Home » Eclipse Projects » Eclipse Scout » Rap login problem(Rap and DataSourceSecurityFilter)
Rap login problem [message #1354439] Wed, 14 May 2014 04:56 Go to next message
I have an Scout (Kepler sr2) appllication with an SWT client. It uses DataSourceSecurityFilter for authorisation and that works fine.
Now they asked me to make it available through the web so I want to use RAP client for this but I cannot make the security work. I tried every hint I could find in the forum and in the documentation but it does not work.
When I start the app, I get an Login Dialog. (One from the browser, not from RAP) When correct credentials are entered I get an error.
Any ideas?
Browser error message:
HTTP ERROR: 500
Problem accessing /web. Reason:
    Server Error
Logging from my Eclipse Console:
!ENTRY org.eclipse.scout.rt.ui.rap 4 0 2014-05-14 10:31:59.869
!MESSAGE org.eclipse.scout.rt.ui.rap.login.internal.InternalNetAuthenticator.getPasswordAuthentication(InternalNetAuthenticator.java:74) http://localhost:8080/scarabee/ajax
!STACK 0
	at org.eclipse.scout.rt.ui.rap.login.internal.InternalNetAuthenticator.showModalDialog(InternalNetAuthenticator.java:102)
	at org.eclipse.scout.rt.ui.rap.login.internal.InternalNetAuthenticator.getPasswordAuthentication(InternalNetAuthenticator.java:71)
	at org.eclipse.scout.net.internal.InternalEclipseAuthenticator.reflectPasswordAuthentication(InternalEclipseAuthenticator.java:77)
	at org.eclipse.scout.net.internal.InternalEclipseAuthenticator.getPasswordAuthentication(InternalEclipseAuthenticator.java:44)
	at org.eclipse.scout.net.EclipseAuthenticator.getPasswordAuthentication(EclipseAuthenticator.java:31)
	at java.net.Authenticator.requestPasswordAuthentication(Unknown Source)
	at sun.net.www.protocol.http.HttpURLConnection$1.run(Unknown Source)
	at sun.net.www.protocol.http.HttpURLConnection.privilegedRequestPasswordAuthentication(Unknown Source)
	at sun.net.www.protocol.http.HttpURLConnection.getServerAuthentication(Unknown Source)
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
	at java.net.HttpURLConnection.getResponseCode(Unknown Source)
	at org.eclipse.scout.rt.client.servicetunnel.http.internal.HttpBackgroundJob.runStatus(HttpBackgroundJob.java:79)
	at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:172)
	at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:159)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
!ENTRY org.eclipse.scout.rt.client 4 0 2014-05-14 10:31:59.869
!MESSAGE org.eclipse.scout.rt.client.AbstractClientSession.startSession(AbstractClientSession.java:264) load session
!STACK 0
java.lang.reflect.UndeclaredThrowableException
	at $Proxy9.getAllCodeTypeClasses(Unknown Source)
	at org.eclipse.scout.rt.client.services.common.code.CodeServiceClientProxy.getAllCodeTypeClasses(CodeServiceClientProxy.java:342)
	at org.eclipse.scout.rt.client.services.common.code.CodeServiceClientProxy.getAllCodeTypes(CodeServiceClientProxy.java:363)
	at org.eclipse.scout.rt.shared.services.common.code.CODES.getAllCodeTypes(CODES.java:64)
	at nl.rid.scarabee.client.ClientSession.execLoadSession(ClientSession.java:48)
	at org.eclipse.scout.rt.client.AbstractClientSession.startSession(AbstractClientSession.java:259)
	at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService$1.runVoid(ClientSessionRegistryService.java:64)
	at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:189)
	at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
	at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService.createAndStartClientSession(ClientSessionRegistryService.java:68)
	at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService.newClientSession(ClientSessionRegistryService.java:49)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.init(AbstractRwtEnvironment.java:341)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.ensureInitialized(AbstractRwtEnvironment.java:289)
	at org.eclipse.scout.rt.ui.rap.AbstractStandaloneRwtEnvironment.createApplicationContent(AbstractStandaloneRwtEnvironment.java:158)
	at org.eclipse.scout.rt.ui.rap.AbstractStandaloneRwtEnvironment.createUI(AbstractStandaloneRwtEnvironment.java:107)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:177)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:289)
	at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
Caused by: ProcessingException[ProcessingStatus[ERROR code=0 Calling ICodeService.getAllCodeTypeClasses() org.eclipse.scout.rt.shared.servicetunnel.HttpException: 401 - UNAUTHORIZED]]
	at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:163)
	at org.eclipse.scout.rt.client.servicetunnel.http.internal.InternalHttpServiceTunnel.invokeService(InternalHttpServiceTunnel.java:175)
	at org.eclipse.scout.rt.client.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:115)
	at org.eclipse.scout.rt.client.servicetunnel.ServiceTunnelInvocationHandler.invoke(ServiceTunnelInvocationHandler.java:47)
	at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:167)
	... 21 more
Caused by: org.eclipse.scout.rt.shared.servicetunnel.HttpException: 401 - UNAUTHORIZED
	at org.eclipse.scout.rt.client.servicetunnel.http.internal.HttpBackgroundJob.runStatus(HttpBackgroundJob.java:85)
!ENTRY org.eclipse.scout.rt.ui.rap 4 0 2014-05-14 10:31:59.885
!MESSAGE org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.ensureInitialized(AbstractRwtEnvironment.java:292) could not initialize Environment
!STACK 0
	at org.eclipse.ui.internal.Workbench.getWorkbenchWindows(Workbench.java:1512)
	at org.eclipse.scout.rt.ui.rap.util.RwtUtility.getParentShellIgnoringPopups(RwtUtility.java:1618)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.getParentShellIgnoringPopups(AbstractRwtEnvironment.java:1291)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.showClientSessionLoadError(AbstractRwtEnvironment.java:430)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.init(AbstractRwtEnvironment.java:352)
2014-05-14 10:31:59.885:WARN:oejs.ServletHandler:ERROR:  /web
java.lang.SecurityException: Cannot initialize application
	at org.eclipse.scout.rt.ui.rap.AbstractStandaloneRwtEnvironment.createApplicationContent(AbstractStandaloneRwtEnvironment.java:160)
!ENTRY org.eclipse.scout.commons 2 0 2014-05-14 10:40:13.158
!MESSAGE org.eclipse.scout.commons.serialization.SerializationUtility.getBundleOrderPrefixes(SerializationUtility.java:123) bundle order prefixes are neither defined in config.ini nor as a system property. Using default value: org.eclipse.scout.commons.serialization.bundleOrderPrefixes=nl.rid.scarabee.,org.eclipse.scout
!ENTRY org.eclipse.scout.rt.ui.rap 4 0 2014-05-14 10:40:13.159
!STACK 0
!ENTRY org.eclipse.scout.rt.client 4 0 2014-05-14 10:40:13.159
!STACK 0
	... 21 more
!ENTRY org.eclipse.scout.rt.ui.rap 4 0 2014-05-14 10:40:13.191
!STACK 0
2014-05-14 10:40:13.191:WARN:oejs.ServletHandler:ERROR:  /web
Re: Rap login problem [message #1383810 is a reply to message #1354439] Mon, 26 May 2014 10:51 Go to previous messageGo to next message
I don't know if you have already configured this, but this was a point I struggled some weeks ago.
Did you change the config.ini of the RAP configuration? Because you have to add there the same credential as in the SWT config.ini for DataSourceSecurity.
Also you have to plugin.xml. For me the following configuration worked.
<extension point="org.eclipse.scout.http.servletfilter.filters">
    <filter
      aliases="/"
      class="org.eclipse.scout.http.servletfilter.security.AnonymousSecurityFilter"
      ranking="50">
    </filter>
    <filter
      aliases="/web"
      class="org.eclipse.scout.http.servletfilter.security.BasicSecurityFilter"
      ranking="40">
    </filter>
    <filter
      aliases="/process"
      class="org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter"
      ranking="30">
    </filter>
    <filter
      aliases="/web"
      ranking="20">
    </filter>
     <filter
      aliases="/"
      ranking="10">
    </filter>
Regards Chris
Re: Rap login problem [message #1391113 is a reply to message #1383810] Mon, 30 June 2014 09:14 Go to previous messageGo to next message
Hi, still did not solve the issue.
To validate my eclipse (Kepler SR2) environment, I created a new project and only implemented the security. That works OK with a dataSourceSecurityFilter (Server, Swing client and RAP client).
The project I have the problem with is a project that is initailly created with an older version of Eclipes Scout (could be Indigo or Juno). I ran through all the configurations , target definitions etc. but I cannot find any difference. Maybe someone has another hint?
!ENTRY org.eclipse.scout.rt.client 4 0 2014-06-30 15:01:29.462
!STACK 0
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.initClientSession(AbstractRwtEnvironment.java:463)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.init(AbstractRwtEnvironment.java:365)
	at org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.ensureInitialized(AbstractRwtEnvironment.java:319)
	at org.eclipse.scout.rt.ui.rap.AbstractStandaloneRwtEnvironment.createApplicationContent(AbstractStandaloneRwtEnvironment.java:135)
	at org.eclipse.scout.rt.ui.rap.AbstractStandaloneRwtEnvironment.createUI(AbstractStandaloneRwtEnvironment.java:99)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
	at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
	... 22 more
!ENTRY org.eclipse.scout.rt.ui.rap 4 0 2014-06-30 15:01:31.444:WARN:oejs.ServletHandler:ERROR:  /web
	at org.eclipse.scout.rt.ui.rap.AbstractStandaloneRwtEnvironment.createApplicationContent(AbstractStandaloneRwtEnvironment.java:142)
2014-06-30 15:01:31.429
!MESSAGE org.eclipse.scout.rt.ui.rap.AbstractRwtEnvironment.init(AbstractRwtEnvironment.java:368) ClientSession is not active, there must be a problem with loading or starting
Re: Rap login problem [message #1396076 is a reply to message #1391113] Mon, 07 July 2014 17:09 Go to previous messageGo to next message
I had similar issues once. My solution may be relevant.
The problem was that the RAP had no alias to the server, and therefore no access. The solution:
    <filter
      aliases="/ /web"
      ranking="20">
    </filter>
Hope that's helpful...
Re: Rap login problem [message #1424199 is a reply to message #1396076] Mon, 15 September 2014 12:25 Go to previous message
Hi I still did not succeed to fix the RAP login. Created a new project (luna) that works fine. I cannot find any differences between configuration etc. but still get the same error. Has anybody a hint how to trace this.
Regards Bertin
Previous Topic:"Flicker/blink" on mouse move with Firefox>=28 (RAP GUI)
Next Topic:Amount and currency field
Current Time: Wed Jul 23 07:41:22 EDT 2025
Powered by FUDForum. Page generated in 0.54383 seconds
