| Papyrus model to emf/uml2 - stereotypes get lost [message #1341611] |
Thu, 08 May 2014 11:14  |
iam total newbie to emf and papyrus. I have a given payprus model in emf/uml2. (.uml).
//Problem:
The model with the "platform:/" has lost all its stereotypes and profiles, especially the needed sysML one.
There are still packages "pathmap:/" around.
Is there a way to fix that stereotype-lost problem?
Are there may plugins wich could do that ?
//speculation
In my search for a solution i found for example that:
http://www.eclipse.org/forums/index.php/t/354631/
It is often recommended to fix the pathmap or register the profiles of papyrus to the emf-model. I don't understand the example in the link , how that pathmap are fixed , how do i find wich should be fixed and so on.
May some could give me hints
best wishes
Mathias
| Re: Papyrus model to emf/uml2 - stereotypes get lost [message #1343663 is a reply to message #1341611] |
Fri, 09 May 2014 07:55   |
Hi, Mathias,
If you are loading UML (or any EMF-based) resources in a "stand-alone"
JVM (without the Eclipse run-time and workspace), then you will simply
have to have a priori knowledge of the mappings of all
platform:/resource/<project>/... URIs to locations in the filesystem or
wherever.
The usual way to set up these mappings is using the
URIConverter::getURIMap() of the URI converter provided by the
ResourceSet in which you are loading your resources. Note that the
keys and the values of these mappings should both be *prefix* URIs,
that is, hierarchical URIs ending with a slash ('/'). These map
logical "folders".
URIs of the platform:/plugins/<symbolic-name>/... and
pathmap://<token>/... form indicate library models and profiles
deployed in Eclipse plug-ins. For any such resources provided by the
Eclipse UML plug-ins, the UMLResourcesUtil::init(ResourceSet) utility
API should set up the mappings that you need. I don't think that
Papyrus provides any comparable utility for the SysML profiles and
libraries, so you'll need to set that up. Probably the implementation
of UMLResourceUtil can be a guide.
HTH,
Christian
On 2014-05-08 15:51:45 +0000, Mathias Krill said:
> emf/uml2. (.uml).
> //Problem:
> profiles, especially the needed sysML one. There are still packages
> "pathmap:/" around.
> //speculation
> on.
> best wishes
> Mathias
| Re: Papyrus model to emf/uml2 - stereotypes get lost [message #1349439 is a reply to message #1343663] |
Mon, 12 May 2014 03:37   |
Hi Christian and thank you for your explanations. May you could give me some futher hints, i'll start with the Ressource-Set:
"The usual way to set up these mappings is using the
ResourceSet in which you are loading your resources."
The ResourceSet in which iam loading the resources - how do i define/get that ?
I have seen some code like that:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
resourceSet.getPackageRegistry().put(Ecore2XMLPackage.eNS_URI, Ecore2XMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(SysmlPackage.eNS_URI, SysmlPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(ModelelementsPackage.eNS_URI, BlocksPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(BlocksPackage.eNS_URI, BlocksPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(PortandflowsPackage.eNS_URI, PortandflowsPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(ConstraintsPackage.eNS_URI, ConstraintsPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(ActivitiesPackage.eNS_URI, ActivitiesPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(AllocationsPackage.eNS_URI, AllocationsPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(RequirementsPackage.eNS_URI, RequirementsPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(InteractionsPackage.eNS_URI, InteractionsPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(StatemachinesPackage.eNS_URI, StatemachinesPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UsecasesPackage.eNS_URI, UsecasesPackage.eINSTANCE);
I suppose thet profilSet.getPackageRegistry() is the part of getting the actual resource-set in wich i have to load the resources?
So profilSet is a Hashmap :(key, URI) and i register for the actual instance:
.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE); ?
[Updated on: Mon, 12 May 2014 04:40] by Moderator
| Re: Papyrus model to emf/uml2 - stereotypes get lost [message #1349941 is a reply to message #1349439] |
Mon, 12 May 2014 08:20   |
Hi, Mathias,
To get a resource set, you just create it like so:
ResourceSet rset = new ResourceSetImpl();
A resource set has a local package registry in which you can put
EPackages for the EMF run-time to find when loading resources that
contain instances of the EClasses in those packages.
Much of the basics of working with EMF should be explained in the EMF
tutorials [1] on the Eclipse website and/or in the FAQ [2].
HTH,
Christian
[1] http://www.eclipse.org/modeling/emf/docs/
[2] https://wiki.eclipse.org/EMF/FAQ
> // Load the profile
> URI profileUri = URI.createURI(PROFILE_NAME);
> ResourceSet profileSet = new ResourceSetImpl();
> profileSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
> profileSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION,
> UMLResource.Factory.INSTANCE);
> profileSet.createResource(profileUri);
> Resource profileResource = profileSet.getResource(profileUri, true);
> Profile profile =
> (Profile)EcoreUtil.getObjectByType(profileResource.getContents(),
> UMLPackage.Literals.PROFILE);
> [...]from
> stackoverflow.com/questions/15374753/eclipse-uml2-obtain-value-of-a-property-defined-in-a-profile
FUDForum. Page generated in 0.04908 seconds
