Home » Modeling » TMF (Xtext) » Cross reference, Qualified name and scoping(Problem when referencing a qualified name using cross reference)
Cross reference, Qualified name and scoping [message #1349676] Mon, 12 May 2014 05:45 Go to next message
I want to make cross reference using qualified name but i had some problem with it.
I want to be able to parse
Probe P1 {
  11 22 33 //the content of Probe is not important
Condition C1 {
  P1.value = 1
Here is an extract of the grammar
Probe :
  'Probe' name=ID '{'
   descr+=INT+
Condition :
  'Condition' name=ID '{'
   probe=[Probe] '.' met=ID '=' val=INT
Using this grammar, I can only parse 'P1 . value' and not 'P1.value' . It parse 'P1.value' as a single token. Note that the 'value' field is not defined in the language anywhere.
I tried a workaround :
Condition :
   probe=QualifiedName '=' val=INT
I don't use the cross reference directly but a qualified name. I bind it with to correct probe in the MyDslGenerator (in my generated code), check that the used probe is defined in the MyDslValidator, and add the correct auto-completion in the MyDslProposalProvider.
Is there a less hacky way to do it ?
Re: Cross reference, Qualified name and scoping [message #1350354 is a reply to message #1349676] Mon, 12 May 2014 12:24 Go to previous messageGo to next message
Hi xxx=[Sometype] is short for xxx=[Sometype|ID] and means "parse an
ID To reference a Some type. Thus you want to have
xxx=[SomeType|QualifiedName]
BTW why should x.y with your first grammar not work. Maybe you have
some other conflicting terminals
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Cross reference, Qualified name and scoping [message #1350397 is a reply to message #1350354] Mon, 12 May 2014 12:48 Go to previous messageGo to next message
Christian Dietrich wrote on Mon, 12 May 2014 12:24
I can't have xxx=[SomeType|QualifiedName] because the Probe is defined only by its name 'P1', and when is used with : 'P1.value' . The field 'value' is not defined anywhere. I tried with xxx=[SomeType|QualifiedName], I have as error : Couldn't resolve reference to Probe 'P1.value'.
I was suprised that it didn't work. I only have two others terminal rules :
terminal QualifiedName:
	ID ("." ID)+
terminal COMPARATOR: '<' | '>' | '>=' | '<=' | '=';
Re: Cross reference, Qualified name and scoping [message #1350449 is a reply to message #1350397] Mon, 12 May 2014 13:17 Go to previous messageGo to next message
Hi qualifiedname should be a data type rule instead of a terminal.
QualifiedName: ID ("." ID)*;
Re: Cross reference, Qualified name and scoping [message #1350476 is a reply to message #1350449] Mon, 12 May 2014 13:32 Go to previous messageGo to next message
That was the problem.
Thanks a lot !
Re: Cross reference, Qualified name and scoping [message #1783666 is a reply to message #1349676] Thu, 15 March 2018 06:42 Go to previous messageGo to next message
I have the following rule for qualified names:
QualifiedName:
    ((catalogName=ID '.')? schemaName=ID '.')? identifier=ID;
And I can't use it for cross-references because it's not a data rule returning EString.
Also in my language the following idnetifiers are the same: dbo.person, "dbo".person, dbo.PERSON
I think I need to transform them into a canonicial form before comparision or implement a custom comparision.
Could you suggest how to implement it?
For now I have the following scope provider:
class SQLScopeProvider implements IScopeProvider {
    override getScope(EObject context, EReference reference) {
        if (context instanceof ReferencesColumnConstraint) {
            if (reference == SqlPackage.eINSTANCE.referencesColumnConstraint_ReferredTableName) {
                val rootElement = EcoreUtil2.getRootContainer(context)
                val candidates = EcoreUtil2.getAllContentsOfType(rootElement, TableDefinition)
                return new SimpleScope(candidates.map[EObjectDescription.create(it.tableName.fullyQualifiedName, it)])
            else if (reference == SqlPackage.eINSTANCE.referencesColumnConstraint_ReferredColumnNames) {
                if (context.referredTableName !== null) {
                    val rootElement = context.referredTableName
                    val candidates = EcoreUtil2.getAllContentsOfType(rootElement, ColumnDefinition)
                    return new SimpleScope(candidates.map[EObjectDescription.create(it.name, it)])
    def QualifiedName getFullyQualifiedName(TableName obj) {
        if (obj.schemaName === null) {
            QualifiedName.create(obj.identifier)
        else if (obj.catalogName === null) {
            QualifiedName.create(obj.schemaName, obj.identifier)
        else {
            QualifiedName.create(obj.catalogName, obj.schemaName, obj.identifier)
Re: Cross reference, Qualified name and scoping [message #1783668 is a reply to message #1783666] Thu, 15 March 2018 06:55 Go to previous messageGo to next message
you can always implement a IQualifiedNameProvider or a helper as you did .
which comparison are you talking about
Re: Cross reference, Qualified name and scoping [message #1783680 is a reply to message #1783668] Thu, 15 March 2018 09:39 Go to previous messageGo to next message
Thanks! I've got it.
Here is a simplified fragment of the grammar:
TableDefinition:
    'CREATE' 'TABLE'
    tableName=TableName
    contentsSource=TableContentsSource;
AlterTableStatement:
    'ALTER' 'TABLE'
    tableName=[TableDefinition]
    action=AlterTableAction;
TableName:
ID returns ecore::EString:
    IDENTIFIER ('.' IDENTIFIER)*;
I have to use diferent rules for identifier itself (TableName rule in my grammar) and identifier reference (ID rule in my grammar). I can't use TableName for both. An alternative approach is to use ID rule for both kinds of ids.
On comparision... In my language dbo.person equals dbo."person". I've implemented a value converter, which adds quotes to all segments of an identifier:
class IdConverter implements IValueConverter<String> {
    final static String IDENTIFIER_PATTERN = '([A-Za-z][A-Za-z0-9_]*|"([^"]|"")*")'
    final static Pattern patternFirst = Pattern.compile('''^«IDENTIFIER_PATTERN»([.]«IDENTIFIER_PATTERN»)*$''')
    final static Pattern patternFollowing = Pattern.compile('''[.]«IDENTIFIER_PATTERN»''')
    override toString(String value) throws ValueConverterException {
        // TODO: Remove quotes?
        value
    override toValue(String string, INode node) throws ValueConverterException {
        if (string === null) return null
        val matcherFirst = patternFirst.matcher(string)
        if (!matcherFirst.matches()) {
            throw new IllegalArgumentException("Invalid value: " + string)
        val matcherFollowing = patternFollowing.matcher(string)
        val segments = new ArrayList<String>()
        segments.add(matcherFirst.group(1))
        for (var start = 0; matcherFollowing.find(start); start = matcherFollowing.end()) {
            segments.add(matcherFollowing.group(1))
        segments.map[quote].join('.')
    def private static quote(String value) {
        if (value.startsWith('"')) return value
        '"' + value.replace('"', '""') + '"'
Also my ScopeProvider quotes all identifier's segments. So identifier comparision works as expected now.
Re: Cross reference, Qualified name and scoping [message #1783682 is a reply to message #1783680] Thu, 15 March 2018 09:49 Go to previous messageGo to next message
The only problem is that ID is the terminal rule. So, if an identifier will contain a comment
dbo./*comment*/person
this comment will be lost after parsing-serialization cycle.
Re: Cross reference, Qualified name and scoping [message #1783700 is a reply to message #1783682] Thu, 15 March 2018 13:29 Go to previous message
hmmmm have no idea on that.
hat was not working with having name in 3 parts?
or is this about the cross reference containing comments?
Previous Topic:Opting to use original formatter over formatter2
Next Topic:Unable to execute MWE2Runner with maven
Current Time: Sun Jul 27 11:58:05 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
