Home » Archived » BIRT » JS-Scriptiing: What exacly does Row.rowData.getExpressionValue() do?
JS-Scriptiing: What exacly does Row.rowData.getExpressionValue() do? [message #134812] Thu, 23 February 2006 01:43 Go to next message
Originally posted by: juergen.schwarz.gefasoft.de
I try to use rowData.getExpressionValue() in the Row of a Table to get
the data of the Dataset. But this function seems to give strange results
and not the data.
Any explanations what this function really does? Or how I can get the
data of my Dataset?
Is there any documentation about the availabe classes and their methods
that can be used for scripting? I have the BIRT Designer help but this
doesn't really help...
Re: JS-Scriptiing: What exacly does Row.rowData.getExpressionValue() do? [message #136121 is a reply to message #134812] Fri, 24 February 2006 19:37 Go to previous message
rowData.getExpressionValue(int) should give you the value of the expression
in the i:th column in your table.
rowData.getExpressionValue("some_expression") should give you the value of
the provided expression for the row (need to be a defined column expression
on the table).
Examples:
Table(2 columns):
row["product"] | row["price"]
Result:
product1 | $20
product2 | $30
Script on row.onCreate:
if (this.rowData.getExpressionValue(1) == "product1")
this.getStyle().backgroundColor = "red";
if (this.rowData.getExpressionValue("row[price]") == "$20")
this.getStyle().backgroundColor = "blue";
Result of script:
First row should be red, second row should be blue.
Remember that the the expressions are the one defined on the table, not the
dataset. So if a table has the following expression: row["price"]/100, the
following if ok:
rowData.getExpressionValue("row[price]/100")
but this is not:
Hope this helps,
Petter Ivmark
"Juergen Schwarz" <juergen.schwarz@gefasoft.de> wrote in message
news:dtjlip$56g$1@utils.eclipse.org...
>I try to use rowData.getExpressionValue() in the Row of a Table to get the
>data of the Dataset. But this function seems to give strange results and
>not the data.
> Any explanations what this function really does? Or how I can get the data
> of my Dataset?
Previous Topic:Is there a setStyle for a report elements?
Next Topic:CSV without veiwer?
Current Time: Tue Sep 23 03:32:12 EDT 2025
Powered by FUDForum. Page generated in 0.02882 seconds
