Home » Archived » Maven Integration (M2E) » stable dev build 0.9.6.20080731-1407 is published
stable dev build 0.9.6.20080731-1407 is published [message #13645] Thu, 31 July 2008 17:03 Go to next message
We have published stable development build 0.9.6.20080731-1407. You
can install it from the dev update site at
http://m2eclipse.sonatype.org/update-dev/
This build includes number of bug fixes for the Form-based POM editor.
See list of fixed issues in JIRA at http://tinyurl.com/6rhdwr
We made performance improvements for Eclipse startup. Now state of
resolved dependencies is persisted and then loaded on Eclipse startup,
which allowed to skip costly Maven dependency resolution. Note that if
you'll make changes in your projects while Eclipse were down, saved
state will be out of sync and you will need to manually force update for
Maven dependencies, either from project Maven menu for selected
projects, of globally for all projects using the "Update All Maven
dependencies" action from main Project menu.
There is also few new features, such as SCM handler and UI for Eclipse
Team CVS, filter in the Package Explorer view for Maven modules and
working set support in all wizards. You can see complete New and
Noteworthy features for this and previous builds on the wiki at
http://docs.codehaus.org/display/M2ECLIPSE/New+and+Noteworth y
As always, we would like to hear your feedback. Please don't hesitate
to share your thoughts in the news group and mailing lists, submit bug
reports to the project issue tracker [1] and contribute to project
documentation on the wiki [2].
m2eclipse team
[1] http://jira.codehaus.org/browse/MNGECLIPSE
[2] http://docs.codehaus.org/display/M2ECLIPSE
How to enable maven dependencies programmatically [message #13666 is a reply to message #13645] Fri, 01 August 2008 12:54 Go to previous messageGo to next message
Originally posted by: chingyichan.tw.gmail.com
I create a plugin to create the java project which contains the pom.xml
file. User can make choice to enable maven dependencies.
How do I do to make it in programmatic way ?
Re: How to enable maven dependencies programmatically [message #13708 is a reply to message #13666] Fri, 01 August 2008 15:21 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Have a look at
org.maven.ide.eclipse.project.IProjectConfigurationManager#e nableMavenNature
The most basic way to use it is
IProjectConfigurationManager configurationManager =
MavenPlugin.getDefault().getProjectConfigurationManager();
ResolverConfiguration configuration = new ResolverConfiguration();
configurationManager.enableMavenNature(project, configuration, monitor);
chingyichan wrote:
> Hello,
Re: How to enable maven dependencies programmatically [message #13749 is a reply to message #13708] Fri, 01 August 2008 23:27 Go to previous message
Igor Fedorenko 提到:
> Have a look at
> chingyichan wrote:
>> Hello,
>> pom.xml file. User can make choice to enable maven dependencies.
Thanks a lot. It work well !
I check out the source code, and extract some codes to make a method:
* enable project maven dependency management
* @param project the project must has pom.xml
* @throws CoreException
private void enableMavenDependencyManagement(IProject project)
throws CoreException {
configuration.setIncludeModules(false);
configuration.setResolveWorkspaceProjects(true);
configuration.setActiveProfiles("");
boolean hasMavenNature = project.hasNature(IMavenConstants.NATURE_ID);
IProjectConfigurationManager configurationManager = MavenPlugin
UIUtilz.NULL_PROGRESS_MONITOR);
if (!hasMavenNature) {
configurationManager.updateProjectConfiguration(project,
configuration, MavenPlugin.getDefault()
.getMavenRuntimeManager().getGoalOnUpdate(),
new NullProgressMonitor());
Previous Topic:Is m2eclipse use archetype:generate to create project ?
Next Topic:m2eclipse on twitter
Current Time: Wed Sep 03 03:31:02 EDT 2025
Powered by FUDForum. Page generated in 0.06563 seconds
