Home » Archived » BIRT » BIRT bug when adding a parameter to a data set(Adding a parameter that is linked to the a Report Parameter changes the type)
BIRT bug when adding a parameter to a data set [message #1355732] Wed, 14 May 2014 17:35 Go to next message
I am not sure where to report bugs, but I will add it here. If you add "parameter" to a Data Set of a certain data type, ie Integer, and map it to a Report Parameter that is also Integer, it changes the Report Parameter type to string for some reason.
I always have to go back into the Report Parameters when adding linked data set parameters and fix the data types. Editing parameters does not have this impact, but just adding them new.
Re: BIRT bug when adding a parameter to a data set [message #1371815 is a reply to message #1355732] Wed, 21 May 2014 10:55 Go to previous message
Hi Brian! You can report bugs here
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=BIRT ...I think this
one is already reported but if not, that's where you can file it.
Thanks! :)
Previous Topic:Using new Docx Emitter programmatically
Next Topic:Preview web viewer
Current Time: Wed Jul 23 04:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.10248 seconds
