Home » Archived » Visual Editor (VE) » How to test a BeanInfo
How to test a BeanInfo [message #134862] Sun, 14 January 2007 11:22 Go to next message
I've written a BeanInfo for a custom component and now I want to see if
it is loaded into the remote-VM. How can I test this, either by using
the debugger or some test code?
Thanks in advance,
Daniel
Re: How to test a BeanInfo [message #134962 is a reply to message #134862] Tue, 16 January 2007 22:13 Go to previous messageGo to next message
Daniel Rohe schrieb:
> Hello,
> Thanks in advance,
> Daniel
I've tested my plugin in a separate Eclipse instance. In this instance I
get the following error:
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.Error: Unresolved compilation problems:
The import org.eclipse.jem.beaninfo.vm cannot be resolved
BaseBeanInfo cannot be resolved to a type
I've tried to create my own BeanInfo for the layout just like one of the
bean infos for the JFC classes in the org.eclipse.ve.jfc plugin. To
solve my problem can someone point me to the correct location to look for.
Kind regards,
Daniel
Re: How to test a BeanInfo [message #134973 is a reply to message #134962] Wed, 17 January 2007 10:02 Go to previous messageGo to next message
The problem is you need the jar that contains the
org.eclipse.jem.beaninfo.vm.BaseBeanInfo class. It is contained in the
org.eclipse.jem.beaninfo plugin. That needs to be on your classpath too.
>> Hello,
>> if it is loaded into the remote-VM. How can I test this, either by
>> using the debugger or some test code?
>> Thanks in advance,
>> Daniel
> Kind regards,
> Daniel
Rich Kulp
Re: How to test a BeanInfo [message #134982 is a reply to message #134973] Wed, 17 January 2007 19:20 Go to previous message
I know, but how do I get this jar into the classpath of the remote-vm?
As far as I understood VE, all BeanInfo classes are in the remove-vm and
provide more information to JEM about UI components. It would especially
be interesting how the org.eclipse.ve.jfc plugin has solved this problem.
Kind regards,
Daniel
>>> Hello,
>>> Thanks in advance,
>>> Daniel
>> I get the following error:
>> the bean infos for the JFC classes in the org.eclipse.ve.jfc plugin.
>> To solve my problem can someone point me to the correct location to
>> look for.
>> Kind regards,
>> Daniel
Re: How to test a BeanInfo [message #615000 is a reply to message #134862] Tue, 16 January 2007 22:13 Go to previous message
> Hello,
> Thanks in advance,
> Daniel
Kind regards,
Daniel
Re: How to test a BeanInfo [message #615001 is a reply to message #134962] Wed, 17 January 2007 10:02 Go to previous message
>> Hello,
>> Thanks in advance,
>> Daniel
> Kind regards,
> Daniel
Rich Kulp
Re: How to test a BeanInfo [message #615002 is a reply to message #134973] Wed, 17 January 2007 19:20 Go to previous message
Kind regards,
Daniel
>>> Hello,
>>> Thanks in advance,
>>> Daniel
>> look for.
>> Kind regards,
>> Daniel
Previous Topic:Where are VE's code generation templates???
Next Topic:SWT problem: unable to change size when gridlayout is used
Current Time: Sun Jul 20 23:18:49 EDT 2025
Powered by FUDForum. Page generated in 0.32455 seconds
