no http requests recorded [message #134698] |
Thu, 21 August 2008 15:55  |
I run eclipse 3.4.0 on windows 2003 server R2.
I just installed latest TPTP plug-in.
When I try to record a HTTP URL test, internet explorer is launched at
google.ca
and everything seems ok:
Test generation started with generator: TPTP URL Test Generator
Test to be generated: /MyJavaRecordingProject/src/recordings.testsuite
Test generation completed.
Warning: Port 1080 already in use. Using port 1287 for recording.
Recording started.
Connecting to Agent Controller on host 'localhost' and port '10002'.
Deploying required recorder files.
Sending command: Init
Sending command: StartRecording
Sending command: StartApp 'Internet Explorer'
Recording completed.
The following HTTP requests are defined int this test:
No HTTP requests.
the list remains empty.
I would like to record HTTP requests from browser.
Can someone help me ?
thank you.
carmichael underscore martin at hotmail dot com
Re: no http requests recorded [message #135111 is a reply to message #135045] |
Wed, 27 August 2008 06:42  |
Great news Martin. Yes, it appears to be a firewall issue based on your
information. You can configure the URL Recorder port in the preferences
(Window >> Preferences >> Test >> TPTP URL >> URL Recorder >> Proxy
Recorder ).
Paul
"martin carmichael" <carmichael_martin@hotmail.com> wrote in message
news:375588385a6eec919a16c267da080a99$1@www.eclipse.org...
> Hello Paul,
> Where I work, we have three distinct ms-windows domains. It might be
> possible that some networks/domains are subject to firewall/port
> restrictions. I just cannot tell as I do not know how to diagnose.
> On my machine The firefox plug-in selenium and selenium RC (remote
> control) do work on port 4444, as I can record and play back HTTP
> sessions.
> Yesterday, I did try to install eclipse and tptp on a XP machine in an
> other distinct windows domain. Guess what: It worked.
> If it is a firewall related problem, is there a way to configure the TPTP
> recorder and the integrated agent to work on port 4444 ?
> If not, I will keep working on the XP machine. My 2003 server uses many
> distinct components, each with different versions:
> TPTP platform : 4.5
> TPTP profiling: 4.4
> test framework: 4.3.2
> monitoring: 4.4.1
> and so on
> Thank you for your support. It is appreciated.
FUDForum. Page generated in 0.41609 seconds
