Home » Eclipse Projects » Eclipse Platform » Change The Locale
Change The Locale [message #135253] Wed, 24 September 2003 11:45 Go to next message
What, if any, mechanism is provided by eclipse for changing locales?
If there is a way to change locales might there be a way to do it
dynamically while eclipse is running?
Any help with eclipse locale changing would be greatly appreciated.
Thank you,
Greg
Re: Change The Locale [message #135289 is a reply to message #135253] Wed, 24 September 2003 12:23 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
You can startup eclipse using -nl <Locale>
Currently there's no UI that would allow the user to do this and
existing views/dialogs don't change dynamically.
HTH
Dani
> Thank you,
> Greg
Re: Change The Locale [message #135317 is a reply to message #135289] Wed, 24 September 2003 12:41 Go to previous messageGo to next message
Daniel Megert wrote:
Thank you very much. I have one other question you may also know the
answer to:
Do you know if there is a place I could find a list of all the locales
that eclipse supports? I want to create a UI button that would allow a
user to change locales (even if it has to restart eclipse when one is
selected) I need to test some stuff out though and I can't seem to get any
of, what I thought where, standard locales to work.
> HTH
> Dani
> > Thank you,
> > Greg
Re: Change The Locale [message #135881 is a reply to message #135317] Thu, 25 September 2003 08:52 Go to previous messageGo to next message
> answer to:
That's not so easy since it depends on each plug-in how many languages
it supports i.e. for which languages it delivers the *.properties files.
I don't know of any API that would help you here.
Dani
>>HTH
>>Dani
>>>Thank you,
>>>Greg
Re: Change The Locale [message #136037 is a reply to message #135881] Thu, 25 September 2003 13:04 Go to previous message
You can scan the file system, look for properties files and come up with a
rough guess?
Some plugins may support German, some French, some both, but no
garantuees anywhere....
Chris
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bkuocq$1f0$1@eclipse.org...
> > answer to:
> Dani
any
> >>HTH
> >>Dani
> >>>Thank you,
> >>>Greg
Previous Topic:ant Build file name?
Next Topic:Where are Launch Configurations stored?
Current Time: Wed Nov 05 15:40:06 EST 2025
Powered by FUDForum. Page generated in 0.04302 seconds
