Home » Eclipse Projects » Eclipse Platform » Force deletion
Force deletion [message #134920] Wed, 24 September 2003 08:28 Go to next message
Originally posted by: yohai.attunity.co.il
Hi.
I'm trying to delete a file but it seems to be "locked" somehow by some
resource. I get a messgage saying i can't delete the file because "it is
being used by another person or program". Is there's a way to check which
program is using this file? Is there a way to force the deletion?
____________________________________________________________ ______ yohai
ICQ#: 81309797 Current ICQ status: + More ways to contact me
Re: Force deletion [message #135537 is a reply to message #134920] Wed, 24 September 2003 16:40 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
That's a limitation of your operating system. Some operating systems
allow you to delete a file that is being read by another process, and
others (ie, Windows) do not.
Yohai Danon wrote:
> Hi.
Re: Force deletion [message #135651 is a reply to message #134920] Wed, 24 September 2003 21:20 Go to previous message
> Is there's a way to check which program is using this file?
You have to play Sherlock Holmes. Check the type of the file. Check your
open applications.
A special case is when you have a DOS box that has its current working
directory in one of the subdirectories of one of your projects.
For instance, if your DOS box sits in MYPROJECT/bin and you do
a rebuild-project on MYPROJECT, the builder may not be able
to remove the contents of the bin directory.
Chris
Previous Topic:PDE Runtime not picking up plugins
Next Topic:plugin
Current Time: Sat Nov 01 16:48:23 EDT 2025
Powered by FUDForum. Page generated in 0.51325 seconds
