TPTP 4.5 Profiling crash (Sun, Vista) [message #135783] |
Tue, 16 September 2008 07:21  |
Environment:
- Windows Vista SP1
- Eclipse 3.4
- TPTP 4.5
- Sun JRE 1.6.0_07 or Sun JDK 1.5.0_15
Goal:
Profile own bundles in an Equinox framework based project.
Problem:
I never used TPTP before. (Could be part of the problem as well.)
When I try it, it consistently causes VM crash at launch of the project.
"Java2 SE 1.5 platform doesn't work anymore".
Unhandled exception at 0x770681cb in java.exe:
0xC0000005: Access violation reading location 0x00000004.
Already tried:
- Both Sun VM versions 1.5 and 1.6.
I took the same VM for Eclipse as for the Run.
- Tried to follow the TPTP installation procdure in detail.
Most is about Agent installer, but I suppose I use IAC.
- Forum suggested IBM SDK iso Sun,
but that's not available on a non-IBM machine.
- Verified necessary agent ports in firewall.
They seem to be open.
- Looked for updates, none available (dd. 2008-09-14).
- Browsed through numerous news articles (dev.eclipse.org) all pointing
out this or similar issue but without solutions.
- Looked for similar Bugzilla entry.
Question:
This looks like an 'out-of-the-box' scenario to me.
What to investigate next?
Any information that you would like me to produce?
Johan
Re: TPTP 4.5 Profiling crash (Sun, Vista) [message #553629 is a reply to message #136020] |
Wed, 18 August 2010 04:48  |
Hello !
I'm using Eclipse 3.5 and java 1.6.0_06 and I'm experimenting same kind of problems on Windows XP 32 bits.
First time I launched TPTP Profiling for my project (v4.3), It worked.
But the next time, launch blocked at 51% and a message told me Java.exe had a problem that forced it to quit. I had to kill Eclipse to use it again.
Since that moment, the same crash occures and I can't use TPTP.
I tried in a new workspace -> same problem.
I tried with different versions of TPTP (from 4.3 to 4.6.2) -> not better.
As I'm using EMF 2.5, I didn't try with TPTP 4.7 which requires Helios which requires EMF 2.6 (means some work to make my code compile).
I'm also using Guice 2.0 so as explained here, I have to use this option : -Xverify:none
I tried on a simpler project (no EMF and Guice, just simple Java), It worked.
Can you help me ?
It'll be great to use TPTP Profiling with my EMF + Guice project !
Thanks ;p
[Updated on: Wed, 18 August 2010 04:55] by Moderator
FUDForum. Page generated in 0.03756 seconds
