Home » Archived » Hudson » Is there a function in perforce pluggin to resolve MAXSCANLINE issue?
icon5.gif  Is there a function in perforce pluggin to resolve MAXSCANLINE issue? [message #1356241] Wed, 14 May 2014 22:41 Go to next message
I meet a big problem when using perforce pluggin to sync code tree to local. The code tree is too big, it over the MaxScanLine limitation. My solution is to split the whole tree into several sync tasks, narrow the one-time sync scope. But it is not a smart way, sometimes maybe with code tree growth, one task scope may hit this limitation again. Then I need split to more pieces.
There is another bug, when sync code hit the limitation, Hudson doesn't pop up Error, and still list un-synced check-in out. It seems like work fine as normal. It hidden the issue.
Is there another way to resolve this MaxScanLine issue? The version of perforce plug-in is 1.3.23-h-1.
Re: Is there a function in perforce pluggin to resolve MAXSCANLINE issue? [message #1357642 is a reply to message #1356241] Thu, 15 May 2014 12:17 Go to previous messageGo to next message
Unfortunately I don't have perforce working knowledge. So I asked Konstantin who uses Perforce with Hudson at Oracle. Following is his reply.
Typically, if you cannot sync a p4 workspace from scratch without running into the file count limit, the workspace should be split into multiple workspaces/jobs. Depending on his particular circumstances, perhaps a pipeline of jobs to build components in series or separate jobs for different branches. In perforce, a branch is just a different folder, so it's possible to create a single workspace that has all your branches, but that's rarely advisable.
- Konstantin
Re: Is there a function in perforce pluggin to resolve MAXSCANLINE issue? [message #1358594 is a reply to message #1357642] Thu, 15 May 2014 21:58 Go to previous message
Thanks Winston.
Yes I have used that solution to split whole tree syncing into several jobs. If below is the whole tree,
MAIN
-- component1
-- component2
-- component3
Then I create 3 jobs to sync these 3 sub-folders to local separately. There is potential issue, the component1 may hit the MAXSCANLINE limitation again with the code tree growth. Then,
MAIN
-- component1
---- sub-component1
---- sub-component2
---- sub-component3
-- component2
-- component3
I need create more jobs to split component1 again.
In here we just talk about sync code, for the compiling, I can create soft link to get all folders together and start fully compiling.
I maintain the daily build compiling, I meet this issue two times, May I suggest improve perforce pluggin?
a, Report ERROR when sync code hit MAXSCANLINE limitation.
b, or goto further, when hit MAXSCANLINE limitation, auto sync the sub-folders seperately. The MAXSCANLINE only against one-time sync.
THanks Again.
[Updated on: Thu, 15 May 2014 21:59] by Moderator
Previous Topic:Update Sonar Plugin in Hudson to version 2.2
Next Topic:Passing a Parameter in the URL
Current Time: Wed Jul 23 04:50:50 EDT 2025
Powered by FUDForum. Page generated in 4.86320 seconds
