Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with DecorationOverlayIcon
Problem with DecorationOverlayIcon [message #134637] Tue, 02 June 2009 06:08 Go to next message
--------------020900090006040902090000
Hello everybody,
Recently I've experienced a strange problem. I have a TableViewer with
decorated icons in its items.
At some point I call ColumnViewer#refresh to update decorations.
I'm receiving com.sun.imageio.plugins.png.PNGImageReader exception.
Stack trace is provided along with the png image.
com.sun.imageio.plugins.png.PNGImageReader#readImage at 1253 has thrown
an IOException from decodeImage().
Content-Type: application/x-zip-compressed;
name="overlays.zip"
Content-Disposition: inline;
filename="overlays.zip"
UEsDBAoAAAAAAFR4wjqWW+XwFAIAABQCAAAPACQALTE4Mjg3MTI1MDgucG5n CgAgAAAAAAAB
ABgABi6t4GDjyQFpBL0EZ+PJAWkEvQRn48kBiVBORw0KGgoAAAANSUhEUgAA ABAAAAAQCAYA
AAAf8/9hAAAB20lEQVR4nGNgGBRg7dq1/zdv3vx/wYIF/ydOnPi/u7sbK25q avpfWlr6PyMj
4z+KASDNIBAUFPQfBpDZ6PzY2FhUA+bPn//f19cXA3t5eWFgd3f3/wEBAagG TJo0CWzyzJkz
/8888x+MY6oQbBh/xun/YAwyCMWAnp6e/0+fPv3f0dHxv2PrIzAOyGr937Lh Dhg3rL353yet
8X/tymtg7ObmhmkAuguigTZOP/UfjiMqZv6fdOw/GIO8gWIAKIRv3779v7Gx 6X/Dmhtg7JVS
/79q2WUwLlt4/r9rQvX/onlnwBjDBU+uLfzfFccPxiD2lJNAG8tn/p8AtA2G Q0pngl1p0HwN
TKMYANJ48uzF/+WVNWBDSuaf/e8SV/W/cO4ZMEYG0XPv/bfuQDJkY5sO3HYY BokFA23sOvQf
jEHAY+Kt/1Fz7v03BLpAtuz8f+GcoxBDZuaL/P/zdhsc/7rV+B8kBvInDIOA U8/1/wxpZ+CY
PXH3f76Mg/8ZJqUJgjXOq9IG2/7rVsN/kBiyF0EGyJed/S+Rd/g/d8re/6yR a/8z+8+BuKA/
WfD/y2N5/3/dqAY7/cOpjP8gMXQDYEAqZf1/3rD5iDBYNyUWIwxAYgxYAEgT d8wahGYGBgDt
ggAi27tSlwAAAABJRU5ErkJgglBLAwQUAAAACADIfMI65SJhqrkFAAAUFgAA CQAkAHN0YWNr
LnR4dAoAIAAAAAAAAQAYAElLw9pl48kBSUvD2mXjyQE9STnXZePJAd1YTW/j NhA9t0D/gw4+
yIAhWLIs20VRwOtkWy2yayNOmsMiB1qa2NzQpEBRTry/vvzQpy01ddBe9pLE w3mPjzPDGcZX
CPaMWnc7Dii2vt6HxV/Jd8/1cfLy7XiAx0fLXmdpAjSG2LI30uM5YZgKCwmL YArWeGRhaoXh
8vo1gkRgRvv9n375+ae6xfkNUyx+t9eCY7odqD3ZC9oQ6GuOXyWJgqy+/BHu 0RZupQzgjlKj
P9uldYU42hcg1wuGHTBbKhxYHTA/mGiBajVcGn/zgSaZkBqh7ux5584tfiMv UH63kLKMR/AR
RYLxY3WGNf4ObcCR34qLpI8Ac/oiam3o4aQN/YRpPXJXSKBS6ESf5woixpHK zfIAnKBjGDFq
L9g+YSnON76CNOI4kYz9hp4NYwQQHVhXcMBRmUN3Oupm7iAshNsnVCaxxlj4 fEZUcnAHEcIi
ibWbyzXyoqiCThJ7vkkFl9E6sRe63uSeThX3jRRC3q1v6nVx/I/y7A7Kermc 0Z0VjSTJiHBi
Y4AHLHZ5tlPDMbBO9ymUzZpM62gHcUZk3P6JbLn5BpGofocVwYJRAa+ic0Nv GNR2ZLxIU7Fd
7eDv4h9P3Uv5C2jgaegaiDTeqX74F4YX4H8CSYD3tOUGbYCsODtg1du2IBaM ZHtqWAu5mJac
nucrTo01roazyZMlsSojs7QAQgr4RCuqA3ujwk0b+w6HJw7prgXs+roD3M5X iywVbF87UlnR
NVvfidm9FhIK2NsPOJbHq3KQt5my1U11HteCZ5HIOMS5vIphjZ7gNqNU7eDw jNoF1A90+Rbr
akbI1bDuX+6i++mKIPHE+L7bb2pu2KePKIJ7gUnP7fb1J/XdS3Wtvu5k3BnC 06P38zS2RK8q
/tHsAj5MBXCKiInpWUbMIPr6WLGb4XiRWruLzZ0FbidbvSLfZBqbzv8eWV8f 24QNu/nOLH1n
h2h8cnEX0raF2G4zXh+gur6j4chcQJkJKvISdx3yLrKJ39aZ8lItq9ObXHY5 zjrdE+Zwg1Mp
WMajU9TAChtrBaLSMe6YDD13qDSFtHii2qEk2XJI08+M4vrENz3iPvzENifH dIdDs7RAhHxA
0XMRjeKQH1Da7BqeCd8Zwkk4i+TeX+BVFOCatuo5ZG7yw90NfoLFMVLXXjrM aXyF0wSJaFdt
ZVqEshN07HSbTPUZPrMYkXws9eofjAJnQ1j0XOmYBKcgk+FCu5q3RTzLriuz dRLjgZXLq6rB
lBdGhG0/qD0x3S7Yfo9ofP0KUSZBvRMS42y3WvtaVrl/JaRNaJlxN3hThBOz FXDVzwsHe70D
QiR17rlQTyB1xJOZ4/pvH9FJ3sk9nP5X3M1Xn3lOhFT3pDzgtSdGLdg5S1WG w5l3AQN7XqlU
QEUwGrv+yYsmpMtMGERv7LAEqL2UPxp9yjfPy7PR7jXu49Sd/phTXPXPZWtg pu4lg8zMHc1k
EoBZk84dTiatgQ7+BdY171zlIvFIwPZYKteeHUBvPDvDoUg10J5n160Dq4tg dEog82QEm42b
7jN9xnsqjkk+euYxSoR6kucNtQXlT6ZdqBf9CrqCJ5QRYSRC3HHYPL6NtXLb O7bcpMAPMnnN
V5o7mZ3Dcn3FtDG2Uq7fArgrpXegXPMdReXngG40oEZZ5RUEFwyu0QWDq62v PGAasxfdjrSk
G8YS0+bKSzAK3gLrtlJdmkYTm+sI9byT94CZzj/Cc+CB8ecN0GjXjKGJTS8s v4T7U9+Y8znu
+UZag+c+rKkx1Vat59d3bJem6r/PWZOr5zeCmM+HW0BEt2U10vObZWvjwDrr 5SOvubv5vkIG
RHqWVjs/1MAqTfP4gNNqOPqzxlC4D99L5I410TxJCI70S3WeLghW18kw1mJn LvY1Ffy4Ut+a
FjVTOpr/NQp3M34bNXJG6Y2Gp069otrU+44zQvLZWOvdpnTzmjS/+g2fwFVS /wZQSwECGQAK
AAAAAABUeMI6llvl8BQCAAAUAgAADwAAAAAAAAAAACAAAAAAAAAALTE4Mjg3 MTI1MDgucG5n
UEsBAhkAFAAAAAgAyHzCOuUiYaq5BQAAFBYAAAkAAAAAAAAAAAAgAAAAZQIA AHN0YWNrLnR4
dFBLBQYAAAAAAgACAHQAAABpCAAAAAA=
--------------020900090006040902090000--
Re: Problem with DecorationOverlayIcon [message #134650 is a reply to message #134637] Tue, 02 June 2009 06:50 Go to previous messageGo to next message
I've been reading comments by Frank Appel in
ResourceFactory#createImage. The following testcase shows that the
approach is erroneous.
The img.png is the one I attached to my referenced message.
try
InputStream inputStream = new FileInputStream("c:\\img.png");
BufferedInputStream bis = new BufferedInputStream( inputStream );
try
ImageIO.setUseCache( false );
BufferedImage buf = ImageIO.read(bis);
catch (IOException e)
e.printStackTrace();
catch (FileNotFoundException e)
Dmitry Pryadkin wrote:
> Hello everybody,
Re: Problem with DecorationOverlayIcon [message #134714 is a reply to message #134650] Tue, 02 June 2009 07:35 Go to previous messageGo to next message
The image itself seems to cause the problem. Reading it directly
also results in an exception:
InputStream inputStream = new FileInputStream( "c:\\imgage.png" );
ImageIO.read( inputStream );
raises the same exception as your code.
Some image-viewing-progreams also refuse to show the image.
> try
> try
>> Hello everybody,
>> thrown an IOException from decodeImage().
Re: Problem with DecorationOverlayIcon [message #134727 is a reply to message #134714] Tue, 02 June 2009 07:44 Go to previous messageGo to next message
Rüdiger,
The point is that it was not me who generated this image. It was
composed by DecorationOverlayIcon from the parts.
Rüdiger Herrmann wrote:
> The image itself seems to cause the problem. Reading it directly also
>> try
>> try
>>> Hello everybody,
>>> with decorated icons in its items.
Re: Problem with DecorationOverlayIcon [message #134740 is a reply to message #134727] Tue, 02 June 2009 08:27 Go to previous messageGo to next message
we experienced the same problem a few weeks ago. The problem was, that one
of the images (the icon itself, or the icon to overlay with) had a
transparent area. Some image software, like photoshop, can save the image in
a way it can not be read properly (transperency set to "on" and no
background color). To fix this in photoshop for example you can save for
web, than activate the checkbox for transperency, if not already activate,
and set background to be "white". This solved our problem.
Hope that helps.
Markus
"Dmitry Pryadkin" <drpadawan@ya.ru> schrieb im Newsbeitrag
news:h033a5$brs$1@build.eclipse.org...
> R
Re: Problem with DecorationOverlayIcon [message #134829 is a reply to message #134740] Wed, 03 June 2009 08:39 Go to previous message
Thanks, I'll check this out
Markus Krüger wrote:
Previous Topic:RightToLeft
Next Topic:How to use upload widgets
Current Time: Sat Jul 26 05:14:04 EDT 2025
Powered by FUDForum. Page generated in 0.08689 seconds
