Home » Language IDEs » C / C++ IDE (CDT) » Add a global variable with CDT 2.1 generates a "Null pointer exception"
Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #134767] |
Thu, 13 January 2005 11:06  |
With CDT 2.1, in Debug perspective, when I try to "Add a global variable"
to the "Variables" View, the following Null pointer exception occurs.
I can't add any global variable in the Variable view.
This feature works fine with the CDT 2.0.2 and same program.
Any idea ? Is it a known bug ?
Jerome
!ENTRY org.eclipse.ui 4 0 Jan 13, 2005 16:46:56.500
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.creat eGlobalVariable(CDebugTarget.java:1877)
at
org.eclipse.cdt.debug.internal.core.CGlobalVariableManager.a ddGlobals(CGlobalVariableManager.java:104)
at
org.eclipse.cdt.debug.internal.ui.actions.AddGlobalsActionDe legate.doAction(AddGlobalsActionDelegate.java:269)
at
org.eclipse.cdt.debug.internal.ui.actions.AddGlobalsActionDe legate$1.run(AddGlobalsActionDelegate.java:100)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.cdt.debug.internal.ui.actions.AddGlobalsActionDe legate.run(AddGlobalsActionDelegate.java:96)
at
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:71)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:266)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
at
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #134915 is a reply to message #134794] |
Fri, 14 January 2005 10:48   |
When I debug the plugin, in the file "AddGlobalsActionDelegate.java", in
'doAction' method, the variables in the selected list (CVariableFactory)
have path=null. It seems that it is this 'null' value that generates the
exception.
In 'CDebugTarget.java', 'getCFileGlobals' method, all symbols have also
their sourceFile = null.
Any idea ?
Mikhail Khodjaiants wrote:
> Which platform are you using?
> "jerome correnoz" <jerome.correnoz@st.com> wrote in message
> news:cs66al$8nb$1@www.eclipse.org...
>> Hello,
>> Thanks
>> Jerome
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #134928 is a reply to message #134915] |
Fri, 14 January 2005 11:16   |
Originally posted by: mikhailkhod.rogers.com
We retrieve this information parsing the executable. The problem may be
caused by a parsing error or incorrect debug information. Either way we
should check if path != null, so this is a bug.
news:cs8pl6$urt$1@www.eclipse.org...
> exception.
> Any idea ?
> >> Hello,
variable"
> >> Thanks
> >> Jerome
> >> !STACK 0
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
tem.java:866)
> >> at
tionItem.java:785)
> >> at
> >> at
> >> at
java:335)
> >> at
> >> at
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #135102 is a reply to message #134928] |
Mon, 17 January 2005 04:53   |
Is this information in the DWARF ?
>> exception.
>> Any idea ?
>> >> Hello,
> variable"
>> >> Thanks
>> >> Jerome
>> >> !STACK 0
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
> tem.java:866)
>> >> at
> tionItem.java:785)
>> >> at
>> >> at
>> >> at
> java:335)
>> >> at
>> >> at
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #135177 is a reply to message #135102] |
Mon, 17 January 2005 12:39   |
Originally posted by: alain.nowhere.ca
The Dwarf parser is not finish.
If you are using cygwin i.e. the PE Windows Parser
we use the binutils tools: nm, addr2line to retrieve
the information. I've notice in many cases the information
return by the utilities are erroneous.
>>> exception.
>>> Any idea ?
>>> >> Hello,
>> variable"
>>> >> Thanks
>>> >> Jerome
>>> >> !STACK 0
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>>> >> at
>> tem.java:866)
>>> >> at
>> tionItem.java:785)
>>> >> at
>>> >> at
>>> >> at
>> java:335)
>>> >> at
>>> >> at
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #135239 is a reply to message #135177] |
Tue, 18 January 2005 02:13   |
Thanks for your answer.
I'm using org.eclipse.cdt.core.ELF binary parser for a ST100 core.
>>>> exception.
>>>> Any idea ?
>>>> >> Hello,
>>> variable"
>>>> >> Thanks
>>>> >> Jerome
>>>> >> !STACK 0
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>> tem.java:866)
>>>> >> at
>>> tionItem.java:785)
>>>> >> at
>>>> >> at
>>>> >> at
>>> java:335)
>>>> >> at
>>>> >> at
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #135261 is a reply to message #135177] |
Tue, 18 January 2005 03:02   |
You use nm and addr2line to retrieve this debug information but how is
this information used by the CDT ? Is it necessary ? What are the
limitations with CDT if this information isn't returned.
>>>> exception.
>>>> Any idea ?
>>>> >> Hello,
>>> variable"
>>>> >> Thanks
>>>> >> Jerome
>>>> >> !STACK 0
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>>> >> at
>>> tem.java:866)
>>>> >> at
>>> tionItem.java:785)
>>>> >> at
>>>> >> at
>>>> >> at
>>> java:335)
>>>> >> at
>>>> >> at
Re: Add a global variable with CDT 2.1 generates a "Null pointer exception" [message #135337 is a reply to message #135261] |
Tue, 18 January 2005 10:49  |
At the current time not much:
- the add global variable action may not work
- adding breakpoints in the outliner of a binary
- Many ISV using the CDT as the base of there IDE
use the information in there own plugin(for example some memory analysis)
- Some browsing capabilities may not work
But this is no show stopper any most users will not even notice.
Current Time: Wed Oct 15 03:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.05761 seconds
