Error running URL Test [message #134811] |
Fri, 22 August 2008 09:50  |
Hi!
I have a problem running a URL Test as Test (local_deployment). When I run
the Test as JUnit-Test it works.
I get following error in the *.execution file. I use Java JDK 1.5.0_8 as
Eclipse JRE. Do you need any further information.
What does the error message mean?
Thanks for your help,
Günter!
Error Message:
<executionEvents xsi:type="Common_Testprofile:TPFMessageEvent"
ownerId="A1DD6F9F1D5C62E1EB88B03062363338" timestamp="1219411318515"
text="java.lang.UnsupportedClassVersionError: (test/Unriskfactory_admin)
bad major version at offset=6
	at
java.lang.ClassLoader.defineClassImpl(Native Method)
	at
java.lang.ClassLoader.defineClass(ClassLoader.java:224)& #xD;
	at
java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:148)
	at
java.net.URLClassLoader.defineClass(URLClassLoader.java:556)
	at
java.net.URLClassLoader.access$400(URLClassLoader.java:119)& amp;#xD;
	at
java.net.URLClassLoader$ClassFinder.run(URLClassLoader.java: 961)
	at
java.security.AccessController.doPrivileged(AccessController .java:275)
	at
java.net.URLClassLoader.findClass(URLClassLoader.java:487)&a mp;#xD;
	at
java.lang.ClassLoader.loadClass(ClassLoader.java:603)&#x D;
	at
sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:327 )
	at
java.lang.ClassLoader.loadClass(ClassLoader.java:569)&#x D;
	at
java.lang.Class.forNameImpl(Native Method)
	at
java.lang.Class.forName(Class.java:164)
&am p;#x9;at
org.eclipse.hyades.test.java.runner.HyadesJUnitRunner.main(H yadesJUnitRunner.java:188)
severity="error"/>
FUDForum. Page generated in 0.04390 seconds
