
Wed, 15 October 2008 12:55  |
Hi, I'm getting a null pointer exception when attempting to run my tests
through the ASF.
I'm using tptp 4.5.0 on eclipse 3.4, and java 1.5, and in my mind I've
convinced myself that this was working correctly when we were previously
running under tptp 4.3 and eclipse 3.2... :-)
My ant debug output is below:
Question 1 - has anyone seen this before that can help me resolve the issue?
Is it something I've done wrong or am missing? Does the stack trace help?
Question 2 - surely it shouldn't be producing an NPE as shown below in any
case?
Many thanks,
Nick
Output:
testjunit:
[echo] Executing JUnit test suite...
parsing buildfile
jar:file:/C:/eclipse/plugins/org.apache.ant_1.7.0.v200803061 910/lib/ant-tptp.jar!/org/eclipse/hyades/automation/client/a dapters/ant/antlib.xml
with URI =
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Automation
loaded from parent loader (parentFirst)
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:aut omation
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Execution
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:exe cution
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Extraction
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:ext raction
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Interrogation
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:int errogation
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Publication
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:pub lication
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Verification
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:ver ification
Class
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$ImportExistingProjects
+Datatype
antlib:org.eclipse.hyades.automation.client.adapters.ant:imp ortExistingProjects
+Datatype antlib:org.eclipse.hyades.automation.client.adapters.ant:tes t
parsing buildfile
jar:file:/C:/eclipse/plugins/org.apache.ant_1.7.0.v200803061 910/lib/tptp-automation-client.jar!/org/eclipse/hyades/autom ation/client/adapters/ant/antlib.xml
with URI =
parsing buildfile
jar:file:/C:/eclipse/plugins/org.apache.ant_1.7.0.v200803061 910/lib/tptp-automation-server.jar!/org/eclipse/hyades/autom ation/client/adapters/ant/antlib.xml
with URI =
fileset: Setup scanner in dir
c:\eclipse_ide\3_4workspace\com.microfocus.eclipse.testconta iner with
patternSet{ includes: [junit_tests/CommentActionTest.testsuite] excludes:
[tptp:execution] Adding file
" c:\eclipse_ide\3_4workspace\com.microfocus.eclipse.testconta iner\junit_tests\CommentActionTest.testsuite ".
[tptp:execution] Test execution started.
[tptp:execution] java.lang.NullPointerException
[tptp:execution] at
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:574)
[tptp:execution] at
org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
[tptp:execution] at
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:139)
[tptp:execution] at
org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
[tptp:execution] at java.lang.Thread.run(Thread.java:595)
BUILD FAILED
c:\eclipse_ide\3_4workspace\com.microfocus.eclipse.testconta iner\test.xml:121:
at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:115)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
at org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
at org.apache.tools.ant.Main.runBuild(Main.java:698)
at org.apache.tools.ant.Main.startAnt(Main.java:199)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
at java.util.Hashtable.get(Hashtable.java:336)
at org.apache.tools.ant.PropertyHelper.setProperty(PropertyHelp er.java:308)
at org.apache.tools.ant.Project.setProperty(Project.java:507)
at
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Execution.execute(AutomationClientAdapter.java :637)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
... 11 more
--- Nested Exception ---
at
at
at
at
Total time: 4 seconds
Re: null pointer while using ASF... [message #137351 is a reply to message #137124] |
Thu, 23 October 2008 05:35   |
Thanks Paul,
After a bit of tinkering (and your pointers!) I did get it working as it was
looking for the project/results in a different directory to where I thought
it was. Now I just have to figure out why my tests take much longer to run
in this manner and hang half way through! Ho hum :)
BTW, (you can never take the tester out of the tester!) from the dumb user
perspective, wouldn't it be better to return an error stating as much rather
that just throwing a null pointer. Is there any value in creating a bugzilla
report for this?
Thanks!
Nick
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:gd75gr$5vs$1@build.eclipse.org...
> Hi Nick,
> The first NPE (AbstractTestExecutionService.java:574) is caused by the
> ASF trying to resolve the directory location of the results file(s) based
> on the path of the 'project' property specified in your ANT script. Is
> this path correct, based on the current workspace?
> The second NPE (Hashtable.java:336) is caused by the ASF not resolving
> the 'results' property specified in your ANT script. Is this path
> Paul
> "Nick Young" <Nicholas.Young@microfocus.com> wrote in message
> news:gd57bg$db3$1@build.eclipse.org...
>> through the ASF.
>> issue? Is it something I've done wrong or am missing? Does the stack
>> trace help?
>> any case?
>> Many thanks,
>> Nick
>> Output:
>> testjunit:
>> parsing buildfile
>> with URI =
>> Class
>> +Datatype
>> Class
>> +Datatype
>> Class
>> +Datatype
>> Class
>> +Datatype
>> Class
>> +Datatype
>> Class
>> +Datatype
>> Class
>> +Datatype
>> parsing buildfile
>> with URI =
>> parsing buildfile
>> with URI =
>> [tptp:execution] at
>> [tptp:execution] at
>> [tptp:execution] at
>> [tptp:execution] at
>> BUILD FAILED
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 11 more
>> at
>> at
>> at
>> at
>> at
Re: null pointer while using ASF... [message #137374 is a reply to message #137351] |
Thu, 23 October 2008 07:36  |
Hi Nick,
There should only be a <20% increase in the time required to run your
tests using the ASF and they should never hang.
Regarding the confusing exceptions thrown by ASF, please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=217487. You may want to
comment and/or add your name to the CC list.
Paul
news:gdpgir$b3k$1@build.eclipse.org...
> Thanks Paul,
> was looking for the project/results in a different directory to where I
> thought it was. Now I just have to figure out why my tests take much
> longer to run in this manner and hang half way through! Ho hum :)
> rather that just throwing a null pointer. Is there any value in creating a
> bugzilla report for this?
> Thanks!
> Nick
>> Hi Nick,
>> Paul
>>> through the ASF.
>>> trace help?
>>> any case?
>>> Many thanks,
>>> Nick
>>> Output:
>>> testjunit:
>>> parsing buildfile
>>> with URI =
>>> Class
>>> +Datatype
>>> Class
>>> +Datatype
>>> Class
>>> +Datatype
>>> Class
>>> +Datatype
>>> Class
>>> +Datatype
>>> Class
>>> +Datatype
>>> Class
>>> +Datatype
>>> parsing buildfile
>>> with URI =
>>> parsing buildfile
>>> with URI =
>>> excludes: [] }
>>> [tptp:execution] at
>>> [tptp:execution] at
>>> [tptp:execution] at
>>> [tptp:execution] at
>>> BUILD FAILED
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 11 more
>>> at
>>> at
>>> at
>>> at
>>> at
FUDForum. Page generated in 0.03786 seconds
