Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] what about cross-references of a merged eObject ?
[EMF Compare] what about cross-references of a merged eObject ? [message #137012] Tue, 09 June 2009 07:56 Go to next message
I am doing some trails on EMF Compare with the EMF ExtLibrary example.
When we select an object from the right-side to copy on to the left-side
(using the Compare UI) ... the cross-references of the old object are not
reflected on its copy.
Let's say there are 2 library instances.
Litrary01 (leftside): no books
Library02: has a book which is associated with an author.
When i copy the book from right to left, the author is not included. It
seems fine but infact i feel the merge can be more smart in copying the
cross-references of the copy object to the destination tree.
Does EMF Compare provide such a merge functionality off the shelf ? or
can we use an extension-point to tweak only this part of the merge.
- Chetan Kumar
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #137072 is a reply to message #137012] Tue, 09 June 2009 12:27 Go to previous messageGo to next message
--------------010309000601020706030502
Hi Chetan,
This behavior is intentional. We don't copy cross references to non
existing objects (some people might want it, some others not as all use
cases don't apply to one case or the other).
If you copy the book, its reference towards an author is not copied
alongside it. If you then copy the author, the reference should be
restored as it should.
You can tweak this part of the merge by overriding the existing mergers
(see extension point org.eclipse.emf.compare.diff.mergerprovider ).
Laurent Goubet
Obeo
Chetan Kumar a
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #137248 is a reply to message #137072] Sun, 14 June 2009 14:07 Go to previous message
Hello Laurent,
Thank you for yer response.
That makes sense.
laurent Goubet wrote:
> Hi Chetan,
> Laurent Goubet
> Obeo
> Chetan Kumar a écrit :
>> Hi,
>> not reflected on its copy.
>> Library02: has a book which is associated with an author. When i copy
>> the book from right to left, the author is not included. It seems fine
>> - Chetan Kumar
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #621005 is a reply to message #137012] Tue, 09 June 2009 12:27 Go to previous message
Hi Chetan,
Laurent Goubet
Obeo
Chetan Kumar a
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #621020 is a reply to message #137072] Sun, 14 June 2009 14:07 Go to previous message
Hello Laurent,
That makes sense.
> Hi Chetan,
> Laurent Goubet
> Obeo
>> Hi,
>> - Chetan Kumar
Previous Topic:EEF: When will this link go somewhere: The project has been created. Please visit the project page
Next Topic:EMF Index Project
Current Time: Fri Jul 18 02:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.06569 seconds
