Home » Modeling » GMF (Graphical Modeling Framework) » Change color EditPolicy
Change color EditPolicy [message #137094] Mon, 18 June 2007 11:53 Go to next message
Hi All,
I'm trying to change the colors of nodes programmatically. I've followed
this description but haven't gotten it to work:
http://www.sagewire.org/gmf-modeling-eclipse/changing-connec tion-color-programtically-352798.aspx
I've put in some flags and the code is being executed but the color isn't
changing.
I'm calling the EditPolicy with an OpenRole (double click), does it matter
how the EditPolicy is called or am I missing something really obvious?
Gaff
public class ColorEditPolicy extends OpenEditPolicy {
protected Command getOpenCommand(Request request) {
EditPart targetEditPart = getTargetEditPart(request);
if (targetEditPart instanceof IGraphicalEditPart == false)
return null;
IGraphicalEditPart editPart = (IGraphicalEditPart) targetEditPart;
EObject modelElement = editPart.resolveSemanticElement();
System.out.println("Flag1");
Command ret = null;
ChangePropertyValueRequest req = new ChangePropertyValueRequest(
StringStatics.BLANK, Properties.ID_LINECOLOR,
FigureUtilities.colorToInteger(DiagramColorConstants.red));
System.out.println("Flag2");
final Command cmd = editPart.getCommand(req);
System.out.println("Flag3");
AbstractEMFOperation operation = new
AbstractEMFOperation(((IGraphicalEditPart) editPart).getEditingDomain(),
StringStatics.BLANK, null) {
protected IStatus doExecute(IProgressMonitor monitor, IAdaptable
info)throws ExecutionException {
cmd.execute();
return Status.OK_STATUS;
System.out.println("Flag4");
try {
operation.execute(new NullProgressMonitor(), null);
} catch (ExecutionException e) {
// nothing to do here
return ret;
Re: Change color EditPolicy [message #137226 is a reply to message #137094] Mon, 18 June 2007 21:06 Go to previous message
Originally posted by: khai.n.situvista.com
Not sure what you're trying to do with the code below but this code works:
if (getHost() instanceof IGraphicalEditPart) {
ChangePropertyValueRequest(StringStatics.BLANK,
return getHost().getCommand(req);}
return null;
-- Khai --
Gaff wrote:
> Hi All,
> isn't changing.
> matter how the EditPolicy is called or am I missing something really
> obvious?
> Gaff
> @Override
> EditPart targetEditPart = getTargetEditPart(request); if
> return null;
> Command ret = null;
> IAdaptable info)throws ExecutionException {
> cmd.execute();
> try {
> return ret;
Previous Topic:Custom position for label
Next Topic:Removing default Note connection functionality
Current Time: Thu Nov 06 02:41:57 EST 2025
Powered by FUDForum. Page generated in 0.03588 seconds
