Home » Archived » Test and Performance Tools Platform (TPTP) » Crash when trying to profile osgi application
| Crash when trying to profile osgi application [message #136110] |
Tue, 23 September 2008 17:44  |
I am trying to use TPTP version 4.5 to profile an osgi application.
I downloaded the latest TPTP plugin from the eclipse update service. I am
using the IAC. The connection to the IAC seems to work, because when I go
to Preferences->Agent Controller->Hosts and click Test Connection, it says
"connection success". I am running on WindowsXP, java 1.6u6, and eclipse
Ganymede.
I have created a Profile Configuration for my application that should
monitor threads. The application starts as normal, then just stops
running. The only thing I see in my .log file is:
!ENTRY org.eclipse.tptp.platform.common.ui.trace 0 0 2008-09-23
17:43:02.984
!MESSAGE Processed: 224901 bytes, bytes/second: 74967, events processed:
0, events/second: 0, elapsed time: 3 seconds
17:43:03.000
I would really appreciate any pointers as to where to look to figure out
why this isn't working. Thanks.
| Re: Crash when trying to profile osgi application [message #136289 is a reply to message #136110] |
Wed, 24 September 2008 19:16   |
> am using the IAC. The connection to the IAC seems to work, because when
> I go to Preferences->Agent Controller->Hosts and click Test Connection,
> it says "connection success". I am running on WindowsXP, java 1.6u6,
> and eclipse Ganymede.
> 17:43:02.984
> 17:43:03.000
After playing around a bit more, I am seeing this stack trace in the
workspace's .log file. I notice that I only get the stack trace the
first time I try to profile my application after I start eclipse. The
next times I try to profile the application, nothing appears in this log
file. I can only reproduce this error if I restart eclipse and try to
profile the application again.
!SESSION 2008-09-24 19:08:47.640
eclipse.buildId=I20080617-2000
java.version=1.6.0_07
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2008-09-24 19:08:52.843
!MESSAGE Could not load repository template extension repository
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.656
!MESSAGE Can't find bundle for base name feature, locale en_US
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.718
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.734
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.750
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.765
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.781
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.796
!ENTRY org.eclipse.update.configurator 4 0 2008-09-24 19:09:29.812
!ENTRY org.eclipse.osgi 2 0 2008-09-24 19:09:34.828
!MESSAGE While loading class
"org.eclipse.hyades.trace.ui.internal.core.TraceUIImages", thread
"Thread[main,6,main]" timed out waiting (5000ms) for thread
"Thread[Worker-5,5,main]" to finish starting bundle
" reference:file:plugins\org.eclipse.hyades.trace.ui_4.4.101.v 200806130100.jar
[869]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding
but "org.eclipse.hyades.trace.ui.internal.core.TraceUIImages" may not be
fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
" reference:file:plugins\org.eclipse.hyades.trace.ui_4.4.101.v 200806130100.jar "
by thread "Worker-5".
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1144)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:263)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.hyades.trace.ui.UIPlugin$1.run(UIPlugin.java:404 )
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 38 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.tptp.platform.common.ui.trace 0 0 2008-09-24 19:09:45.718
!MESSAGE Processed: 231087 bytes, bytes/second: 77029, events processed:
!ENTRY org.eclipse.tptp.platform.common.ui.trace 0 0 2008-09-24 19:09:45.750
| Re: Crash when trying to profile osgi application [message #136377 is a reply to message #136289] |
Thu, 25 September 2008 16:02   |
>> I am trying to use TPTP version 4.5 to profile an osgi application. I
>> when I go to Preferences->Agent Controller->Hosts and click Test
>> Connection, it says "connection success". I am running on WindowsXP,
>> java 1.6u6, and eclipse Ganymede.
>> 17:43:02.984
>> processed: 0, events/second: 0, elapsed time: 3 seconds
>> 17:43:03.000
>> out why this isn't working. Thanks.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> fully initialized.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 38 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 19:09:45.718
> 19:09:45.750
It seems that I'm have a problem that is similar to Nick's:
http://dev.eclipse.org/newslists/news.eclipse.tptp/msg06589. html
I've looked around on the TPTP bugzilla and can't find any reference to
this problem. Is anyone else having a similar problem?
| Re: Crash when trying to profile osgi application [message #136424 is a reply to message #136377] |
Fri, 26 September 2008 17:04   |
Hi Kyle,
It does look like you have a corrupted workbench that TPTP plugins cannot be
loaded properly. Please try a new driver and run your scenario again.
Eugene
"Kyle Neumeier" <kyle@pramari.com> wrote in message
news:gbgqnu$gt6$1@build.eclipse.org...
>>> go to Preferences->Agent Controller->Hosts and click Test Connection, it
>>> says "connection success". I am running on WindowsXP, java 1.6u6, and
>>> eclipse Ganymede.
>>> 17:43:02.984
>>> 17:43:03.000
>> !SESSION 2008-09-24
>> 19:08:47.640 -----------------------------------------------
>> [869]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but
>> fully initialized.
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Caused by:
>> ... 38 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 19:09:45.718
>> 19:09:45.750
| Re: Crash when trying to profile osgi application [message #136584 is a reply to message #136424] |
Wed, 01 October 2008 16:50   |
Eugene,
Thanks for responding. What do you mean by a new "driver"? I have
tried deleting my eclipse installation, downloading a new one, and
reinstalling the TPTP plugins with no success.
Kyle
Eugene Chan wrote:
> Hi Kyle,
> Eugene
>>>> eclipse Ganymede.
>>>> 17:43:02.984
>>>> 17:43:03.000
>>> !SESSION 2008-09-24
>>> fully initialized.
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> ... 38 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> 19:09:45.718
>>> 19:09:45.750
| Re: Crash when trying to profile osgi application [message #136657 is a reply to message #136584] |
Thu, 02 October 2008 10:14  |
Hi Kyle,
When you said your application stop working, does it crash (with any dump
files) or simply frozen?
What kind of profiling filter did you setup in your profile? Could you copy
them here?
Eugene
news:gc0nqd$8g4$1@build.eclipse.org...
> Eugene,
> Thanks for responding. What do you mean by a new "driver"? I have tried
> deleting my eclipse installation, downloading a new one, and reinstalling
> Kyle
> Eugene Chan wrote:
>> Hi Kyle,
>> be loaded properly. Please try a new driver and run your scenario again.
>> Eugene
>>>>> 17:43:02.984
>>>>> 17:43:03.000
>>>> log file. I can only reproduce this error if I restart eclipse and try
>>>> to profile the application again.
>>>> !SESSION 2008-09-24
>>>> be fully initialized.
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> ... 38 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> 19:09:45.718
>>>> 19:09:45.750
Current Time: Sun Oct 26 15:00:45 EDT 2025
Powered by FUDForum. Page generated in 0.04544 seconds
